Nova Scotia Mike Posted April 10, 2021 Share Posted April 10, 2021 Asking for a friend 😎  Man, this is a tough one to fess up to. Let's say I have a friend who in a drunken mishap over the winter accidentally put the Battery Tender Jr charger leads on the wrong battery poles (battery in bike, 2000 XX) and plugged the fucking charger into the wall. The bass-ackwards charger/battery made a funky humming noise immediately which the drunken idiot noticed after a short time, like less than a minute. They then unplugged the charger from the wall.  Damage done? What to check now?  Battery was then removed from bike and put on trickle charge (properly) a few times over the winter. Battery Tender Jr. would then charge it until the green light came on, like normal. Fast forward to now and the battery will not turn the engine over.  Battery is likely 4-5 years old. Dead battery? Blown fuse? Something more serious fried during drunken idiocy?  Any and all help appreciated. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted April 10, 2021 Share Posted April 10, 2021 Go to Walmart and spend the $60 already, cheap fucker.  "Will not turn the engine over" as in it tries and doesn't, or doesn't try at all? Do you have a charger with a starter mode?  Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted April 10, 2021 Share Posted April 10, 2021 Quote  SAFE AND SECURE Connect and forget with the Battery Tender® Junior! Capable of managing battery health all on its own, this charger and maintainer is equipped with reversed hook-up protection that checks for a correct connection before providing power to remain spark free. Link  It shows it having a fuse in the cord so you can look at that. I don't know what auto parts stores you have, but most here will test your battery for free. I just did it this spring when my Wing's battery crapped out. BTW- they can do it with the battery installed or carried in.     Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted April 11, 2021 Share Posted April 11, 2021 It's very unlikely that 'your friend's mistake' did a much damage to the battery. If it was a high power charger then it could, and could even let the smoke out of the battery in a boring or exciting way, but I assume a Tender JR is low power like 1-2 amps which would do very little damage if any. Quote Link to comment Share on other sites More sharing options...
FiXXation Posted April 11, 2021 Share Posted April 11, 2021 For point of reference, I keep 10 Battery Tender Plus brand smart trickle chargers (the "full sized" metal boxes) going all the time, and have for many years. If the cables are on the wrong posts, it just alternately flashes the red and green LEDs, doesn't care, and won't go any further in it's pre-charge test sequence.  Two things could have happened. First, keeping a Tender on a battery won't make the battery last forever. The battery can gradually age and allow only a surface charge over time. When in float mode, the Tender doesn't know that and thinks it's doing a good job. Second, the Tender can die and act like it's working okay, even though it's not putting out 13-14 volts to the battery. The logic voltage can survive, but not the output. This can happen if it is running through a serious power brown-out. You can connect the Tender to a good battery and monitor with a volt meter to see if, once it goes to the red LED charge mode, the battery voltage slowly rises. It has to be hooked to a battery to read the voltage because even if it is working right, it won't put any output volts on the cables unless it is satisfied the battery is there and the polarity is right.  Quote Link to comment Share on other sites More sharing options...
Nova Scotia Mike Posted April 11, 2021 Author Share Posted April 11, 2021 Thanks for all the feedback folks. Â A little more related info... Â I've been running two bikes for the last few years, the XX and a DRZ. I have and mainly use a Harley branded Battery Tender Jr. that trickle charges @ ~0.75a with an auto feature. I don't log when I charge the batteries over the winters but I try to charge each one at a time for a week or two then swap to the other. Both are AGM, XX is YUASA, DRZ is generic no name. Â As mentioned my XX battery would charge to the point the tenders light would turn green, as expected. The DRZ battery was charging to the green light point during the winter but more recently (the last 1-2 charges?) it would not, the charger light would remain solid orange. It's finally getting nice out (yesterday was the first day of the year I wore shorts) so I, like everyone else, am in get-bikes-on-road mode. I gave both a full couple days on the charger this week and tried to fire them up. XX - dash lights come on like normal but starter did not turn the engine over at all. No click, no nothing. DRZ - starter jabs turned over the engine a bit but it was weak limp dick turns and only a few. Â I figure I've got two dead batteries at that point and on Tuesday, I call the shop and ask them to prepare two new ones for me. [As a sidenote, YUASA runs ~$140 here and no name generic ~$60-80. What brands off batteries do you guys run? Does it matter? Both seem to have the same 1 year warrenty] While on the phone, the shop owner, Barry, notices that my DRZ battery is not even a year old and thus would be covered under warranty if it's actually dead. He asks me about my home charging situation as asks me to bring it in for them to assess/try charging, I drop it off to them 5 minutes before close on Tuesday. I went into the shop yesterday morning to see how it went and he tells me it's fine after a charge there in the shop and hands it back to me. I can only presume they have some top shelf charging set up. We talk about the XX battery and my charger and Barry says I should bring the suspect XX battery in to him too for them to check out/charge similarly. I agree. I know it's likely 4-5 years old. Â I put the DRZ battery back in the bike at home yesterday afternoon and it works like new. It turns that engine over quickly and strongly, with the strength of an unexpected boner that a 15 year old would be desperately trying to hide in class. It is at this point that I remember my drunken charging fuck up ... errr my friend's .... and I start a wondering about possible damage. Â I plan to drop XX battery off to Barry this week to see if they can resurrect it or sell me a new one. In the meantime I was aiming to check on anything that might have occurred during the drunken mishap. Â I do have 2 other chargers. Â One is a manual 1 amp with no auto feature. I.e., it's not a set it and forget it. Looks like they don't even sell manual ones anymore, but it's this one. You have to watch the time it's on and disconnect after x-hours. Â The other I have is an older one I stole from my dad years ago. It's a big honker for car batteries and has a 2amp setting as the lowest option so I have been reluctant to use it on tiny bike batteries but it is variable and has auto/maintenance. I think it is an older version of this one. It does have a jump start type setting but I think it says it's like 80 amps or something. Â I'm going to check fuses on the XX and will aim to take the battery into Barry this week but if any of you have any other suggestions in the meantime, it's appreciated. Â Â Quote Link to comment Share on other sites More sharing options...
