XXitanium Posted April 21 Share Posted April 21 Step away for a bit. Do you have an owners manual 1 Quote Link to comment Share on other sites More sharing options...
tomek Posted April 21 Share Posted April 21 (edited) Nevermind Edited April 21 by tomek Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted April 21 Share Posted April 21 (edited) I wonder if some of the float are stuck in the up position not letting the fuel fill the bowls? Quote Very partial turnover then nothing. Hit the starter and it sounds like its engaging but motor does not turn over. Make sure you are working with a strong battery because even though it is turning over, I have found that my bikes get harder to start when the battery gets weak. Edited April 21 by blackhawkxx 1 1 Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted April 21 Share Posted April 21 You could try tapping the carbs to loosen things up if they are sticking. Quote Link to comment Share on other sites More sharing options...
Dotetcher Posted April 21 Author Share Posted April 21 1 hour ago, XXitanium said: Step away for a bit. Do you have an owners manual Stepped away for the rest of today. Re-watching Altered Carbon on Netflix. I have the factory Service manual. Next time I get into it I'll try tapping the carbs. Thank you. 1 Quote Link to comment Share on other sites More sharing options...
Dotetcher Posted April 21 Author Share Posted April 21 48 minutes ago, blackhawkxx said: I wonder if some of the float are stuck in the up position not letting the fuel fill the bowls? Make sure you are working with a strong battery because even though it is turning over, I have found that my bikes get harder to start when the battery gets weak. I'm running cables to my jeep for good juice. Once the battery runs down that is. I've got the battery back on the Tender. Brand new battery last year. It's been sitting on the Battery Tender all winter. Quote Link to comment Share on other sites More sharing options...
tomek Posted April 21 Share Posted April 21 Have you tried starting fluid? Quote Link to comment Share on other sites More sharing options...
XXitanium Posted April 22 Share Posted April 22 Clean and tighten the terminals. Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted April 22 Share Posted April 22 Mouth suction is more than enough to open it, it doesn't take much. If the gas isn't super old, my guess is that the carbs need cleaning. The fact that it's trying to start says that it's very unlikely to be a battery problem. Quote Link to comment Share on other sites More sharing options...
jon haney Posted April 22 Share Posted April 22 22 hours ago, Dotetcher said: Stepped away for the rest of today. Re-watching Altered Carbon on Netflix. Good first season. Officer Ortega will definitely take your mind off your troubles.😜 Will the engine rotate a full revolution by hand? Quote Link to comment Share on other sites More sharing options...
XXitanium Posted April 22 Share Posted April 22 4 hours ago, jon haney said: Officer Ortega will definitely take your mind off your troubles.😜 ...scratches head, waddles off to Google.. I tried watching it. The first couple episodes didn't have a hook. I may need to revisit that. Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted April 23 Share Posted April 23 9 hours ago, XXitanium said: Why not both? 2 Quote Link to comment Share on other sites More sharing options...
jon haney Posted April 23 Share Posted April 23 (edited) 18 hours ago, XXitanium said: ...scratches head, waddles off to Google.. I tried watching it. The first couple episodes didn't have a hook. I may need to revisit that. SPOILER ALERT! Don't remember what episode, but we do get to see her completely naked and "doing" the main character. Edited April 23 by jon haney 1 1 Quote Link to comment Share on other sites More sharing options...
Furbird Posted April 23 Share Posted April 23 That's not a spoiler, that's an advertisement! 1 2 Quote Link to comment Share on other sites More sharing options...
Dotetcher Posted April 26 Author Share Posted April 26 On 4/22/2024 at 2:48 PM, jon haney said: Good first season. Officer Ortega will definitely take your mind off your troubles.😜 Will the engine rotate a full revolution by hand? Yes. Just won't fire now. Occasional pops and backfires while cranking. Gonna check the carbs but uncovering the boat first. Striper season here in communist state of NY. So many hobbies, so little time. Quote Link to comment Share on other sites More sharing options...
Dotetcher Posted April 28 Author Share Posted April 28 (edited) Got the boat running so I figured I’d take another delve into this. Think this has anything to do with it? 🙂 Edited April 28 by Dotetcher 3 1 Quote Link to comment Share on other sites More sharing options...
Dotetcher Posted April 28 Author Share Posted April 28 Also what material are you guys using to replace 17254-MAT-000. Discontinued. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted April 28 Share Posted April 28 Maybe these? https://www.jpcycles.com/product/hiflofiltro-air-filter-hfa1910-honda?sku_id=10235045 https://www.ebay.com/itm/284475740941 Quote Link to comment Share on other sites More sharing options...
Dotetcher Posted April 28 Author Share Posted April 28 (edited) I bought a K&N. $30 more but it’s being delivered tomorrow morning by Amazon. The little spongy breather filter I’m gonna make myself. Going to cut the yellow part off one of these kitchen sponges and use the green Part and cut it to size. Edited April 28 by Dotetcher Quote Link to comment Share on other sites More sharing options...
Furbird Posted April 28 Share Posted April 28 Yep, that might do it. I'm surprised it didn't stink to high heaven. I think all my birds have K&N's. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted April 29 Share Posted April 29 So the carb area is clean? You might want to look around to see if any wires are chewed also. Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted April 29 Share Posted April 29 9 hours ago, Dotetcher said: Got the boat running so I figured I’d take another delve into this. Think this has anything to do with it? 🙂 While I don't like the OEM media delete, I do like that you've added a lot of additional filter media. Way better filtration than a K&N, probably under 1 micron! 1 Quote Link to comment Share on other sites More sharing options...
Dotetcher Posted April 29 Author Share Posted April 29 (edited) Running. A little rough in lower RPMs but still a major kick in the rear end at around seven grand. As usual Gentlemen thank you for all the help and the encouragement to keep going. It is very much appreciated. IMG_3692.mov Edited April 29 by Dotetcher 1 Quote Link to comment Share on other sites More sharing options...
Dotetcher Posted April 29 Author Share Posted April 29 Do you guys use any carb cleaner additives? And are they successful? Quote Link to comment Share on other sites More sharing options...
TOXXIC Posted April 29 Share Posted April 29 6 hours ago, Dotetcher said: Do you guys use any carb cleaner additives? And are they successful? I like Seafoam. Were those peanuts in the picture of the inside of the airbox? Guessing your bike lives outdoors? 1 Quote Link to comment Share on other sites More sharing options...
