Zz want’s an XX Posted December 8, 2020 Share Posted December 8, 2020 Hello everyone! Looking to get a replacement chain and sprocket set for my 02. Figured I’d start here! Any recommendations on gearing or product choice would also be welcome! 1 Quote Link to comment Share on other sites More sharing options...
poida Posted December 9, 2020 Share Posted December 9, 2020 when the exchange rate was better between U.S and AUS i used to get my kits from sprocket centre.D.I.D zvmx chain and pretty sure i would get the JT sprockets .i always run the standard gearing although the gearing on the U.S bikes are i believe different to ours. Quote Link to comment Share on other sites More sharing options...
RXX Posted December 9, 2020 Share Posted December 9, 2020 A lot of us are partial to 18T front sprocket. I have always gotten DID 530VX3. And you can never, ever go wrong splurging for a pro-oiler. Pays for itself in 30,000 miles. Welcome aboard. Your dad is a standup guy. Quote Link to comment Share on other sites More sharing options...
Zz want’s an XX Posted December 9, 2020 Author Share Posted December 9, 2020 28 minutes ago, poida said: when the exchange rate was better between U.S and AUS i used to get my kits from sprocket centre.D.I.D zvmx chain and pretty sure i would get the JT sprockets .i always run the standard gearing although the gearing on the U.S bikes are i believe different to ours. Thanks for the info! I wonder why there would be a difference between gearing? Quote Link to comment Share on other sites More sharing options...
Zz want’s an XX Posted December 9, 2020 Author Share Posted December 9, 2020 22 minutes ago, RXX said: A lot of us are partial to 18T front sprocket. I have always gotten DID 530VX3. And you can never, ever go wrong splurging for a pro-oiler. Pays for itself in 30,000 miles. Welcome aboard. Your dad is a standup guy. Thanks for the welcome! Proud to be following in his foot steps! Wouldn’t mind a oiler, good idea! Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted December 9, 2020 Share Posted December 9, 2020 37 minutes ago, Zz want’s an XX said: Thanks for the info! I wonder why there would be a difference between gearing? I believe the difference is that the other countries got a one tooth smaller rear, 44 instead of 45 I think. I don't know why, but it supposedly makes the speedo closer to accurate and maybe that's the reason. Common here is to use the stock US rear with a 16 front for more acceleration, 17 to stay stock, or 18 for better highway MPG and lower RPM. The stock one has a vibration damper in it and many say it makes a noticeable difference. Someone recently posted a link to a company that offers all three with the damper. I don't think anyone can tell you what size sprockets are best since the advantages/disadvantages come down to your use and your liking. If you do mostly street and want more git up & go a smaller front might suit you. If you want lower RPM cruising a bigger one might suit you. Before putting too much thought into it you should confirm what is currently on the bike, it could already be re-geared without you knowing it. If you have no desire to have a different experience, get a new set of the existing. The only thing I'll suggest is to stick to a damped front sprockets instead of the 'normal' type. Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted December 9, 2020 Share Posted December 9, 2020 Okay. Bottom line, its your choice as to what works for you. 17/45 is stock gearing. I've heard the Aussies mention that they had an option of 44 or 45 from the dealer, maybe it was a "dealer installed" option. Why a smaller rear sprocket? Have you ever been to Australia? It makes eastern Washington look overpopulated. Making gas last 20 more miles is really a good thing. Anyway, as has been said, lots of folks go up or down a tooth on the front rather than change the rear. Remember, one tooth on the front equals three on the rear sprocket. My advice is to go with stock and the dampened (factory) front sprocket. The OEM rear sprockets wear like the good steel that they are. You may not need them. I've run all three front sprockets at the dragstrip, 16, 17, and 18. The 16 was the slowest as I had to back off a little at the start for to keep the front end down. 17 ran out of revs, 18 suffered the extra shift, so they came out the same. I'm not fast, between 10.5 and 11.0 if I had a good day I've run 18 tooth in the more recent years. That includes two up with luggage on tight switchbacks, the bike will pull the extra gear. That's probably 300 pounds more than you if your picture is recent. Right now, I have an 18 tooth front with a 44 rear. Its smooth, quiet, clutches off fine, but backroad