Furbird
Everything posted by Furbird
  1. Considering this is in the garage, I'm assuming this is a serious question, otherwise it belongs elsewhere? Bike related, way back in my early drag racing days, I would put a bottle of alcohol in the tank with the fuel. We all did it, can't even remember why if I'm being honest. Last time I did it, I messed up and bought 50-ish% instead of the 93-ish% I normally did. Well, that was just enough to make the bike not run considering the other 50-ish% was WATER. Fortunately nothing hydrolocked but it certainly didn't run. Ended up having to drain the tank and come back the next week. Car related, I jumped a 1971 Super Beetle. It was NOT a Baja Beetle. I think the only reason it survived is that it landed on a soft dirt field and only dropped about four feet, plus it landed on all four wheels simultaneously. I did have to re-gap the points to make it home, though. That's the same car I put 4-15's in because a local stereo shop said "You can't put 4-15's in a Bug."
  2. Mine failed high as well. Same bike, the drag bike. I posted on it somewhere on here, similar voltage as yours. That bike was a former stunt bike, and it showed it. The only thing left after I got done throwing things away was basically the frame and the engine. Even the swingarm bearings at the pivot were seized.
  3. 40 man hours at shop rate = totaled. 40 man hours at your time = helluva deal. That must be low miles and lived inside to be that clean. The connectors anyway.
  4. I've only ever owned Dillon because all the guys I plate raced with had Dillon. Now the rifle stuff is where the fights start but when you're doing hundreds of pistol rounds at a time, it's Dillon. Ain't no snipers out there reloading on a progressive machine.
  5. Good idea on the headlight if you're still running standard bulbs for sure. I did it because I (like a lot of us) are running additional accessories as well (upgraded horns, heated gear, etc.) and it's not like any of us leave anything alone anymore. But in the OP's case it was clear that somebody had been in there before so you might as well start with a known good connection instead of hoping all the factory stuff is there.
  6. I don't think we were clear, or if you watched the video or not, but you actually have to unplug the block and check the inside to verify there is no corrosion on that ground and power test connectors. I'd be shocked on a 22 year old bike if it doesn't have some corrosion in it. Not doubting you, just saying historically speaking that is very rare. Also re-read the previous and it popped a 30 amp fuse which means you had a dead short in the ECM (or perhaps somewhere else in the wiring that also fried the ECM.) Over the years I have added an additional battery to engine and battery to frame ground separate from the factory connections. Just something I've always done as a carryover from my years in car audio installs because the factory stuff was always so lackluster. If somebody has been in there digging around they may have left something unbolted and you may have missed it. There's one ground right by the battery where the left tank bolt is (I believe that's right, off the top of my head) you might want to check and make sure that's there or not loose.
  7. The real question is do you want to keep chasing this ghost or just make it so the bike will run? If all it is is this one thing, you might consider putting up the proton pack and parking Ecto 1 and just wiring up the fuel pump directly to bypass this Ghostbusters mission.
  8. The photos got lost in the boards transitions over the years, so maybe somebody has one somewhere. Here's a video I found real quick where somebody had already tried to do a quick repair and it didn't work. There's also a positive connector that's green in color on the inside frame rail near the throttle bodies. Believe I and the guy with the quad bird are the only two people on here that have had that one go bad.
  9. 00's have the same plug as the 99's have, which is the test plug under the battery. Known issue. Should be electrical taped to the main wiring harness, known for getting water intrusion and corroding the wiring. One of my bikes got both the power AND ground test plugs to the point I had to replace entire sections of wiring from end-to-end.
  10. Holy shit, that guy was not fucking around with that Dillon, it's got damn near everything you could get!
  11. The curing answer will be dependent on the product you buy. You also might have to float a topcoat over what you have now with some of these fancy ones. I wouldn't even consider it until I had the building up and dried-in if I were you. You also have the weather factor and will need something resistant to hot-tire pickup. Some of the cheap shit will peel right off. That's why I just said eff it and left mine raw. It's a shop, not a museum.
  12. https://www.ebay.com/itm/334545390793?hash=item4de4758cc9:g:tP8AAOSw-IljDB0H&amdata=enc%3AAQAHAAAAoFIW0ppbXo7zs%2BVRlhE6e6IFug5HR6Mb0c9vja7zBbDuA3zMdZYKYUQJbhptcVG7vAWwuKDlZ2JfRQE3ztMBFT1Fyz%2FF0EXjbwjOMsVf7gWyGsI4jntYWFamoDE%2F%2FPeRba4s4yEs%2BjwUjYo%2F4WWsIYWTPyBCyRR3wbQNCGOIBNHtmKOuGEeJxBIGRioqux4dCrq0g5g3QDKjSy7N%2FXZ2GRA%3D|tkp%3ABk9SR8Cch7vdYA
  13. This is ignition, NOT stator. I think Mike only read the first couple of lines and replied (where you incorrectly typed "stator").
