XXTi Posted April 12, 2005 Share Posted April 12, 2005 I damn near twisted my key off trying to get my gas tank open yesterday. :evil: I put some graphite in the lock a few months ago and it's worked OK until yesterday. Anyone have a better lube suggestion? I'd also like to get another OEM style key, but I can't seem to find a blank anywhere. Am I going to have to go to the local Stealer? Quote Link to comment Share on other sites More sharing options...
willxx23 Posted April 12, 2005 Share Posted April 12, 2005 I sometimes see the blanks on Ebay, I went to the stealer and paid 10$ for the blank, then had to go to the locksmith and pay 1.50$ for him to cut it. :x Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted April 12, 2005 Share Posted April 12, 2005 We've had a few ignition switches do this, can't remember a gas cap. Try sticking the key in the other way or try your other key. The tumblers only read one side, but key is cut on both sides so it can go in either way. With use the key peaks can wear and not engage properly. Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted April 13, 2005 Share Posted April 13, 2005 Sometimes mine seems to have a bit too much pressure on it key doesn't seem to want to turn. If I push down on the cap and turn it works no problems. Might want to give it a shot if you haven't. Quote Link to comment Share on other sites More sharing options...
mbarr78 Posted April 13, 2005 Share Posted April 13, 2005 I use (CLP Break Free) for all my lube needs. You can get it at Wal-Mart in the same area as the guns. It is made for use on guns but I have discovered it works very well on anything, much better than WD-40. In Gun test magazine they tested it against many other lubes and it ranked the best and showed very good rust resistance on blued firearms. It is worth a try IMO. My $ .02 Mike Quote Link to comment Share on other sites More sharing options...
XXTi Posted April 13, 2005 Author Share Posted April 13, 2005 CLP is a good idea. I probably have half a gallon of it around the place. I'll try some. Quote Link to comment Share on other sites More sharing options...
N1K Posted April 13, 2005 Share Posted April 13, 2005 My gas cap sticks all the time too. its annoying. I bend a key once trying to get it open. (won't do that again) now I just click it back down, open it, click it back down repeatedly until it comes loose. Quote Link to comment Share on other sites More sharing options...
LongHaul Posted April 13, 2005 Share Posted April 13, 2005 My cap sticks as well. Another BB owner told me his cap used to stick but he thought it was the rubber seal around the cap. He lubed it with something (?), it fixed the problem, so he's convinced that it was in fact the seal. Haven't lubed MY seal yet cuz graphite in the lock fixes MY problem (for awhile) so I'm convinced its NOT the seal but the lock. Quote Link to comment Share on other sites More sharing options...
N1K Posted April 13, 2005 Share Posted April 13, 2005 I'm pretty sure its the lock. Seems to happen more often when I overfill the tank and get gas up on the latch. Quote Link to comment Share on other sites More sharing options...
JB4XX Posted April 13, 2005 Share Posted April 13, 2005 SELL IT!! POS Honda! :mrgreen: Quote Link to comment Share on other sites More sharing options...
Fly By Posted April 13, 2005 Share Posted April 13, 2005 I'm pretty sure its the lock. Seems to happen more often when I overfill the tank and get gas up on the latch. +1 Quote Link to comment Share on other sites More sharing options...
gearjunkie Posted April 18, 2005 Share Posted April 18, 2005 This same bullshit happend to me all the time about a year ago. Damn near twisted a key in half trying to get the friggen gas cap open. I finally fixed it by slightly adjusting the position of the cap assembly within the tank. Try loosening the cap assy w/an allen wrench, moving it slightly until the lock opens easily, and retighten. Worked for me. My cap hasn't jammed since. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted April 18, 2005 Share Posted April 18, 2005 Try loosening the cap assy w/an allen wrench, moving it slightly until the lock opens easily, and retighten. Worked for me. My cap hasn't jammed since. Nik, if you do this, remember, you have to tighten the bolts really-really tight. Quote Link to comment Share on other sites More sharing options...
N1K Posted April 18, 2005 Share Posted April 18, 2005 Nik, if you do this, remember, you have to tighten the bolts really-really tight. I'll throw a breaker bar on the end of the allen wrench! Quote Link to comment Share on other sites More sharing options...
XXMAN Posted April 27, 2005 Share Posted April 27, 2005 My zx11 stuck like that and I put wd-40 in the keyhole works great now. good luck getting your key out. Quote Link to comment Share on other sites More sharing options...
LoneWolf Posted April 27, 2005 Share Posted April 27, 2005 Appreciate the tip gearjunkie! I have had trouble with the cap for some time thinking I needed to lube the tumblers and release mechanism. It really did not take much adjustment but now the cap opens easily and no mo twisted keys... Quote Link to comment Share on other sites More sharing options...
XXMAN Posted August 22, 2005 Share Posted August 22, 2005 Have same problem with zx11 wd-40 fixed mine.. Quote Link to comment Share on other sites More sharing options...
rickrad Posted August 22, 2005 Share Posted August 22, 2005 Wal-mart had Honda blanks when I looked last. No Joke. Quote Link to comment Share on other sites More sharing options...
XXTi Posted August 22, 2005 Author Share Posted August 22, 2005 I fixed mine with spray Rem-Oil gun lube. It's been working fine since then. I think I probably used too much graphite in it. Quote Link to comment Share on other sites More sharing options...
chaserkeywest Posted August 23, 2005 Share Posted August 23, 2005 Marine hardware store "Corrosion Block" spray can, best stuff lasts a long time mush better that WD40 and others that evaporate in short time. I use it on cable ends,switch gear, spray top of forks under triple Tree and let it run down, also ignition key slot, wire connections, nuts bolts. Any where you would spray WD 40 but it stays active much longer. Quote Link to comment Share on other sites More sharing options...
