ptxyz Posted August 21, 2016 Share Posted August 21, 2016 (edited) while doing the pair delete and changing spark plugs (i now realize i coulda left the lowers on...), i noticed this. appears to be an oil tube, perhaps 30-40% restricted with that kink. should i be concerned? is this something that can easily be replaced? it's not clear how the tube attaches on the upper end. i also see a slight bend to the lower right corner of the radiator. this poor bike musta had a pretty hard down on the right side. on a perhaps related note, i've had the oil analyzed (pdf report attached below) and there's a bit of copper indicating wear of a bushing or bearing. could it be a flow restriction here is causing accelerated wear somewhere downstream? bummer, when i "upgraded" i just traded one set of issues for another, ha ha! 01 CRB 1100XX-081416.pdf Edited August 21, 2016 by ptxyz Quote Link to comment Share on other sites More sharing options...
redxxrdr Posted August 21, 2016 Share Posted August 21, 2016 Could it be item #1? A oil pipe Shown here? If so, it looks like it would change out. Quote Link to comment Share on other sites More sharing options...
ptxyz Posted August 22, 2016 Author Share Posted August 22, 2016 (edited) thanks for the hint, craig. hadn't looked at the part diagrams yet, i think it #9 here; http://www.ronayers.com/oemparts/a/hon/506c1ffbf870023420a2f606/oil-pump if that's the case, less worrying as it's a return tube. kinda strange, the lower end is held in place by a stay plate but, there doesn't appear to be anything similar on the upper end. Edited August 22, 2016 by ptxyz Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted August 22, 2016 Share Posted August 22, 2016 If it's not leaking, leave it. I don't see any serious obstruction to worry about. Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted August 22, 2016 Share Posted August 22, 2016 It's a return, #9. As far as whether it'll be a problem, all depends on how much oil needs to flow through it. Looks like you'd have to drop the pan to replace it. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted August 22, 2016 Share Posted August 22, 2016 13 minutes ago, superhawk996 said: Looks like you'd have to drop the pan to replace it. If that is so and being a return, I would have to try to forget about it but things like that bother me. Quote Link to comment Share on other sites More sharing options...
