A garage queen would be ideal. I'd take an outside bike from Az long before one from a rain/snow/freeze area. In fact I did, my 2001 obviously spent a shit load of time outside in Phoenix. The faded frame paint pretty much tells the tale, and other sun baked things confirm it. But I'm less afraid of cosmetic damage than actual damage like corrosion so to each his own. As far as coolant hoses go, if them living outside in hot weather scares you, you must be shitting yourself over the 200+ temps they see on a ride.
2016 F150 Supercab EcoBoost.
superhawk996 replied to racer212's topic in The Sales Floor -- For Sale/Wanted
Try again pal, 2001 is Lamborghini Balloon White. -
A dictatorship with only one rule, shit tons of freedom, no taxes, that we choose to be a part of. -
You meant to say, for an idiot it sure is. To hate someone you've never met is already kinda dumb, to hate him enough that his becoming president causes you to leave the country purely because of the hatred is retarded. And if their reason really is Trump's presidency it's retarded to have waited this long. -
Curiosity fucking got to me so I went back to read. Worst case scen Worst case scen
I scrolled straight to the end after about 6 posts. Kill the power, flush it out and empty it leaving the drain valve open, bypass the water lines. Some surface rust may form from sitting empty, like any piece of metal sitting around, but it won't rust out like it will if left full of water. Hope your tankless works for you, mine kinda sucks and so did my parents'.
As far moving because of Trump, I agree that's not a reasonable reason. Just like moving because my neighbor's a Jew. Moving because my Jewish neighbor or the president is doing things that negatively impact my life and the only way to stop those things from impacting me is to leave, that's a reason. -
Ahhh, so we're mostly trusting that people will do what's right with extremely minimal actions from our voluntarily chosen governing body and the most aggressive action generally taken against an offender will be to ostracize him?!? ANARCHY! Had to. -
That's about the price range I was guessing they'd offer. Lots of famous people said they'd leave, none did AFAIK. It would be interesting to know how many actually have left because of Trump, and previous presidents, even if the president was only a partial motivator. -
I think '01 and up were all the same, not sure. They're less susceptible to corrosion than the '99 & '00, but my '01 fell victim a couple years ago. Generally the FI light will at least flicker when the loom is acting up, sometimes dimly/quickly so it may not be obvious in daylight. When mine first started showing signs hitting the kill switch off-on fixed it so I figured it was the switch contacts, which can also act up. I assume there was a little bit of resistance in the switch adding to the growing resistance of the loom because the problems started coming back quickly, then got real bad. I checked the computer for fault codes and it had a bunch. Knowing that the loom is a common connection to all the sensors I finally cut into it and it was pretty bad. BTW, we're calling it the loom, harness, etc., I think the proper term is 'check connector' or something like that. All of the sensor grounds come together at that connector so when the resistance goes up from corrosion you can get several fault codes. Under the seat near the ECU is a two wire connector, you put a wire in it to connect those to each other and the FI light will flash the fault codes.
Is your FI light coming on, or flickering at all?
Measuring/copying just ain't gonna work. Send me the wheels and I'll engineer some proper spacers. When I get done enjoying the wheels I'll send them back to you with the spacers.
Blackbird drag race parts
superhawk996 replied to jon haney's topic in The Sales Floor -- For Sale/Wanted
I'll take it, PM on the way. -
Yup. I'm still waiting to hear the price on the ignition system, but this other stuff is very interesting. -
No reloading press? Vise? Milling machine? Motorcycle lift? Not even a fuckin tool box?!?! I expect to see at least one corner of the man card voluntarily relinquished. But really, that's a pretty bitchen table. I doubt I'd ever even considered making something like that. Nice job.
Wow, that thing is fucked.
If injection started shortly after valve closing, which after a quick googling seems pretty normal, it would allow for about double that 250 degrees of crank rotation time needed; wouldn't it? As far as a good engineering book, I have no idea what to search for; can you suggest a good one? -
Split the difference and target 181. And yea, mine might be way the hell off. I do so much by feel that I rarely think about specs. On stuff like this I feel for the part to be bottomed out plus a little bolt/stud stretch. Next time I'm in there I'll try to remember to check them just for kicks.
Yup. I always use my in.lb. wrench for lower torques like this. Tho I've not tested my big ft.lb. clickers, I'd be leery of them at such low settings.
That's exactly what sequential injection means from everything I've read. There's a sequence of events and the events are the injection and valve movement. Tho probably not spraying at open valve, but attached to the timing of the valve opening. Regardless the exact timing, whether it be at open valve or XX degrees before opening, there's one shot per intake stroke. If that's wrong, please explain what you know about it. As for the timing, I'd a assume that shooting it before valve opening, and possibly right after valve closing, would allow the fuel time to vaporize and the engine would run cleaner. Maybe shooting at open valve under heavy load to get a little better cylinder cooling. Just theories, I've never even thought of the timing 'till now. Injection timing is adjustable on two of my cars, would be interesting to play with it. -
Haynes is WAY off. '97 factory manual calls for 21nm./15 ft.lb. But the '99-'00 manual calls for 20nm/14ft.lb. like the Haynes. Honda calls them 'exhaust pipe joint nut'. I've always just done them by feel, but if I were gonna use specs I'd use the newer one.
BTW, the fact that diesels run super lean is unknown by MANY people who know about engines. I put my van on a smog test machine just for fun (wanted to see how dirty my waste oil fuel was compared to real diesel fuel) and right away the tech said "this thing is running super lean, you need to fix that". The oxygen percentage of the exhaust indicated a guesstimated 50:1 air/fuel ratio. This guy has been an engine tinkerer for decades and can't wrap his mind around the fact that diesels don't rely on air/fuel ratios. -
If Subaru is so retarded that they don't use sequential injection, which I assume everyone does by now, then that could cause damage. For all the others that do use sequential injection, which has been pretty standard since at least the 90's, it shouldn't be a problem. I can't imagine Subaru is that retarded so I'm guessing those kaboomed Subarus weren't stock and had some tuning done that may have fucked with injection timing. Also some 'tuned' turbo cars use an auxiliary injector to supply extra fuel on demand through the air intake, in those cases cutting the port injection would cause a lean condition. -
That article is full of retarded shit. The photo is of a guy holding pistons from a Diesel engine, which run super lean all the damn time and generally outlast gas motors. The beginning text is about 2 strokes being extra susceptible to lean mixtures because of the lack of fuel; no. It's because in a 2 stroke running pre-mix the fuel is carrying the only oil the engine gets so a lean mix means a lack of oil. The retardedness continued so I kinda tuned out. -
How are the millions of factory turbo cars surviving? I don't see how giving the cylinder no fuel can be damaging, please explain.
