Obby Posted July 13, 2005 Share Posted July 13, 2005 Silly question I guess.... but what the hell. What is the best way to clean you chain without removing it? Some say they use Gunk, WD-40, Kerosene. Any other bright ideas out there? -Obby Quote Link to comment Share on other sites More sharing options...
matey_peeps Posted July 13, 2005 Share Posted July 13, 2005 I don't. Never have. I get around 20k outta chains. However, you're supposed to use kerosene or wd40 as it's mostly kerosene and a soft cloth. :roll: Quote Link to comment Share on other sites More sharing options...
Redbird Posted July 13, 2005 Share Posted July 13, 2005 I do. Occasionally. I get around 20k outta chains. WD-40, just to wipe off the gunk from the sideplates, no dicking around with brushes or anything. Quote Link to comment Share on other sites More sharing options...
XXTi Posted July 13, 2005 Share Posted July 13, 2005 I use kerosene and a brush if mine gets particularly grungy. Quote Link to comment Share on other sites More sharing options...
RichardCranium Posted July 13, 2005 Share Posted July 13, 2005 I clean mine by applying more chain lube on top of all the old chain lube. Quote Link to comment Share on other sites More sharing options...
Cossi Posted July 13, 2005 Share Posted July 13, 2005 I clean mine by applying more chain lube on top of all the old chain lube. :stupidsign: Quote Link to comment Share on other sites More sharing options...
G4XX Posted July 13, 2005 Share Posted July 13, 2005 I put mine on the centerstand, get the WD-40, put the little red tube in the can, and go to town. Put a drain pan under her to catch the drips and spray away from the back tire...works good enough for me... Quote Link to comment Share on other sites More sharing options...
XX Posted July 13, 2005 Share Posted July 13, 2005 85W synthetic oil dispensed manually via my hawkeoiler, my chains go about 25k until getting noisy and then getting replaced. Quote Link to comment Share on other sites More sharing options...
willxx23 Posted July 13, 2005 Share Posted July 13, 2005 I clean mine by applying more chain lube on top of all the old chain lube. :stupidsign: +2 Then I use WD40 to clean all the chain gunk from the rim/rear end. :wink: Quote Link to comment Share on other sites More sharing options...
Grey_XX Posted July 13, 2005 Share Posted July 13, 2005 I clean mine by applying more chain lube on top of all the old chain lube. Same technique here. 20kmiles on average. Hugo Quote Link to comment Share on other sites More sharing options...
Dion Posted July 14, 2005 Share Posted July 14, 2005 I clean mine by applying more chain lube on top of all the old chain lube. :stupidsign: +2 Then I use WD40 to clean all the chain gunk from the rim/rear end. :wink: +3 Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted July 14, 2005 Share Posted July 14, 2005 If it don't look good, it aint worth having. Clean it.IMHO Quote Link to comment Share on other sites More sharing options...
Grey_XX Posted July 14, 2005 Share Posted July 14, 2005 If it don't look good, it aint worth having. Â Clean it.IMHO IMHO, the time you spend cleaning should be spent RIDING Hugo Quote Link to comment Share on other sites More sharing options...
LongHaul Posted July 14, 2005 Share Posted July 14, 2005 WD-40, just to wipe off the gunk from the sideplates, no dicking around with brushes or anything. +1 Quote Link to comment Share on other sites More sharing options...
blkbrdrydr Posted July 14, 2005 Share Posted July 14, 2005 Scottoiler! Hardly any wear on the chain or sprockets at 30,000 miles. Quote Link to comment Share on other sites More sharing options...
N1K Posted July 14, 2005 Share Posted July 14, 2005 I spray wd-40 in a cloth and wipe the chain, just the outside so the gold is purty. Then I spray honda chain lube on it. Quote Link to comment Share on other sites More sharing options...
Hobicus Posted July 14, 2005 Share Posted July 14, 2005 Scottoiler. I had 57k miles on the rear sprocket, no wear, was only on my 2nd chain. I clean my chain, once in a while, just because, with Honda Polish. Quote Link to comment Share on other sites More sharing options...
bhanxx Posted July 14, 2005 Share Posted July 14, 2005 Clean chain? Hell, i don't even clean the tank... Quote Link to comment Share on other sites More sharing options...
twodealdrive Posted July 14, 2005 Share Posted July 14, 2005 when it gets dirty I touch it up with some silver spray paint. Makes it look brand new. Be careful of the overspray though and make sure it's dry before you take off. I'm thinking about trying gold spray paint next for the bling bling look. Or maybe chrome paint..... Quote Link to comment Share on other sites More sharing options...
arcticflipper Posted July 14, 2005 Share Posted July 14, 2005 Cleaning the chain I found in south africa is bit different. i don't know if the chain wax is the same all over the world, but here we seem to get the really shitty products. The wax doesn't last long, and becomes very sticky. There are 2 easy ways to clean the wax of the rim and also the chain. Cheap Version: 1 or 2 cans of Doom (this is a bug spray) - seems to take the wax right off with one wipe. + a hell of a lot cheaper than the wax removal products available... Better version: Parafin - This is fairly cheap, and goes a long way. Use a squirt bottle for this and spind the wheel. Please wear eyewear - old wax and gunk flies off the chain pretty quickly, and don't smoke while you're doing this, parafin is extremely flamable.... Quote Link to comment Share on other sites More sharing options...
Squareman357 Posted July 14, 2005 Share Posted July 14, 2005 I spray wd-40 in a cloth and wipe the chain, just the outside so the gold is purty.Then I spray honda chain lube on it. +1 Gold looks nice when clean... Quote Link to comment Share on other sites More sharing options...
jblackbird2000 Posted July 14, 2005 Share Posted July 14, 2005 Speaking from experience, just make sure what ever you use to clean your chain with is O-ring safe. I just recently used some old paint thiner I had laying around, and guess what...not o-ring safe. :roll: I am getting that red dust all over my rear end now, a sure sign my chain isn't going to last much longer. I know, stupd, stipud, stoopid Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted July 14, 2005 Share Posted July 14, 2005 Yep, gas, paint thinner, carb cleaner, brake cleaner, all are BAD for o rings. Just kerosenne or WD-40. I'm pretty much in the don't clean it camp. Quote Link to comment Share on other sites More sharing options...
Red J Posted July 14, 2005 Share Posted July 14, 2005 Astroglide, same as what I lube it with. Quote Link to comment Share on other sites More sharing options...
Obby Posted July 14, 2005 Author Share Posted July 14, 2005 This is turning out to be a funnier thread than I expected. Thanks for the suggestions folks. The reason I asked is that one of my links is kinked and starting to bang around when riding. I was hoping to clean and lube it really well to see if I can get some more life out of it. Damn chain cost ~$160.00 bucks to replace as you all know Quote Link to comment Share on other sites More sharing options...
