1997 hydrolocked? Not. Update on latest post
Dotetcher
I wonder if some of the float are stuck in the up position not letting the fuel fill the bowls?
Quote
Very partial turnover then nothing. Hit the starter and it sounds like its engaging but motor does not turn over.
Make sure you are working with a strong battery because even though it is turning over, I have found that my bikes get harder to start when the battery gets weak.
Edited by blackhawkxx
  • Useful/Thanks! 1
1 hour ago, XXitanium said:
Step away for a bit.
Do you have an owners manual
Stepped away for the rest of today. Re-watching Altered Carbon on Netflix.
I have the factory Service manual.
Next time I get into it I'll try tapping the carbs.
Thank you.
I'm running cables to my jeep for good juice. Once the battery runs down that is. I've got the battery back on the Tender. Brand new battery last year. It's been sitting on the Battery Tender all winter.
Mouth suction is more than enough to open it, it doesn't take much.  If the gas isn't super old, my guess is that the carbs need cleaning.  The fact that it's trying to start says that it's very unlikely to be a battery problem.
  Good first season.  Officer Ortega will definitely take your mind off your troubles.😜
Will the engine rotate a full revolution by hand?
...scratches head, waddles off to Google..
I tried watching it. The first couple episodes didn't have a hook. I may need to revisit that.
SPOILER ALERT!
Don't remember what episode, but we do get to see her completely naked and "doing" the main character.
Edited by jon haney
  • Useful/Thanks! 1
Yes. Just won't fire now. Occasional pops and backfires while cranking. Gonna check the carbs but uncovering the boat first. Striper season here in communist state of NY. So many hobbies, so little time. :)
Posted (edited)
I bought a K&N. $30 more but it’s being delivered tomorrow morning by Amazon. The little spongy breather filter I’m gonna make myself. Going to cut the yellow part off one of these kitchen sponges and use the green Part and cut it to size.
Edited by Dotetcher
9 hours ago, Dotetcher said:
Got the boat running so I figured I’d take another delve into this. Think this has anything to do with it? 🙂
While I don't like the OEM media delete, I do like that you've added a lot of additional filter media.  Way better filtration than a K&N, probably under 1 micron!
  • Haha 1
Posted (edited)
Running. A little rough in lower RPMs but still a major kick in the rear end at around seven grand. As usual Gentlemen thank you for all the help and the encouragement to keep going. It is very much appreciated.
Edited by Dotetcher
6 hours ago, Dotetcher said:
Do you guys use any carb cleaner additives? And are they successful?
I like Seafoam. Were those peanuts in the picture of the inside of the airbox? Guessing your bike lives outdoors?
  • Like 1
