SwampNut Posted September 20, 2022 Share Posted September 20, 2022 This is another high-dollar thing that lasts a lifetime. I believe Oscar is still using the tube my dad owned. 1 Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted September 21, 2022 Share Posted September 21, 2022 51 minutes ago, SwampNut said: This is another high-dollar thing that lasts a lifetime. I believe Oscar is still using the tube my dad owned. I agree if it is a low use but works excellent, it is worth it. Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted September 21, 2022 Share Posted September 21, 2022 (edited) 10 hours ago, superhawk996 said: Heat seems to draw the lube in, maybe just because it thins the lube, and/or it draws the lube in as the parts cool. But you don't want the parts so hot that they cook the oil. I have two transmission to engine bolts soaking in Deep Creep after warming the engine up, today I'll find out if it helped. Yes, I'm quoting myself, there's a follow-up. The lube seemed to do nothing. After about a week of soak time both bolts were still stuck hard. How hard you ask? One of them broke the engine block before coming loose. Luckily it's a Porsche 911 so a used engine only costs about what the car is worth in running condition. But truthfully, it doesn't need replacing. Luckily the cracked area isn't a huge deal and I was able to fix the threads so that the bolt goes in fine. ETA: The bolts appeared to have copper anti-seize and I think there was some metallurgical force at play making the bolts stick. Steel bolt + aluminum engine case + copper anti-seize might be a bad cocktail. The bolts felt like they were a pressed fit, I had to crank them pretty hard right to the last thread using an extra long 1/2" drive ratchet. Edited September 21, 2022 by superhawk996 Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted September 21, 2022 Share Posted September 21, 2022 1 hour ago, SwampNut said: I believe Oscar is still using the tube my dad owned. This is a can, and he stole if from work, but they don't know I have it. I often wonder why I'm so careful not to waste any, fuckin thing's 20 years old and around 3/4 full...after showing up already in used condition. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted September 21, 2022 Share Posted September 21, 2022 6 minutes ago, superhawk996 said: Yes, I'm quoting myself, there's a follow-up. The lube seemed to do nothing. After about a week of soak time both bolts were still stuck hard. How hard you ask? One of them broke the engine block before coming loose. Luckily it's a Porsche 911 so a used engine only costs about what the car is worth in running condition. But truthfully, it doesn't need replacing. Luckily the cracked area isn't a huge deal and I was able to fix the threads so that the bolt goes in fine. Was there some unusual reason for the stuck bolt like screwed up threads? After removal, was it super rusty? I've never had a motor to trans bolt stuck very bad. Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted September 21, 2022 Share Posted September 21, 2022 Just now, blackhawkxx said: Was there some unusual reason for the stuck bolt like screwed up threads? After removal, was it super rusty? I've never had a motor to trans bolt stuck very bad. No corrosion at all, and re-read it as I edited it to add the possible reason. Quote Link to comment Share on other sites More sharing options...