passing lunges need three clicks down, not two, and it doesn't have that instant pull at highway speeds that is so nice. Lastly, an 18/45 combination puts your speedo right on the money. But your odometer will be off and you'll have to adjust that before you can figure your actual gas mileage. Or just wonder why you suddenly went from 45 to 38mpg. I've always used DID Xring chain on the XX when I could afford it. There are stronger versions, the 9800 lb rating of the stock chain is good enough unless you have engine mods, track every weekend, or ride like a dickhead. Stronger chains are heavier and add weight where you don't need it. Search the online motorcycle sites and ebay/amazon for deals. Don't search for an XX, just search for DID chain. Stock sprocket chain length is 115 links. Its not uncommon to find something that's longer for less money. Just cut off the extra and throw it in a box because someday, if you're like me, you will get a brand new chain for free...you'll just have to get 11 new master links. 1 1 Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted December 9, 2020 Share Posted December 9, 2020 2 hours ago, rockmeupto125 said: Stock sprocket chain length is 115 links. Is it required, or desirable, to change the chain size for going up/down one tooth at either end? Personally I think I'd like an 18. I haven't tried it, but I like to keep the revs down and an 18, maybe even 18/44 like you have, would reduce upshifting around town. Somewhere I found a chart that showed ideal and bad combinations back when I was looking to re-gear one of my 999s. There's stuff that happens with combining tooth counts, something about how often the same tooth hits the same link or something like that. It supposedly effects wear and noise. On one of them I went from the stock 530 to a 525, the weight difference was pretty big. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted December 9, 2020 Share Posted December 9, 2020 15 tooth for wheelies... But my favorite was one down, by far, for everyday riding and trips. The motor is smooth so there's no reason to fear a little more RPM. Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted December 9, 2020 Share Posted December 9, 2020 22 minutes ago, superhawk996 said: Is it required, or desirable, to change the chain size for going up/down one tooth at either end? Somewhere I found a chart that showed ideal and bad combinations back when I was looking to re-gear one of my 999s. There's stuff that happens with combining tooth counts, something about how often the same tooth hits the same link or something like that. It supposedly effects wear and noise. I never had to change the chain going to 18 or 16. Regularity/irregularity with different combination is a concept I don't recall ever considering. Interesting point. I have a hard time imagining it would make a difference in the real world, but if you're racing for a world championship, or building a chain drive spaceship, might be something worth considering. Quote Link to comment Share on other sites More sharing options...
CBR-RR-XX-CESS Posted December 9, 2020 Share Posted December 9, 2020 31 minutes ago, SwampNut said: 15 tooth for wheelies... But my favorite was one down, by far, for everyday riding and trips. The motor is smooth so there's no reason to fear a little more RPM. Never tried a 15 as I'm a solid 16 lover. Love the increase acceleration out of corners. You guy's who run a 18 should just buy a Goldwing. ( Calcxx) 1 Quote Link to comment Share on other sites More sharing options...
CALCXX Posted December 9, 2020 Share Posted December 9, 2020 (edited) Jeff and I have not agreed on this gearing choice for 15+ years. I have had an 18T since about 2004. I bought a 16t and didn't like it so I gave it to Jeff some 15 years ago. He said it reminded him of his 954rr. I will admit that I lost a small amount of acceleration. What did I gain? A bike that loafs at 90mph. A speedometer that is on the money. An engine that's not sceaming it's lungs out at 100 or maybe it's just 71mph with the new 16t speedo error? Long winded 2nd gear that goes all the way to a true 105mph. About 20 more miles per tank of gas. It will still do clutchless wheelies in 1st gear. Chains should last longer bending less thru the radius. 18t is the way to go. Jeff, you should buy a 15T. Take off in third from a stop sign and do 4th gear clutch wheelies at 100 indicated or should I say 47 mph? Edited December 9, 2020 by CALCXX Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted December 9, 2020 Share Posted December 9, 2020 I think I hit 70mph in 1st gear a couple weeks ago.....because I could. 😊 3 Quote Link to comment Share on other sites More sharing options...
