googus Posted August 3, 2019 Share Posted August 3, 2019 I have searched around and fuel mileage varies a bit and it seems that around 150- 200 miles in the norm depending how heavy handed you are. I am on my second tank now. Up to about 60-70miles my bars don’t go down much but after that it seems like every time I put the kickstand up I loose a bar. My last bar starts blinking at 140 miles. The last time I filled it up was 161miles at 4.8 gallons ( took it to get gas as soon as it started to blink). This is all done 100% around town and very easy driving. Just want to get some thoughts. By reading other threads the pessimist side of me thinks I need a new fuel pressure regulator? Thanks Greg Quote Link to comment Share on other sites More sharing options...
SwampNut Posted August 3, 2019 Share Posted August 3, 2019 I've seen anywhere from 22 to 50+ MPG. Gone 250 miles on a tank once, even with a little twisty riding. I'm not understanding how a pressure regulator would change your fuel consumption without making the bike run like shit. 1 Quote Link to comment Share on other sites More sharing options...
googus Posted August 3, 2019 Author Share Posted August 3, 2019 I am far from a guy who know how to wrench very well. It is something that I read on a thread somewhere that when they changed out the regulator they saw better MPG Quote Link to comment Share on other sites More sharing options...
tomek Posted August 4, 2019 Share Posted August 4, 2019 Start with new vacuum lines. Just get generic line at Auto Zone, etc, cut to correct length and replace them all . You have to figure out ID of stock lines before heading to the store. It is gonna cost you like 2 bucks. Replace them piece by piece so you wont waste time trying to figure what goes where. It is cheaper and quicker than checking whether they are good or not. Ecu on XX needs accurate pressure or vacuum reading from intake ports to operate properly under light load conditions. In heavy load area it is rpm and % of throttle opening system. 1 Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted August 4, 2019 Share Posted August 4, 2019 I rarely see a FPR failure other than leaking into the vacuum hose. You can check this by just pulling the hose off and turning the key on to create pressure. On occasion they'll only leak when hot so if you see nothing cold try it after a ride. When the one on my '01 failed it started out not obvious, just a little bit stumbly here & there and some slow starts, eventually it started running like shit as the FPR got worse. 1 Quote Link to comment Share on other sites More sharing options...
redxxrdr Posted August 4, 2019 Share Posted August 4, 2019 If avaiable, try a couple of tanks of non ethanol gas and check mileage. My 01. Gets much better mileage (2-3 mpg) on good old gas. As posted by others, my vacuum lines were cracking, and caused some problems too. 1 Quote Link to comment Share on other sites More sharing options...
RXX Posted August 4, 2019 Share Posted August 4, 2019 2 hours ago, redxxrdr said: If avaiable, try a couple of tanks of non ethanol gas and check mileage. My 01. Gets much better mileage (2-3 mpg) on good old gas. As posted by others, my vacuum lines were cracking, and caused some problems too. Whether or not that fixes your problem, Craig is spot-on about the fuel increase. I just checked the Charlotte area on pure-gas.org (www.pure-gas.org) and there are a shit-bucket load of stations around there. No need for premium. BTW, the gauges are very bike specific. My “new” bird’s readings vary drastically from my old one. Both 1999 FI’s. Expect 220 miles per tank, and thank Allah if you do better. The blended gas has not been kind to your fuel lines, replacement is easy enough. 1 Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted August 4, 2019 Share Posted August 4, 2019 On 8/3/2019 at 9:22 AM, googus said: The last time I filled it up was 161miles at 4.8 gallons ( took it to get gas as soon as it started to blink). 33.5 MPG around town doesn't seem like something to worry about. 1 Quote Link to comment Share on other sites More sharing options...
XXitanium Posted August 5, 2019 Share Posted August 5, 2019 6 hours ago, superhawk996 said: 33.5 MPG around town doesn't seem like something to worry about. Yeah, that's may mileage all-around. Quote Link to comment Share on other sites More sharing options...
sluggo49 Posted August 7, 2019 Share Posted August 7, 2019 My '98 carbed 'Bird gets somewhere between 35 to 40 mpg. Very little in-town riding and I mostly ride 2 lane twisty asphalt at a moderate pace. Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted August 7, 2019 Share Posted August 7, 2019 180 to 190 on average before blinking and even then got a gallon or so left. Quote Link to comment Share on other sites More sharing options...