  14. It's CBX vs KZ though, so I don't know what that spark unit does. That's why I'm asking about the spark unit. If something fishy is going on inside that you could have a short. If I had better pictures I could tell better. But I don't see anything else burned up or any damage to the wiring leading to it (that gray cable looks pristine in that zoomed in photo.)
  15. If my guess is correct (internal failure of the coil back-feeding through the spark unit and frying the Dyna) then I would just parts cannon it. Because I'm not talking about 12 volts, I'm talking about however much voltage is being sent to the spark plug. I don't know what those coils are rated at but if it's back-feeding that voltage, I know I wouldn't want my hands anywhere near it. That's a lot of voltage instantaneously that hit that, not a "slow" burn, because the wiring is not burnt leading to that section. It found the weakest link and it found it FAST. I would ohm out all the related ignition wiring, internally inspect the spark unit or replace with known good, replace that coil (or all coils personally because if one is taking a dump and they're all the same age...), new Dyna, new plugs, new plug wires, verify install and timing, and ride out. This is a 40+ year old bike... unless it's a 100 point restoration and you're Jay Leno, it's time for that factory stuff to go bye-bye. My KZ1000 drag bike that I built in 1996 is STILL racing on the Dyna ignition, coils, and wires I put on it in 1996 with the current owner and it sat in my parents garage for almost 15 years.
  16. That looks like an internal failure in the coil to me. What does the inside of the spark unit look like? If it's just simple connections, then the voltage is carrying straight through (but there may be evidence of overheating.) It may look like that Dyna at this point though. That appears to be a ton of voltage causing snap-crackle-pop.
  17. I guess I'll just build a paint booth and downdraft the entire room. Can't breathe it in if it all gets sucked out the floor! 😁
  18. Might be Sparkomatic. I have yet to find an 8 track to Bluetooth adapter for my 71 Firebird.
  19. Wow, I would have thought considering the CFM on that thing it would have easily controlled that. Well, that's why I keep Monica Lewinsky on speed dial.
  20. https://www.garagejournal.com/craftsman-speed-spinner-ratchet/ DAMN!!! $250 with 24 people watching it!!! https://www.ebay.com/itm/294487338671?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=294487338671&targetid=1263094005306&device=c&mktype=&googleloc=9012987&poi=&campaignid=14859008593&mkgroupid=130497710760&rlsatarget=pla-1263094005306&abcId=9300678&merchantid=113784835&gclid=CjwKCAjwmJeYBhAwEiwAXlg0AaV-UCorrnbdtvMST34TsJfbvvn_-Ebu1bpTL86FJbOFIfEPCfRmvBoCh3UQAvD_BwE
  21. When I said "squirrel cage" I meant I have the fan out of a central unit from my neighbors house, not some cheapy HF floor blower. I think if it provided AC to his 1500 square foot house it should probably take care of dust control for me. The largest tool I use is my Grizzly table saw. I bought the accessory kit for the HF unit and it has a plate I can modify to seal over the squirrel cage inlet. If nothing else it should make for one helluva fire. https://www.harborfreight.com/dust-collector-accessory-kit-93601.html
  22. Bear with me a second here because this may be a stretch, but did you have the car stereo on or have you had any issues with the radio? Reason I'm bringing this up is the factory wiring in that dash could have had two illumination wires... one is a steady and one is dimmer. If that steady wire found power, that would make the parking lights come on. This is assuming it is not the factory radio. If it IS the factory radio, you may have something funky going on inside it (I mean, it's only 40 years old.) And if it works off both house battery or run battery, then that could explain it being present no matter what battery you were on. In your panic you may have jostled the problem away with all the switch-flipping. Nearly a decade as a professional car audio installer and working on 12 volt shit since I was 15... I've seen strange things happen. The reality is I think it's just the switch is telling you it's on it's way out.
  23. I'm thinking that thing you linked and a squirrel cage vented outside my shop and I would never have a dust problem again. No need for a collector when I could vent to atmosphere and let the ACTUAL squirrels have to deal with what's left that the cyclone doesn't catch.
  24. Joe's going to be the only one with all of those parts I'm aware of on here. I used all of that to rebuild Furbird V2 from the previous stunter that owned it (plus a ton more). If he's OOS, you're going to be on ebay as I stated further up the thread. Now will be the time to do tapered head bearings as there is no way I would trust the ones in there since it bent the forks. I would tear the entire front end out and inspect everything VERY carefully as that was a significant hit with that being the case. Might want to go ahead and get the triple trees and all and not just the forks.
  25. Yours I believe is a spin (lol) on the Crafted Workshop design?
