Pretty sure that the same one I have, and pretty sure it's because of the same sale Blackhawk posted about. I stopped the video early when he said that setting 1 is the most powerful, it's the least. From some quick testing, don't rely on this; setting 1 hits a little over 100 ft.lbs, 2 is a little over 200, no idea where 3 goes but it seems like it's a bigger power jump. The auto setting is pretty cool and I used it for a little while, but went back to doing it by feel in one of the other settings. I normally use 3 for removal because I'm impatient, then use 1 or 2 for installation.
I caught a blurb on the radio about how doctors are now saying that whole milk and cheese are good for you. I wonder what the current stance on eggs is, that has also run the good-bad bullshit a few times. Is bread good or bad these days? Dried meats? Fuck it, I'll order a pizza to cover all the bases.
Do you feel that going over it is truly half-assed work, or is it just more satisfying to completely re-do it? I give 0 shits about covering existing flooring that's solid, and in this case I'd consider it an upside since it would be hard to duplicate what was done. Shit, I just realized that you're going to have to fill it back in to match the level of the floor outside the bathroom. Remove all that knowing I'll have to rebuild it? Oh fucking hell no!!! But cudos to you for taking that on.....ya crazy fuck. I re-did most of my flooring and a very large portion of the house had vinyl tiles that were a mutherfucker to remove so I stopped trying. I used leveling compound where necessary around entries and laid down new vinyl.
I would have laid the new over the old, fuck all that work.
And I wound up replacing the compressor. The clutch I ordered was the wrong size. Ordering the right one online would take about a week to arrive and I didn't want to have it down that long. A clutch from the local parts store was $105, whole compressor was $170 so I went that route. One of the idler pulley bearings sounded a bit dry so I put some oil into it to make it happy for now, but will order a new one.
Wear, or too much air gap, is always the cause for one not engaging when hot. Heat increases resistance so it decreases the magnetivity and eventually it can't pull the clutch plate because it's too far away. The quick fix is to give it a tap with the AC on to get it to grab, but next time it cycles off you're stuck again. The longer term fix is to reduce the gap, I've done this on a few. If you take the center screw off and remove the plate there's a shim/small washer between the plate and compressor clutch. You can sometimes just remove it, but sometimes that'll make it too tight and you'll need a thinner shim.
It's Ford brand so it might have been original.
I coulda just re-greased the bearing, but I decided to splurge on a new clutch kit. It's a two row bearing, one row was empty. After pulling it off the rest of the balls fell out. It was so screwed up that I assumed the snout of the clutch was going to be damaged from the bearing overheating/slipping on it, but it's fine so the compressor will live on.
You could drink a gallon of Folger's and possibly still be below Carlos's 'cup' of coffee per day.
Well, I still haven't had the tires replaced, I'm contemplating the options. Ashely recently got into decorative embroidery, with a little practice and stronger hands she could sew the tires back together. If only dad was still alive to give her some pointers I'd be free from Big Tire.
According to the tire guy; aligning the balance dots with the stems does nothing and tires don't loose balance over time, if there's a vibration, something's wrong. When they mounted the motorhome tires I told the guy mounting them to please align the dots and he did, but he had a helper do some of them and he didn't. There was a noticeable difference in the amount of weights needed, one of the aligned tires took Zero weight, one of the misaligned nearly drove them into bankruptcy. I showed the boss, he's the "tire guy" I've been referring to, he seemed unimpressed. Whenever they mount new tires I ask them to align the dots and they typically require minimal weight despite usually being cheapo tires.
When the compressor fails, no biggie, you just loose AC. In this case the pulley bearing appears to be fucked up. When it's rattly/crunchy and shooting sparks out of it that's usually a bad sign. Luckily the engine is so rattly I can't hear the pulley from inside so all's good. And after oiling it the smell of molten metal went away.
The Ex sits for weeks/months at a time, possibly a contributing factor. The guy at the tire shop said short life is a common issue with commercial tires. These say commercial on them, but I assume it's marketing hype for cheap tires. He has said a couple other things about tires that I know are false so-?
4 new tires, I'd already replaced one. It's right on top, pretty easy. I haven't priced it yet, but guessing 100-150 from my rebuilder.
Yea, his water pump went out on the only meet I went to. I've made a bunch of AZ trips without any issues, this trip happened to pack several issues in.
Q: How long after your AC clutch/pulley starts showing signs of issues does it take a total shit? On my way to AZ Thursday the AC suddenly stopped working right after my second stop to change a trailer tire...ugghh. It was only about 105 degrees 😑 Next day it seemed to be working fine so I figured I'd overcharged it and when the temp got high enough it was kicking off the clutch. Today on my way home as the temps hit about 100-102 it stopped again so I planned on letting some refrigerant out at my fuel stop. I popped the hood with the engine running to see if the clutch was cycling and it wasn't, but it was making a fun show of noise and sparks, even with the AC off. I dribbled some oil into both ends hoping it would help get me close enough to home for my free towing coverage and motored on. The temp got to 115 according to the gauge, but it didn't actually feel as horrible as it sounds. I made two more stops along the way, one to swap a front tire that was threatening to come appart, and I dribbled a bit of oil into the pulley each time. No idea if it got to where it needed to be to help anything, but I figured it would't make things worse....other than maybe catching fire then the insurance company would have to deal with it. It made it home, really surprised the bearing didn't seize/disintegrate along the way. The other front tire started wobbling not terribly long after the first one, it also made it home. Cheap tires, not a lot of miles, but 7 years old; I guess it's time.
Yes. Coolant doesn't cool as well as water so as the ratio becomes higher in coolant you loose cooling efficiency. A somewhat surprising effect; the water pump in my SuperHawk started leaking after I accidentally mixed the coolant a bit on the rich side, as I topped it back off with water the leak slowly went away. I never got around to checking the percentage when it stopped leaking, would have been interesting to know.
Eat meat and live the longest.
superhawk996 replied to blackhawkxx's topic in Diet & health exchange
Well, duh. Everyone knows that humans do best on meat based diets. I really have no clue what the truth is, or whether there even is a truth. To know if meat is the secret to their good health we'd have to know how their animals are treated compared to ours, how they're generally cooked compared to us, as well as the many factors in their average daily lives vs. ours, and whether they have natural attributes that make their bodies want meat more than ours. Too much BS, eat what works for you. -
Clocks, Clusters, Dash, Gauges, Speedo...
superhawk996 replied to rockmeupto125's topic in The Sales Floor -- For Sale/Wanted
Oooh, yea. The belt sander did an ok job of scuffing away the chicken strips, the heat gun should finish off the look. -
I'm guessing that every 'normally sourced' food product is full of fuckery. Farming of plants is full of fuckery, and it's part of the reason Salton Sea has become such a threat.
Motorcycle oil thread, because it's been too long.
superhawk996 replied to superhawk996's topic in The Garage
He calls two stroke oil "additive" so don't expect him to call the valve cover a valve cover. -
Did you plan to do 8k on the oil or was it something that got forgotten about or put off? It doesn't seem to have done harm, but I'd be leery of doing it. -
If you're buying a new OEM control there's no need. If you buying one of the questionable Chinese knockoffs, it might be a good idea.