ironmike Posted April 11, 2021 Share Posted April 11, 2021 Almost all trickle chargers have a programmed voltage threshold below which they won't initiate a charging cycle (check to original paperwork). Most have no way of alerting you to a below threshold voltage - per the LED(s) they appear to be working normally but they're not actually charging. Â I have an old Sears 12v 10/2amp charger w/voltmeter from the early '70s that I'll employ at the 2amp setting whenever I suspect a trickle charger isn't really performing. That works just fine for motorcycle batteries. After a full bench charge, the trickle charger is re-applied. After installation I retest voltage at rest and under load. Â I have an earlier version (BA-7)of this load tester . . . Â https://cloreautomotive.com/product/ba9/ Â 1 1 Quote Link to comment Share on other sites More sharing options...
OMG Posted April 12, 2021 Share Posted April 12, 2021 On another side note, waaaay back, 1974 or so, One of the other mechanics was working on a Honda 350 trying to get it to start. He had replaced a few parts to no avail and asked me to look at it. I hit the start button and told him that the battery was connected backward. He said no, I checked that. I convinced him a new battery would fix it, it did. Apparently the owner had the battery go dead flat and charged it with reversed polarity. It was spinning the starter backward. Quote Link to comment Share on other sites More sharing options...
DBLXX Posted April 12, 2021 Share Posted April 12, 2021 Sell the bike. It’s ruined. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted April 12, 2021 Share Posted April 12, 2021 Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted April 13, 2021 Share Posted April 13, 2021 I was only gonna offer a hundy, take the previous offer and run! Quote Link to comment Share on other sites More sharing options...
Nova Scotia Mike Posted April 13, 2021 Author Share Posted April 13, 2021 On 4/11/2021 at 10:02 PM, OMG said: Apparently the owner had the battery go dead flat and charged it with reversed polarity. It was spinning the starter backward.    On 4/12/2021 at 8:41 AM, DBLXX said: Sell the bike. It’s ruined.   23 hours ago, SwampNut said:  12 hours ago, superhawk996 said: I was only gonna offer a hundy, take the previous offer and run!    Quote Link to comment Share on other sites More sharing options...
SwampNut Posted April 13, 2021 Share Posted April 13, 2021 Well at least that removed the last song stuck in my head, and it was from the Spice Girls. Â Quote Link to comment Share on other sites More sharing options...
Nova Scotia Mike Posted April 13, 2021 Author Share Posted April 13, 2021 1 hour ago, SwampNut said: Well at least that removed the last song stuck in my head, and it was from the Spice Girls.  Easy come, easy go Quote Link to comment Share on other sites More sharing options...
XXitanium Posted April 30, 2022 Share Posted April 30, 2022 On 4/11/2021 at 1:36 PM, ironmike said: Almost all trickle chargers have a programmed voltage threshold below which they won't initiate a charging cycle (check to original paperwork). Most have no way of alerting you to a below threshold voltage - per the LED(s) they appear to be working normally but they're not actually charging. Â I have an old Sears 12v 10/2amp charger w/voltmeter from the early '70s that I'll employ at the 2amp setting whenever I suspect a trickle charger isn't really performing. That works just fine for motorcycle batteries. After a full bench charge, the trickle charger is re-applied. After installation I retest voltage at rest and under load. Â I have an earlier version (BA-7)of this load tester . . . Â https://cloreautomotive.com/product/ba9/ Â Â Â Apparently you can trick the logic. You hook two batteries in parallel. Out the discharged AGM on the other side of the good battery. Â My AGM-battery in the CBX wouldn't even turn the neutral light on yesterday. Â I think the battery is more than six years old. I'm trying to decide if I should go try this resurection, or just excercise my plastic at the parts store and get a new battery. Â Â I think I "need" a C-TEC charger. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted April 30, 2022 Share Posted April 30, 2022 (edited) Battery "Failed" version. (Need new battery) Â I typed in "AGM- battery" with a dash for searching later. I had almost 8,000 results here for everything from weed whackers to personal pleasure devices... Â The search function does not "do" TLAs pretty much at all. Â Â Edited April 30, 2022 by XXitanium Clarity dammit Quote Link to comment Share on other sites More sharing options...
