Carrying a motorcycle on a truck...ramp, hitch carrier...both...
superhawk996 replied to SwampNut's topic in The Garage
I would use only the finest Chinesium tubing stated as being super strong. 2" square tubing should be enough, but they sell couplers for 3" so I might go the overkill route just to feel good about it. -
I can think of two easy DIY bolt-on extensions that won't require modding the trailer. A straight square tube from the front of the frame extending under the coupler as far as needed, or a T attached to the V section of the tongue and extending forward past the coupler. The front part of either could be attached to the existing coupler by installing a ball on it, the rear could be U-bolted or through bolted with nuts. -
A bed extender would solve the bike hauling, but not allow the trailer unless you did an extended hitch which is gonna suck for weight distribution. One option would be to extend the trailer's tongue, that would allow tailgate down while reducing tongue weight, and allow for using the distribution hitch if wanted. I bet it wouldn't take much to create a "bolt on" solution rather than doing a permanent tongue mod. -
If the tailgate can be removed and the bike will fit diagonally, that would let you tow the trailer. Or maybe with the tailgate partially open. -
A carrier would probably be easiest and possibly most aerodynamic if it's low enough, but probably limited to one unless you make something. To carry both I'd say bed, or maybe the zero in the bed and XR on a carrier. -
1997 hydrolocked? Not. Update on latest post
superhawk996 replied to Dotetcher's topic in The Garage
Mouth suction is more than enough to open it, it doesn't take much. If the gas isn't super old, my guess is that the carbs need cleaning. The fact that it's trying to start says that it's very unlikely to be a battery problem. -
Something I forgot to say; if it has LED taillights they probably won't do the goofy open ground stuff I mentioned, I've never tested it, but guessing not. If the light only has two wires then it's being internally grounded by the mounting screws, usually only one of them. If it has an external ground wire it 'should' be white and is almost always attached to one of the light's mounting screws, or it'll have its own screw. I've never seen a trailer that had a ground wire going back to the lights, they're always frame grounded at each end. If it uses normal bulbs check it, trailer bulbs and bulb sockets shit out way faster than on a car. I can't imagine the axle causing it. The hub could if it was machined wrong, super loose bearings might be able to cause it. Either can be easily checked.
When a trailer light has an open ground it'll usually do weird shit like flash all the running lights when you hit the turn signal and light them all with the brake applied. If they're wired straight to the vehicle's taillight wiring the car's lights will also act up with turn and brake.
Many, maybe most, trailer lights ground through the mounting studs/screws. First thing I'd check is the weights to make sure they didn't fall off, next would be to spin the tire and make sure it's not out of round. I had a clip-on weight fall off about a mile from the tire shop, and watched a stick-on fall off Carlos's dirt bike while it was just sitting there.
How else am I to stoke the fire?!?! But no, this is a proper Blackbird, the original fastest bike in the world, not that white thing with fuel infection. Which was beautiful. This one's living outside for now, but I'm glad you mentioned that because I've been considering moving it indoors. -
No, the valve is in tact and normal. I added a piece of vacuum hose, the new and original hoses connect to eachother with a barb fitting just below the fairing on the left side. Since the bike sits a lot I wanted an easy way to drain the carbs. Before parking it I disconnect the hose which shuts off the fuel flow so I can run the carbs dry. When I want to start it again I suck on the hose connected to the diaphragm to prime the carbs instead of cranking a long time. Then I reconnect the hoses and fire it up. If the diaphragm were to fail while parked it would empty the tank onto the ground instead of into the engine. I originally planed to use a tiny ball valve, and as often happens I couldn't find it when I wanted it so I just did the barb fitting as a temporary fix...about a year ago. -
If/when the diaphragm goes bad gas can go through the vacuum hose straight into the intake port. A bad float valve 'should' send the excess gas out of the overflow onto the ground. -
Actually, I just realized that mine can't because I've by-passed the vacuum line. Fuck you beetlejuice! -
No, that's an EFI only thing. The carbed bikes could become flooded due to a failed fuel shut-off valve. Hasn't happened to mine...and I might have just summoned Beatlejuice. -
Well duh. You can't just go and cut a strap willy nilly, you'd need a hot knife cutter which will require lots of input. But seriously, not having a bunch of strap to have to secure makes life easier. A less permanent alternative is to roll up the excess and zip tie it...and figuring that out 'should' only take two pages and three failed attempts.
Are you going to commit and cut the excess off the straps?
Take note of the chain guard RXX, I think someone here has been holding out.
Crash protectors? All I see is a large round pillow for a proper nap.
*SOLD* 1997 CBR1100XX Blackbird for sale
superhawk996 replied to Chewtoy's topic in The Sales Floor -- For Sale/Wanted
Thanks, I feel better. -
Can't post to Buy/Sell section.
superhawk996 replied to Zero Knievel's topic in Board Tech Issues & Help
I got the 403 recently when I quoted Dave including the thread title. Then the site seemed to go down so I assumed that the 403 happened because the site was crashing...and hoped I wasn't the cause of the crash. Tried the next day, same 403, but the site didn't crash. -
I'm so accustomed to every sale being half way across the country that I didn't bother getting excited about it, and just noticed that he's local, dammit. -
And in case you don't know, if you have multiple codes or an intermittent code you probably have a failing test connector.
Carlos and I texted about it and I almost suggested asking you about helping them. And I suggested telling them about Jeff's shop. I have no idea how they are, but figured that they probably wouldn't bone family.
I no longer smile at cops, just a friendly wave.
