OMG
I need a switch
Enlisting the collective wisdom and experience of the group, I am needing a button or some such switch to operate an accessory horn on a motorcycle.
Not wanting to use the existing horn button, this will be a separate add on.
Not much I can say about it right now except it will be loud and be whatever sound you want.
Just need the button.
Share this post
Link to post
Kill switch - perfect
Could you use a 137 DB horn on your Jeep?
Share this post
Link to post
May be a hijack, but I installed a Stebel Nautilus http://www.stebel.it/stebel/products.asp?IDserie=14&uso=1&tipologia=moto on my bird and used existing horn switch. Installation requires a relay, but otherwise pretty straight forward. It is the primary horn, the OEM is now a paperweight somewhere.
Share this post
Link to post
No, definitely not.  Actually, I'm not sure if the horn button works.  Have never used it.  But it beeps when I arm/lock it, and it's already too loud.
Shit, I guess I should check the bike horn too.  We're not NY, we don't use the horn here.
Share this post
Link to post
We don’t use the horn either in NY. We use a middle finger :)
Share this post
Link to post
I use it pretty regularly, mostly for people playing with their phone sitting at a green light.  And for the Asian that's stopped or crawling down the road trying to figure out where they are/where they're going.  I often wish I had an air horn to really wake them up, 137db electric might work too.
I ran across a 'history of the car horn' thing that said Klaxon was the first electric car horn and he was inspired by driving in NYC....apparently the trend stuck.
Share this post
Link to post
I haven't horn shopped in a long time, but prices seemed to vary wildly.  How much was this one?
Share this post
Link to post
My F250 horn has not worked for years. I like that I just hear the locks click when I push the button on the fob. If I get home in the middle of the night, if the diesel clattering up the road doesn't wake them, neither does the horn alarm.
Share this post
Link to post
None of my Fords honk when I lock unless I do a double tap.  I like that set-up.
Share this post
Link to post
I've avoided more accidents with my horn than my brakes. In driver's ed they teach you to "cover the brake" in certain situations, I've found that covering the horn is just as useful. When you see someone about to do something stupid, a quick tap of the horn usually gets their attention enough to correct them before shit gets out of hand.
Share this post
Link to post
I've only found myself in those situations maybe twice.  Now I just observe it, move/slow, and just avoid it.  I'm pretty certain I haven't touched the horn in either Jeep.
I can turn it off, but I'm usually walking away and want the confirmation.  Double tap on the Jeep disables the alarm, lock only.
Share this post
Link to post
It seems like anything with a compressor and no tank/valve would take a bit to spin up and get loud.
Share this post
Link to post
The reviews on that second one aren't confidence inspiring.
Share this post
Link to post
Posted (edited)
Looking at reviews has convinced me to skip any of the above listed horns on Amazon!
I bought one of these and mounted it on the Yamaha FJR1300 using the stock hardware.
easy unplug and unbolt, swap horns and rebolt and plug in, done
Not super load but a big improvement on the stock meep-meep sound.
A plus that the name is ZKXX !
https://www.aliexpress.com/item/12V-30W-Single-Sound-Auto-Car-Snail-Horn-Waterproof-Electric-Loud-Air-Siren-for-Vehicle-Motorcycle/32832228704.html?spm=2114.search0302.3.90.74981c3drKtWlX&ws_ab_test=searchweb0_0,searchweb201602_0_10130_453_454_10618_536_10890_317_537_319_10059_10696_10084_10083_10547_10546_10887_10307_321_10548_322_10065_10068_10103_10884_10545,searchweb201603_0,ppcSwitch_0&algo_pvid=9daa9489-5195-4a67-8b22-e220f5fdaa17&algo_expid=9daa9489-5195-4a67-8b22-e220f5fdaa17-11
Think I will do the same on the Civic. Was looking for something louder but everything I see is cheap made junk with bad reviews.
I miss my Nathan real train horn that I had installed on my Rideline with separate compressor and 3 gallon tank. But that was $1,500.00 in cost.
I still have the compressor and tank for some future install.
Edited by John01XX
add link
Share this post
Link to post
What will be ready this summer is small, high powered (200 amp), and will make any sound you can put onto a card in wav.
Train - ooga - horse - car crash - anything
Share this post
Link to post
Watts maybe?  So 16 amps?
Share this post
Link to post
Sorry - 200 watt amp - size of a deck of cards
Share this post
Link to post
So you have to hard-wire it to the battery with 12# wire?  Or is that "Chinese watts?"
Share this post
Link to post
Asians are math specialists, they get 200 amps from the stock 5 amp system.
Share this post
Link to post
The air horns use a rotary vane compressor, the delay is fairly negligible.
Share this post
Link to post
