TPXX Posted October 16, 2007 Share Posted October 16, 2007 Other than throttlemiester are there any good throttle locks? I have a NEP on now put it is kind of draggy when off or if adjusted then it does not grip tight enough when its on. What are you guys using? Quote Link to comment Share on other sites More sharing options...
Jaygermeister Posted October 16, 2007 Share Posted October 16, 2007 Chewing gum and a zip tie.....just don't plan on stopping any time soon. Quote Link to comment Share on other sites More sharing options...
Hobicus Posted October 16, 2007 Share Posted October 16, 2007 Ask you buddies on the C-14 board......... I like the Throttlemeister, sorry. Quote Link to comment Share on other sites More sharing options...
John01XX Posted October 16, 2007 Share Posted October 16, 2007 I sell alot of the Vista Cruise at $25.00 Quote Link to comment Share on other sites More sharing options...
TPXX Posted October 16, 2007 Author Share Posted October 16, 2007 Ask you buddies on the C-14 board......... I like the Throttlemeister, sorry. You mean the other C-14 board?? While they are technically and informationly very helpful, they do not have the fucktard mentality! And no Rich either! You're like crack man! Or is that your crack man? Quote Link to comment Share on other sites More sharing options...
Hobicus Posted October 16, 2007 Share Posted October 16, 2007 And no Rich either! You're like crack man! Or is that your crack man? You'll lick my crack, man? I'm your crack man? Quote Link to comment Share on other sites More sharing options...
Jaygermeister Posted October 16, 2007 Share Posted October 16, 2007 they do not have the fucktard mentality! I don't know what you mean........... Quote Link to comment Share on other sites More sharing options...
TPXX Posted October 16, 2007 Author Share Posted October 16, 2007 And no Rich either! You're like crack man! Or is that your crack man? You'll lick my crack, man? I'm your crack man? they do not have the fucktard mentality! I don't know what you mean........... See! Ya'll know what I'm talkin bout!! Quote Link to comment Share on other sites More sharing options...
Para045 Posted October 16, 2007 Share Posted October 16, 2007 I sell alot of the Vista Cruise at $25.00 +1 I have the Vista and love it Quote Link to comment Share on other sites More sharing options...
JuXXtin Posted October 16, 2007 Share Posted October 16, 2007 Is this another Kawi thread in disguise?? Quote Link to comment Share on other sites More sharing options...
TPXX Posted October 17, 2007 Author Share Posted October 17, 2007 Is this another Kawi thread in disguise?? It appears so although I specifically did not mention for which bike. A lot of haters in here! When I had the warrior the haters were not around, hmmmmm.... are they having C-14 envy? Quote Link to comment Share on other sites More sharing options...
Byrdman Posted October 17, 2007 Share Posted October 17, 2007 I've had both, the Vista Cruise and the Throttlemeister and prefer the Vista Cruise. It weighs nothing, when installed correctly it's 1000 times easier to use, and it costs a fraction of it as well. Quote Link to comment Share on other sites More sharing options...
TPXX Posted October 17, 2007 Author Share Posted October 17, 2007 Thanks guys, I will look at the Vista cruise. Is there no drag when it is not engaged? Quote Link to comment Share on other sites More sharing options...
Para045 Posted October 17, 2007 Share Posted October 17, 2007 Thanks guys, I will look at the Vista cruise. Is there no drag when it is not engaged? Not if you set it up correctly, it can take a little to get it perfect but then it never needs touching although I did put some blue Loctite on the tension screw to stop it moving Quote Link to comment Share on other sites More sharing options...
Jaygermeister Posted October 17, 2007 Share Posted October 17, 2007 Someone at one time had posted or showed me that they had changed out the hex set screw on the NEP and replaced it with a thumb type screw from Home Depot. This way you can adjust it on the fly. See, I can be helpful every now and then. Quote Link to comment Share on other sites More sharing options...
TPXX Posted October 18, 2007 Author Share Posted October 18, 2007 Someone at one time had posted or showed me that they had changed out the hex set screw on the NEP and replaced it with a thumb type screw from Home Depot. This way you can adjust it on the fly. See, I can be helpful every now and then. You were SOOOOOOO helpful at TEXXT! Thanks for the memories!! Quote Link to comment Share on other sites More sharing options...
Jetfixxr Posted October 19, 2007 Share Posted October 19, 2007 I sell alot of the Vista Cruise at $25.00 I got a Vista from John and did a little mod on the installation and have found that it works pretty well for me and campared to the cost of the other ones out there, i have to vote for the vista cruise. Jet Quote Link to comment Share on other sites More sharing options...
prs Posted October 19, 2007 Share Posted October 19, 2007 my vista cruise works super. love it. but what a hassle installing. took about an hour with tinkering. i drilled a hole and installed a screw in the plastic to make it solid. did the same for my daughters 600zzr, and she loves it. my 12r buddy saw it and did the same. Quote Link to comment Share on other sites More sharing options...
Jaygermeister Posted October 19, 2007 Share Posted October 19, 2007 Someone at one time had posted or showed me that they had changed out the hex set screw on the NEP and replaced it with a thumb type screw from Home Depot. This way you can adjust it on the fly. See, I can be helpful every now and then. You were SOOOOOOO helpful at TEXXT! Thanks for the memories!! Apple pie, apple pie, apple pie, you did it to yourself!! I still got your back no matter what!! Quote Link to comment Share on other sites More sharing options...
CALCXX Posted October 19, 2007 Share Posted October 19, 2007 Don't laugh, I have used a rubberband for years when I know I'm going to do a full day freeway drone. I remove the rubberband when I get to the twisties. You can get this crusie control for free. I like the rubberbands they use to bundle asppergas. (sp) Quote Link to comment Share on other sites More sharing options...
Jetfixxr Posted October 20, 2007 Share Posted October 20, 2007 my vista cruise works super. love it. but what a hassle installing. took about an hour with tinkering. i drilled a hole and installed a screw in the plastic to make it solid. did the same for my daughters 600zzr, and she loves it. my 12r buddy saw it and did the same. That's the method i used, it's great. Jet Quote Link to comment Share on other sites More sharing options...
RXX Posted October 21, 2007 Share Posted October 21, 2007 OK, so nobody has stepped forward to recommend the Throttlemeister? Overpriced? Like a Ruth's Chris steak It is a satisfying little doo dad, though. Not hard to use. Pretty to look at. We have all spent more on less. Maybe not the best VALUE, but a neat farkle Quote Link to comment Share on other sites More sharing options...
Byrdman Posted October 21, 2007 Share Posted October 21, 2007 Overpriced? Like a Ruth's Chris steak Any steak that's brought to your table sizzling in a pool of butter can't be overpriced! Quote Link to comment Share on other sites More sharing options...
Jaygermeister Posted October 21, 2007 Share Posted October 21, 2007 Overpriced? Like a Ruth's Chris steak Any steak that's brought to your table sizzling in a pool of butter can't be overpriced! Dammit now I’m hungry……….. Quote Link to comment Share on other sites More sharing options...
RXX Posted October 21, 2007 Share Posted October 21, 2007 Overpriced? Like a Ruth's Chris steak Any steak that's brought to your table sizzling in a pool of butter can't be overpriced! That's the point I was trying to make. Vista Cruise = Bonanza Throttlemeister = Ruth's Quote Link to comment Share on other sites More sharing options...