SwampNut Posted April 30, 2022 Share Posted April 30, 2022 A parallel battery is how I "jump start" my intelligent chargers. Â It can even be a tiny battery, I once used the one out of the alarm panel to do it. Â I recently did a thread about my generator battery. Â A week or so on the restorer and it's starting the generator almost like new. Â I keep forgetting that restorer is sometime magic. Â 1 Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted May 1, 2022 Share Posted May 1, 2022 On 4/30/2022 at 5:35 AM, XXitanium said: Â Â Apparently you can trick the logic. You hook two batteries in parallel. Out the discharged AGM on the other side of the good battery. Â My AGM-battery in the CBX wouldn't even turn the neutral light on yesterday. Â I think the battery is more than six years old. I'm trying to decide if I should go try this resurection, or just excercise my plastic at the parts store and get a new battery. Â Â I think I "need" a C-TEC charger. I stopped at the 4 minute mark, after doing some fast forwarding to that point, because right away I was guessing it would be somewhat retarded. Â You don't have to waste so much time doing what he did, and it's a bad idea because if the dead battery has a shorted cell the charger may not see it and keep trying to charge. Â Put your charger on the dead battery, jumper in the good battery, hit the start button, disconnect good battery. Â Option 2, do the same but use a dumb charger instead of another battery. Â Typically, once the smart charger starts it'll stay on when you disconnect the jumper, it just needs to see enough voltage to start. Â It's the same whether it's AGM or flooded, smart chargers all have a minimum start voltage. Â And as Carlos pointed out, damn near any battery will do the trick. Â It takes very little amperage to get the dead battery's voltage up, could probably even do it with a 9v alkaline battery. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted May 1, 2022 Share Posted May 1, 2022 I hooked my big shop (spare car) battery up backwards momentarily to my Schumacher. Duh! Â The shop battery was low. It's charging now. Â The CBX battery has 5/16 (May 2016) scratched in the top. ...that:s when I got the bike back from the shop. Â The CBX battery threw a code "SUL" on the Schumacher display. It's a sealed unit, but it does not specifically read AGM. Â https://www.motortrend.com/how-to/impp-1105-battery-desulfators-fact-fiction/amp/ Â I think I'm just going to buy a new battery for the CBX. Â Quote Link to comment Share on other sites More sharing options...
XXitanium Posted May 1, 2022 Share Posted May 1, 2022 (edited) The shop battery voltage. Â No desulfating mode. Â https://www.schumacherelectric.com/products/6-2-30-85a-6-12v-fully-automatic-battery-charger-engine-starter/ Â Â Edited May 1, 2022 by XXitanium Quote Link to comment Share on other sites More sharing options...
XXBirdSlapper Posted May 3, 2022 Share Posted May 3, 2022 On 4/11/2021 at 8:02 PM, OMG said: On another side note, waaaay back, 1974 or so, One of the other mechanics was working on a Honda 350 trying to get it to start. He had replaced a few parts to no avail and asked me to look at it. I hit the start button and told him that the battery was connected backward. He said no, I checked that. I convinced him a new battery would fix it, it did. Apparently the owner had the battery go dead flat and charged it with reversed polarity. It was spinning the starter backward. I know someone that did the same thing Quote Link to comment Share on other sites More sharing options...
OMG Posted May 4, 2022 Share Posted May 4, 2022 On 5/1/2022 at 11:01 AM, XXitanium said: I hooked my big shop (spare car) battery up backwards momentarily to my Schumacher. Duh! Â The shop battery was low. It's charging now. Â The CBX battery has 5/16 (May 2016) scratched in the top. ...that:s when I got the bike back from the shop. Â The CBX battery threw a code "SUL" on the Schumacher display. It's a sealed unit, but it does not specifically read AGM. Â https://www.motortrend.com/how-to/impp-1105-battery-desulfators-fact-fiction/amp/ Â I think I'm just going to buy a new battery for the CBX. Â Â Make sure it's from lowa yuasa and not the cheaper uppa yuasa ones. Quote Link to comment Share on other sites More sharing options...