jon haney Posted August 8, 2019 Share Posted August 8, 2019 21 hours ago, The Krypt Keeper said: 180 to 190 on average before blinking and even then got a gallon or so left. I think we have a winner. I got 192 miles on a tank once in Colorado (hauling ass), but never more than 160 in KS riding like a grandpa. Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted August 9, 2019 Share Posted August 9, 2019 Depends on my area of riding, this is all on 87 ethanol fuel. Motorcycle trip with a buddy, 51mpg stock gearing, saddlebags, tail bag and my 240lb butt. Then also done 100 miles and had gauge blinking after a few strolls through the favorite mountain roads in 2nd gear. Quote Link to comment Share on other sites More sharing options...
srideaux Posted August 9, 2019 Share Posted August 9, 2019 Really,.........MPG, who cares, if it starts and runs as it should and the lo fuel indicator get you safely to the next station. I am retired now but I was in the car business for over 40 years so I road tested a lot of cars with customers, when I got into a Corvette, with a prospective buyer, if one of the questions was " what kind of mileage will it get " its more the ride than the economy I have even told them this may not be the car for you! MPG never sold a Black Bird or a Corvette.........Just my 2 cents worth. 1 Quote Link to comment Share on other sites More sharing options...
srideaux Posted August 9, 2019 Share Posted August 9, 2019 And yes , They are very sensitive to Fuel quality. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted August 10, 2019 Share Posted August 10, 2019 I agree with that but if someone is getting very poor mileage on a mostly stock bike without running it hard, it may be a signal that something is wrong. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted August 10, 2019 Share Posted August 10, 2019 What year is it? Quote Link to comment Share on other sites More sharing options...
googus Posted August 11, 2019 Author Share Posted August 11, 2019 2003 Quote Link to comment Share on other sites More sharing options...
XXitanium Posted August 11, 2019 Share Posted August 11, 2019 Ok, so fuel injected. (I guess FPR should have clued me that it is FI) Quote Link to comment Share on other sites More sharing options...
thx113 Posted September 4, 2019 Share Posted September 4, 2019 350 to 420 km country riding. Just cruising at the speed limit of 110. Quote Link to comment Share on other sites More sharing options...
googus Posted September 5, 2019 Author Share Posted September 5, 2019 I was just about to post a follow up. Two tanks of none- ethanol 89 octane at $2.89per gal. Both times went 15 or so miles when bar started to blink both times at 179miles and filled up with 4.8 gallons. A consistent 37miles to the gallon with more or less same riding conditions. That is an increase of 4mpg. The big question is it worth .80more a gallon. Quote Link to comment Share on other sites More sharing options...
OMG Posted September 5, 2019 Share Posted September 5, 2019 (edited) I was looking at fuel milage on the site Fuelly and it seems that motorcycles, from 750 up to 1800"s get somewhere between 35 and 45 mpg No matter what brand. The only exception is the honda NC700 and 750 at 70mpg Gotta be a conspiracy I tell Ya ! My sons Honda Fit gets 35 to 45. Edited September 5, 2019 by OMG Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted September 5, 2019 Share Posted September 5, 2019 (edited) 12 hours ago, googus said: I was just about to post a follow up. Two tanks of none- ethanol 89 octane at $2.89per gal. Both times went 15 or so miles when bar started to blink both times at 179miles and filled up with 4.8 gallons. A consistent 37miles to the gallon with more or less same riding conditions. That is an increase of 4mpg. The big question is it worth .80more a gallon. Easy math, it costs you 1.5 pennies more per mile to use the 'better' gas. Edited September 5, 2019 by superhawk996 Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted September 5, 2019 Share Posted September 5, 2019 10 hours ago, OMG said: Gotta be a conspiracy I tell Ya ! My sons Honda Fit gets 35 to 45. Just a guess, but I'll bet the Fit doesn't make 130hp/liter or do 0-60 in under 4 seconds. Quote Link to comment Share on other sites More sharing options...
OMG Posted September 5, 2019 Share Posted September 5, 2019 1 minute ago, superhawk996 said: Just a guess, but I'll bet the Fit doesn't make 130hp/liter or do 0-60 in under 4 seconds. True But what difference should that make? The amount of energy required to move an object should be the same or similar regardless of the power potential. And that is something that has always puzzled me, Blackbird 35mpg - Harley 35 mpg - Honda Fit 35mpg Drag racing - well, that's different. Quote Link to comment Share on other sites More sharing options...
