Jetfixxr
Everything posted by Jetfixxr
  1. Jetfixxr
    Seat
    The custom look is very nice, thanks guys for the suggestions. Jet
  2. Jetfixxr
    Seat
    I am so effing pissed, I mean royally, I was in my garage moving some crap around, my factory seat was on the bench minding it's own ass, my custom seat on the bike. Well something fell and poked a hole in my factory seat and I am looking for advise on a fix, or how to approach this shitty little issue... Thanks folks Jet
  3. Its pointless for us in that the thermal exchange of the exhaust header is sufficient enough that Honda engineering did not require the manifold be wrapped or any other type of barrier to keep the heat in the assembly for emission or otherwise. Wrapping an exhaust is generally done when the engine and pipes don't get hot enough and subsequently you end up with moisture under the wrap resulting in rust to the pipe in places that you wish it hadn't. If you listen to our bikes idle it's an off beat non consistent "I just want to YELL!!" tone. Our engines were for the most part a racing engine. However check this out... http://www.centuryperformance.com/exhaust-header-heat-wraps-do-not-use.html So, in light of this. I say pointless for us to do. Jet Now if you really want to improve the manifold, send it out and have it ceramic coated. Jet
  4. Check it my 97 the upper is low beam and bottom is high beam.
  5. what year is your bike? 1997
  6. Anyone out there put LED's in the cluster?? Jet
  7. Is that the output over the entire rev range, or at idle?? Make a measurement from idle all the way up to 6k or more, tell us what it does. If you can blow two bulbs in 15 minutes, it is hard to believe that your RR is working properly. Failure to regulate can be caused by the RR being bad, or by a poor connection. It will transition from 13.8 to 14.03 from idle to 6k I am going to swap in a R/R and see what it does, i have a spare but it will really piss me off that the RR is bad. Jet.
  8. Now i put a pair of plain old phillips H7's in and they lasted 15 minutes, so here we go....last thing that changed on the bike before I started having issues was the battery, so back to S1, new battery, new headlights then we will see. I sure hope the RR is not bad.. Jet
  9. That's what i am going to install next. Just 2 plain jane h7 bulbs. Jet
  10. Jetfixxr
    Headlights
    Guys, i am stumped, i have even replaced the little connectors behind the light between the harness and the bulb. i am Effing stumped. My output with the engine running is 14.03 battery charged and i don't know what else 21k on the bike, the headlight relay is working. Any ideas??? Jet..
  11. I had a Zero G touring on mine but still got blasted, i just put a cheap bubble on it to try out but i think i will end up with a Vairo Touring. Jet
  12. They spin in the barrel of the bar. pisses me off Jet
  13. My bar end weights will not tighten up anybody have any suggestions? Thanks Jet
  14. Jetfixxr
    Fuel
    Guys, i am getting a small whiff of fuel every now and then, anybody have any ideas? I am a little concerned especially when my son noticed it other than that the bike runs great, on the freeway 75mph at 4k with the #18 front sprocket. Thanks. Jet
  15. Best bang for your buck to the point you will NOT regret it, i put one in and it is awesome. Jet
  16. That's great but i am sure there is a smaller led to display voltage, i am working on finding a low voltage sensor that has a light, that's enough for me. Just something to alert me that i am not charging. Jet
  17. I have a '97' with 13500 on the clock. And yes it rocks!!! Jet
  18. Jetfixxr
    Milage
    So far i am getting between 37 and 44 mpg and the 44 is if i ride conservativley and i cruise on the freeway at 70-75, i have a 23 mile commute each way and i can do it 5 days a week on one tank. But i have to be "good". Jet
  19. Any steak that's brought to your table sizzling in a pool of butter can't be overpriced! That's the point I was trying to make. Vista Cruise = Bonanza Throttlemeister = Ruth's Same purpose, cruise.....fill a hole and make a turd...LOL Jet
  20. That's the method i used, it's great. Jet
