Zero Knievel Posted February 23, 2023 Share Posted February 23, 2023 The range top sits in the hole cut into the new countertop. It’s larger than needed, so the range top shifts from time to time. Mom doesn’t want to bolt it down in case it ever needs replacement and the replacement’s footprint doesn’t match for holes. I bought some Permatex Clear RTV Silicone. My thought was to apply a dab at the front corners, and when it cures, it will be a strong enough hold to prevent it slipping. I’m concerned about heat, but if the burners emitted that much heat at the countertop level, the range top would be too hot to touch and the counter would melt. Thoughts? If not this, what product would be better? Quote Link to comment Share on other sites More sharing options...
XXitanium Posted February 23, 2023 Share Posted February 23, 2023 Picture of where the top meets the counter from above and below. You know we like pictures. ...did you replace the windows yet? (Bolt it down when she's not looking or tell her it has to meet NEC code) Quote Link to comment Share on other sites More sharing options...
Furbird Posted February 24, 2023 Share Posted February 24, 2023 When in doubt, google it. I was pretty sure it was "it should have come with clips or foam" and I was right. But it depends on your counter and what type of cooktop. https://www.hunker.com/12483594/how-to-caulk-around-a-cooktop 1 Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted February 24, 2023 Author Share Posted February 24, 2023 As far as what the stove top should have come with, we’re talking 30 years ago. Also, the last countertop had a precision cut hole so we didn’t have to worry about mounting it permanently so it wouldn’t shift. Quote Link to comment Share on other sites More sharing options...
Furbird Posted February 24, 2023 Share Posted February 24, 2023 So... buy new clips or foam? Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted February 24, 2023 Author Share Posted February 24, 2023 1 hour ago, Furbird said: So... buy new clips or foam? I'll look into that. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted February 24, 2023 Share Posted February 24, 2023 16 hours ago, Zero Knievel said: Mom doesn’t want to bolt it down in case it ever needs replacement and the replacement’s footprint doesn’t match for holes. Always live your whole life around planning for the worst. Sheesh. You could also use wood blocks to simply make it bigger where it needs to be. Stick them on with light glue or double-stick tape. Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted February 25, 2023 Author Share Posted February 25, 2023 (edited) I hoped to find the original mounting hardware. No luck. Here’s what I’m working with…perhaps spring clips? Photos to follow… Edited February 25, 2023 by Zero Knievel Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted February 25, 2023 Author Share Posted February 25, 2023 23 hours ago, SwampNut said: Always live your whole life around planning for the worst. Sheesh. Failure to so do is why we’re out THOUSANDS because dad presumed we’d never need to work on or replace something. I could probably tabulate and easy $10K so far in house repairs because he didn’t think something was necessary. Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted February 25, 2023 Share Posted February 25, 2023 If the next one is too small to cover screw holes, wouldn't it also be too small for the cut-out? Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted February 25, 2023 Share Posted February 25, 2023 And silicone will be fine, just do it and be done. Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted February 26, 2023 Author Share Posted February 26, 2023 2 hours ago, superhawk996 said: If the next one is too small to cover screw holes, wouldn't it also be too small for the cut-out? Yeah, the guy went by the wrong measurement and nearly cut out too much material. That would have forced them to provide a whole new countertop…again. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted February 26, 2023 Share Posted February 26, 2023 Is it just a straight piece of counter, or is there a 90° corner or something even more complicated? Quote Link to comment Share on other sites More sharing options...
XXitanium Posted February 26, 2023 Share Posted February 26, 2023 (edited) How much did they charge you for the countertop? Edited February 26, 2023 by XXitanium Quote Link to comment Share on other sites More sharing options...
XXitanium Posted February 26, 2023 Share Posted February 26, 2023 Quote Link to comment Share on other sites More sharing options...
XXitanium Posted February 26, 2023 Share Posted February 26, 2023 The super bionic Androids around here keep twisting the handles off of the burner controls around here. Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted February 26, 2023 Author Share Posted February 26, 2023 7 hours ago, XXitanium said: Is it just a straight piece of counter, or is there a 90° corner or something even more complicated? Straight where the cooktop is, but 90 degrees on both ends. Came in 2 parts and had to be glued together. The first one was poorly made and should never have left the factory. Head of QC came out and redid it all (to their credit), but he commented that this happened all the time…installs without a final review by QC before installation…resulting in complete replacements at the company’s cost. 7 hours ago, XXitanium said: How much did they charge you for the countertop? Don’t recall off hand. Not crazy expensive but not cheap. It’s a step up from the fiberboard/laminate basic countertops (original was still in good condition). This is a resin composite. Looks like stone but isn’t. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted February 26, 2023 Share Posted February 26, 2023 That last close-up shot that you had, is that showing holes go all the way through the top from the bottom and are visible from above? I'm thinking Superhawk996's RTV solution is pretty good at this point. Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted February 26, 2023 Share Posted February 26, 2023 14 hours ago, Zero Knievel said: Yeah, the guy went by the wrong measurement and nearly cut out too much material. That would have forced them to provide a whole new countertop…again. You apparently missed my point. Mom is worried that if you drill for screws and the next range was smaller it wouldn't cover those holes. But if the next range is smaller wouldn't it also be too small for the cut-out? Meaning that you couldn't install it at all so the screw holes wouldn't matter. And I would have made them replace it and make the cutout the correct size, but I know you'd rather have something complicated to figure out over the next year and 3 pages of help. Just use the silicone, stop overthinking it. If it gets hot enough to let go, re-do it with high temp silicone. Or just buy that and be guaranteed done. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted February 26, 2023 Share Posted February 26, 2023 It would be the exact same problem, of course. Trent just ran into this, it's pretty common, because the tops have actually become more compact over time. He had a nice stainless steel trim ring made and not only solved the problem, it looks way better. There are always solutions, unless you choose to always look for problems. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted February 26, 2023 Share Posted February 26, 2023 Are there holes all the way through the top? Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted February 26, 2023 Author Share Posted February 26, 2023 No…that’s the base of the unit…the catch pan for anything that falls through the heating element hole. Lowes and Home Depot understood my situation, but they didn’t have anything in stock that addressed it. Searching inventory wasn’t helpful since unless you know exactly what something is called, you get results for a ton of stuff that’s not what you want. However, I had an idea. Why not make a shim to close the gap? I have lots of scrap wood. Taking measurements, I’m trying to close a 1 1/8” gap in the front and 10/16” gaps on the side. The counter itself is 1/4” thick. If I want to do front and back evenly, that’s a 9/16” gap for front and back. I also noticed that with the exposed holes, I could secure it to the drip pan where the shim and hole aligns. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted February 27, 2023 Share Posted February 27, 2023 1 hour ago, Zero Knievel said: However, I had an idea. Why not make a shim to close the gap? I have lots of scrap wood. If only someone had thought of that. On 2/24/2023 at 8:36 AM, SwampNut said: You could also use wood blocks to simply make it bigger where it needs to be. Stick them on with light glue or double-stick tape. Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted March 1, 2023 Author Share Posted March 1, 2023 Just put a square inch of VSB tape on the front two corners. I'll let you know how well it works out. Quote Link to comment Share on other sites More sharing options...
SwampNut Posted March 1, 2023 Share Posted March 1, 2023 You put the Virginia State Bar on it? Is that legal? Quote Link to comment Share on other sites More sharing options...
