Content Count
187 -
Calendar
Everything posted by JaBr
Long time since I saw one of those π That is referring to the test type if I recall correctly, I have personally imported the vehicle so it's an import test. Buses / Taxis and some other classes of vehicle have an annual roadworthiness test and that entry on the certificate would be different despite them also being imported.
I know, strange combination π You can ride it as long as your insurance company is willing to cover you. Mine was willing to risk it so no issue. I'll be able to use it once I get the new numberplate, which should be Monday.
So that's that then. Blackbird basically done. Off to register it now Mine's one of the very early ones, registered 11th September 1996. I bought her 1st April 2019.
So, in the next couple of hours I should have my nice shiny certificate that allows me to register the blackbird on the island. All they have to check is that the rear indicators work. Fingers crossed I got it right this time π After that it's a case of register (Β£48) and ride.
Unless you live in the Uk where you aren't allowed to register one
π To be fair, on the island we only have to get the vehicle tested once in it's lifetime as long as we keep up the road tax each year. Road tax is currently Β£25 per year, you have to also provide proof of insurance when taxing. Insurance for the bird is about Β£280 per year for me. So basically you can still have a deathtrap as long as it's taxed π
So on Thursday I put her in for the test, unfortunately she failed on the rear indicators. My fault, I'd been going to rewire that section and settled for a connector instead, all worked fine as I left, by the time I reached the test centre the connector had vibrated loose and they weren't working. On the plus side, that was the only failure and can be retested in a few minutes when I take it back. Have paid for the retest and now just awaiting the appointment.
Basically a bridge rectifier. I'm no electronics expert but I do like going through things like this
There are indeed two on the other side as well. Clever design now I look at it more closely.
It's possible I guess, although they have 2 conductive tracks on each side of the part that inserts into the holder, I would expect that negates the need to turn them 180 degrees. I received 10 x T5 triple LED bulbs yesterday for the heater controls in my MiTo, same concept. These new ones are pretty cool though, supplied in a strip rather than as small modules. Pretty sure they're hand assembled, the top led's at least.
Always Grandpa, always π
50 years ago I was barely an embryo π
It's very old british humour Want some classics? Radio comedy, Hancocks half hour, The navy lark, the goon show, Round the Horne TV, Only fools and horses, Morecambe and Wise, Benny Hill
All I used was standard white LED's T10 Canbus compatible. The blue is basically because of the brighter white light, the filter appears green with a standard yellow lamp because of the colour mixing. The ones I purchased are These LED's The price has nearly doubled, I paid Β£3.95 for 10, they seem to be Β£6.95 now. They are easy to fit, get the screen off and you can access the rear of the clocks. There are 4 large bulb holders spread across the rear of the clocks with T10 capless bulbs in. Swap these out for the LEDs and make sure they all work before rep
Not yet, have the film, just completely forgot to fit it, d'oh!
That's never a good sign
Thanks man, it's in the final stages of repainting at the moment, hoping to get it back in the new year sometime, kind of tricky to get it finished when the UK is on lockdown. I'm on the Isle of Man and still have that bike and a car in the UK, depending on the situation ref Covid I may see them again by the end of the 2021.
90-93 VFR was the best of the bunch, mine is a '90, first bike I bought when I passed my bike test, love it to bits, and seriously would choose to ride it over the blackbird in most instances. I will give up my VFR when they pry the key from my cold, dead, fingers
So the last few bits I've done have been to mount the cans, side and v-panels, and an oil change. The video I posted earlier was the engine warming prior to draining the old oil and swapping the filter. The cans were a bit of a pig to get on as the joints on the can were slightly smaller than the graphite gaskets, one of the tabs on the right hand can started to crack and go the same way as the original can, luckily I managed to get the gaskets on the collector easily and gently persuaded the cans on with a leather hammer. Took a while and a lot of care but I got there in the end
So this week I finally got to do a few more things, this is the first time she's been run since May this year, half a doze turns of the engine and away she went. Restarts have been instant since then. To say I'm happy is an understatement, there are a couple of niggles to sort out, a small water leak on the water pump hose, and a minor blow at the exhaust headers, but they are tiny compared to what has been achieved over the last 7 months or so. Not bad for someone with little experience of working on motorbikes, and thanks, in a large part, to the generous support and knowledge
π. Of course. Iβm not likely to get to it soon, still waiting for these exhaust cans to show up, hoping they come this week as Iβm off until 4th January from Christmas Eve. Weβll see what happens I guess.
Sean has got back to me and says the gears are made from: SCM415(Chrome Molybdenum) So essentially it is an alloy of steel.
I emailed the company to be sure, this is what they sent me. As soon as they come back with confirmation I'll post it. Hello Jason This is a product we bring in. We donβt manufacture it. As far as I know gears are made from a hardened steel. What I do know is we have been selling them for many years and never had one back with damaged gears. They do seem very tough. Iβll ask the supplier and see what they say. Best
I'll have to get the magnet out and check later. Brand is Morgan, the people who make the CarbTune
