All Activity
- Today
Not DI. I will try new ignition stuff. Thanks.
Outmotoring has an ignition set they just started advertising. Includes coil pak. It has been probably 10 years since I last replaced one. Thanks, will try that next week.
Is it DI or port injection? I doubt the injectors could do anything to cause a tick. If the motor's really worn the imbalance caused by a misfire might cause ticking, but I don't think I've ever experienced it. If it's DI and the intake valves are gunked up and leaking they might be able to cause a tick/chirp type noise along with a misfire.
I don't think first and second part of your post are related. First looks like hydraulic lash adjuster/ lifter whatever you wanna call issue Second, it would be, obviously, fuel or ignition. I won't elaborate any further because I'm totally unfamiliar with your Mini. Maybe just throw on it fresh set of spark plugs and ignition coils. Not that expensive.
For the last year or so my MINI has a loud single tick on cold startup. EVERY ONCE IN A WHILE. It goes completely away in about a minute or two, by the time I get out of my neighborhood. I assume an injector is getting sticky. The car is my daily driver, but one week a month it sits at my office when I am driving a “call” car. Last week I got in after a week on call and started driving home. It was missing on one cylinder. It did not go into limp mode so I said fuck it and kept on driving. About a mile out it cleared. Is this an obvious bad injector? 278,000 miles on not top-tier ethanol free premium gas. I run Techron through it every few thousand miles. Should I try to clean it or replace it? Probably will DIY. Should I replace them all (fuckers are pricey)?
My test was sufficient for needs outside of air/spacecraft. I measured it a few months apart against the other torque wrench. I know exactly how that can be problematic but was simply looking for repeatability/change and really don't care about ultimate precision.
- Yesterday
TOXXIC started following All about torque wrenches
+1 as in send it out for calibration. The Prime Air team that was building drones had theirs sent out every Friday for calibration....FAA and all....maybe Boeing should have been as methodical.
If it can roll away, they can take it in seconds. Don't matter how good, or how many locks you put on it. Meth-heads will even steal worthless crap, if not tied down. Parking boot and/or 3/8" grade 8 chain tied to something not easily cut or broken. A "dead-man" anchor screwed into the ground just at the edge of the pavement should do it. Secure that with the biggest, hard-to-cut locks you can find. Then install a motion sensor on that brick wall. Then you'll know when the fuckers try anyway, and you can go out and shoot beat the shit out of those fuckers. ANYONE WANT TO TRY TAKING MY TRAILER?
More importantly; what color? Black is typically the most sun resistant, but it'll convert sunlight into lots of heat and possibly fatigue the metal. White will reflect the heat better, but degrade faster. Both will trap moisture. A silver tarp perhaps, with appropriate strapping of course. Loosely bound with another fan to prevent moisture damage? I really need to reassess my stupid method of just throwing random old tarps over mine. I thought it was enough, but it's only been a couple decades and the scrap plywood I used as decking is already showing serious signs of age.
Have you not seen the lock picking thread in the pub? Don't trust a common padlock to secure that trailer, people would spin it and either pop that lock in seconds or just hook up the chains and haul ass. Look into a trailer ball hitch lock system. Some are better than others and even help lock up the safety chains.
- Last week
How many mils thick should the bag be? What's the best way to secure it? If there's excess bag flapping around in the wind it might make too much noise. Is there a good website where garage bags are compared? It's got to be current up to date info though as garage bag data from last year or older is useless. He'd probably have to buy a whole box of bags even though only one is needed and that's how they get you...big garbage bag corporate conspiracy.
Seriously, I would just throw one of those contractors/garden huge garbage bag over tow bar.
And now those safety chains are rusted! The strength is compromised. You should remove those and store safely some place warm and dry. Properly clean, heat and oil-quench to restore. Better yet, start over, buy a new set. Those cannot be trusted. They look on the small side anyway. Do better research to make sure the new set is properly sized. I hear they make them in stainless…. Oohhh wait…does stainless have the same tensile strength as regular, zinc-plated?? Oh shit….more research……
Again. Tow bar not protected. Epic fail.
But that won't stop the bugs and rodents from making a new home. Hopefully the wires have synthetic insulation and will only get a few nibbles instead of being eaten.
We care are else there wouldn't be 12 pages, right? BTW- good job. There's more than one way to skin a cat.
Yeah but that's gonna really hold in the moisture underneath. It's probably already rotting the boards, rusting the frame and compromising the wheel bearings. I think maybe rigging up a fan system to create proper airflow would be a good idea.
'03 Yoshimura 4-1 stainless full exhaust-$250
XXitanium replied to Warp11XX's topic in The Sales Floor -- For Sale/Wanted
nice repair. I sent the pics to No. 2 son. -
Warp11XX replied to Warp11XX's topic in The Sales Floor -- For Sale/Wanted
Sooo....thanks to charliethepenismarks1704, I now have pics and the RS-3 system is boxed and ready to travel....wherever it may be called upon to go... I replaced the missing rivet with one having a slightly smaller head...pretty unnoticeable.... -
Heads up on email address charliemarks1704@gmail.com He is a scammer that strung me along for over a dozen emails and then tried to get me to make changes to my PP to "receive" his payment. Dirty bastard he is!! Carry on....😐 -
eBay PC800 Pacific Coast
XXitanium replied to XXitanium's topic in The Sales Floor -- For Sale/Wanted
https://fortmyers.craigslist.org/lee/mcy/d/north-fort-myers-1996-honda-pc-800/7737780801.html -
You'd only know if you tested it.
Carlos doesn't know it, but I sabotage his torque wrenches when I'm there. If it's not at 0 I correct it. Maybe a high quality torque wrench spring won't sag like their tester did, but I won't chance it.
https://www.facebook.com/reel/1819108008581992?mibextid=rS40aB7S9Ucbxw6v
