brianmacza Posted May 27, 2008 Share Posted May 27, 2008 My '97 had overheating issues a year ago - replaced the water pump and all was well. I found that the impeller on the water pump was so corroded that a couple of blades had vanished and the ones that were still there pumped poorly anyway. How often did you change the coolant (if you had the bike for some years) and if so, what brand did you use? I got the bike in Feb 2005 - it had plain water in it. I refilled with 100% Castrol brand antifreeze (which was the best available at the time). The water that came out WHEN I flushed and refilled was absolutely clear. Never did find the bits that broke off... Quote Link to comment Share on other sites More sharing options...
bartonmd Posted May 28, 2008 Share Posted May 28, 2008 My '97 had overheating issues a year ago - replaced the water pump and all was well. I found that the impeller on the water pump was so corroded that a couple of blades had vanished and the ones that were still there pumped poorly anyway. How often did you change the coolant (if you had the bike for some years) and if so, what brand did you use? I got the bike in Feb 2005 - it had plain water in it. I refilled with 100% Castrol brand antifreeze (which was the best available at the time). The water that came out WHEN I flushed and refilled was absolutely clear. Never did find the bits that broke off... If it was plain water, that was one problem (dielectric corrosion... the water will be clean because it deposited its minerals on the metal surfaces of your engine. Coolant may have been another problem... A lot of coolant has "silicates" in it to clean (unless it's the factory Honda coolant, or DexCool) your engine of the gunk that the water and coolant leave behind. Aluminum and the kind of rubber gaskets and such in an engine built for silicate-free coolant (like the Blackbird is) is bad on gaskets, impellers, and radiators... Mike Quote Link to comment Share on other sites More sharing options...
goncallf Posted April 25, 2018 Share Posted April 25, 2018 And what about the problem of the fan getting weaker? Quote Link to comment Share on other sites More sharing options...
XXitanium Posted April 26, 2018 Share Posted April 26, 2018 1 hour ago, goncallf said: And what about the problem of the fan getting weaker? Are you experiencing this? What year is you bird? Any modifications? My stator went outin extremely heavy traffic crossing The Soo a couple years ago. I've been kicking around the idea of a second auxilliary fan mounted next the the OEM one. There's a thread here somewhere. Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted April 26, 2018 Share Posted April 26, 2018 4 hours ago, goncallf said: And what about the problem of the fan getting weaker? Ride faster, make wind. But really, is yours noticeably weaker than it should be? Quote Link to comment Share on other sites More sharing options...
XXitanium Posted April 26, 2018 Share Posted April 26, 2018 Quote Link to comment Share on other sites More sharing options...
silverbird1100 Posted May 3, 2018 Share Posted May 3, 2018 Anyone with ceramic coated headers notice a difference? Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted May 4, 2018 Share Posted May 4, 2018 I can't say for sure because I ride so sporadically, but they seem to help with the felt heat. The fact that it has left my mind is an indication, but I haven't ridden with them in hot weather and slow traffic in a long time. I checked the header temp at idle and I believe it was around 400F stock and 300F coated. I'm pretty sure I posted the numbers shortly after testing so the real numbers should be here somewhere. 1 Quote Link to comment Share on other sites More sharing options...
silverbird1100 Posted May 7, 2018 Share Posted May 7, 2018 (edited) On 4/25/2018 at 9:28 PM, XXitanium said: That's pretty cool, do you get less heat on your legs as well or just lower temps? Edited May 7, 2018 by silverbird1100 Quote Link to comment Share on other sites More sharing options...
XXitanium Posted May 7, 2018 Share Posted May 7, 2018 It's on my wish list. I haven't done it yet. Quote Link to comment Share on other sites More sharing options...