SwampNut Posted December 9, 2020 Share Posted December 9, 2020 1 hour ago, CALCXX said: Jeff and I have not agreed on this gearing choice for 15+ years. I have had an 18T since about 2004. I bought a 16t and didn't like it so I gave it to Jeff some 15 years ago. He said it reminded him of his 954rr. I will admit that I lost a small amount of acceleration. What did I gain? A bike that loafs at 90mph. A speedometer that is on the money. An engine that's not sceaming it's lungs out at 100 or maybe it's just 71mph with the new 16t speedo error? Long winded 2nd gear that goes all the way to a true 105mph. About 20 more miles per tank of gas. It will still do clutchless wheelies in 1st gear. Chains should last longer bending less thru the radius. 18t is the way to go. Jeff, you should buy a 15T. Take off in third from a stop sign and do 4th gear clutch wheelies at 100 indicated or should I say 47 mph? Blah blah blah. Homo. Quote Link to comment Share on other sites More sharing options...
CBR-RR-XX-CESS Posted December 9, 2020 Share Posted December 9, 2020 1 hour ago, CALCXX said: A bike that loafs at 90mph. Loafs- Goldwing and anything over 90mph while loafing is dangerous. I think you had a group of wingers tell you how unsafe you were. Giggle, giggle Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted December 9, 2020 Share Posted December 9, 2020 7 hours ago, rockmeupto125 said: Stock sprocket chain length is 115 links Phil just went through the chain thing before his trip. He came out with 110 links. Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted December 9, 2020 Share Posted December 9, 2020 You are correct, I'm typing through a foggy mind. Thank you for catching that. Stock chain length is 110 links. Quote Link to comment Share on other sites More sharing options...
RXX Posted December 11, 2020 Share Posted December 11, 2020 I can give my opinion, again: BB1 had an 18T front for prolly 45,000 of it's last miles before I parked it. BB2 had a 17T on it when I got it a couple years back. Man, every time I got on a highway I just hated how high it revved. Before my last trip I scavenged the sprocket from BB1 and all was well with the world. Now I am not the type of guy who stsys in tune with my bike, but I didn't notice any difference between the two vis a vis the damper thingy. I had to get used to starting off in 1st, especially going uphill. Quote Link to comment Share on other sites More sharing options...
TOXXIC Posted December 12, 2020 Share Posted December 12, 2020 I do miss 16T wheelies. Can only imagine how much fun 15T front sprocket would be! Quote Link to comment Share on other sites More sharing options...
Furbird Posted December 12, 2020 Share Posted December 12, 2020 Jeez, even a chain and sprocket thread starts a war. I've run 16/45 on the street bike forever. Seriously, changed it over at the first oil change, along with a full D&D system. Steel ONLY, no issues (although the adjusters do end up a pretty good ways in the red even when the stock chain is still good so you can forget using that as your "replacement guideline.") Drag bike ran 12/49 for a weekend, was in 6th in the 1/8th! Wheelie bars because you could not keep it down. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted December 12, 2020 Share Posted December 12, 2020 7 hours ago, Furbird said: Jeez, even a chain and sprocket thread starts a war. I've run 16/45 on the street bike forever. Seriously, changed it over at the first oil change, along with a full D&D system. Steel ONLY, no issues (although the adjusters do end up a pretty good ways in the red even when the stock chain is still good so you can forget using that as your "replacement guideline.") Drag bike ran 12/49 for a weekend, was in 6th in the 1/8th! Wheelie bars because you could not keep it down. I don't see it as a war, just everyone throwing in their two cents. For me, 16/46. 1 Quote Link to comment Share on other sites More sharing options...
OMG Posted December 14, 2020 Share Posted December 14, 2020 On 12/12/2020 at 2:44 PM, blackhawkxx said: throwing in their two cents or teeth Quote Link to comment Share on other sites More sharing options...
