tomek
Chain reaction
10 hours ago, superhawk996 said:
I'd never noticed that button and for some reason it just hit me.
Yeah, I'd never used it, on any forum.  But on an RV forum with light traffic, I decided to try it, because there are SOOO damn many sub-forums with just a message or two.  So then I decided to try it here, and unfortunately read this crap which I'd avoided opening at all, considering the OP.  Lesson learned.
I'd make a "your mom" joke now, but then, that would be, you know, kind of creepy.
Share this post
Link to post
I guess I shoulda known better, but figured it was a completely different deal than the usual threads and thought he would be different.  I truly thought he was seeking an answer, or maybe just playing a fun game of 'guess what happened', either way I didn't expect such a clusterfuck.
Despite my conscious desire to be fair and honest I know that the past will come though in my posts to him.  On a scale of 1-10, or however you want to quantify it, how much of my prejudice do you think I put out to him?  And that is out there for anyone else willing to chime in, I'm just trying to learn.
Share this post
Link to post
Sorry, that would require actually reading the thread.  The only message I had read was the one where he had a hissy fit.  I don't have an opinion on the subject matter, didn't read it.
Share this post
Link to post
On 2/3/2019 at 4:53 PM, superhawk996 said:
The crank journal temp went over 600 long enough for the web to hit 600 pretty far from the journal and there was more than just bearing material gone, the evidence is clear, enjoy your feelings.
Just as expected you failed to explain part of my post in bold. You just resorted to your typical Cuban bull shit when confronted with hard evidence.
Share this post
Link to post
I did, you can't comprehend.
Share this post
Link to post
No, you did not. Respond to bold part of my previous post or you are not man enough to admit you were wrong.
Share this post
Link to post
On 2/3/2019 at 11:07 AM, superhawk996 said:
And that's the last question I'll answer from you 'till you answer my questions.
And acknowledge that I was right about the clogged pump inlet.
Share this post
Link to post
Share this post
Link to post
I'm going to go with a "1", at least to start with.  Clearly Tomek didn't like it that you even posted in his thread at all, so he automatically took offense to anything you said.  Why he didn't just put you back on ignore is the baffling question to me.
Share this post
Link to post
16 minutes ago, SwampNut said:
Why I'm not surprised. Your broo run of ideas how to defend his theory, so we came to this.
He either refuses to learn something new, or has a problem admitting he was wrong.
Share this post
Link to post
Probably trying to pretend he can act like an adult, but then failing.
Share this post
Link to post
I doubt he's even read my theories and what he posted has nothing to do with defending anything.
I invite education and don't at all mind being proven wrong, I'll even entertain unproven reasonable evidence.  Since you refuse to have an honest conversation it's impossible to get anywhere useful.
Share this post
Link to post
Funny the difference in tone between some of the posts and "other's".
Share this post
Link to post
Deflection, deflection, but no response whatsoever to my post in bold. Why I'm not surprised.
My last attempt to pound something in your head.
The picture of the "clearance" between the big end and crank.  More the 1/2. Inch. How do you think it happened. By riding around the race track at 14  k rpm for 30 minutes, or when bearing sized some sort of "thermonuclear"reaction happened and shit melted, ignited in matter of seconds. ?
I gotta admit when I opened the engine my jaw dropped when I saw this.
Share this post
Link to post
I have answers, do you?
Share this post
Link to post
Because you don't have enough intelligence to get to that point?  Just a guess.  I could be wrong.
Your mom does that as soon as I'm in front of her, so that's actually the first believable thing you've ever said!
Share this post
Link to post
Share this post
Link to post
I can't imagine how the top end work you describe could have dislodged something that would have damaged the chain pictured. What type of shrapnel was floating around the engine when you tore it down? Anything large enough to damage the chain as pictured?
 Did the failure lead to the oil pump pickup clogging as the described?
Share this post
Link to post
Are swampnut and superhawk having mental breakdowns ?
Share this post
Link to post
Is that like throwing a cranial rod? 😀
Share this post
Link to post
I'm holding on to my crank just to be sure.
Share this post
Link to post
Unless you dropped something without realizing it, I guess. But I gotta agree that it doesn't seem likely the top end work would do that tot eh chain.
As you look at cam sprockets and the sprocket on the crank are there any indications of something getting lodged under the chain? Just speculation, but it seems to me that something had to get caught between a sprocket tooth and the link plate, forcing the plate to flex out of plane. The flex may have just fatigued that plate and the oscillations from high-rev operation finished the job sometime later.
Anyone have other thoughts to contribute, preferably about Tomek's chain instead of his mom?
Share this post
Link to post
I'm also very curious about it.  There's obvious damage to several links, but without seeing all the parts there's no way to say why.  Even with the whole motor in my hand I don't know if there would be a way to know why it happened.  Your guess of something being dropped in while doing the work makes sense and it was my first thought, but living for another 500 tack miles after that doesn't quite jive.  Maybe the chain was levered onto the sprockets and some initial damage was done that then damaged the guides.  It's also possible that when the rod went the shock load snapped that link, but there appears to be too much damage for the link to be an after-effect unless he continued to run it to get off the track.  It's also possible that everything was done perfectly and the chain just broke for no good reason.
  • Like 1
Share this post
Link to post
