silvertippr2001 Posted June 8, 2005 Share Posted June 8, 2005 hello.guys.i'm.new.here I'm.having.problems.with.the.ecu,is.been.giving.the.tps.code. I.have.a.99.bird.with.13k.on.it,can.some.one.tell.me.if.is.adjustable.or.not. and.if.some.one.has.the.info.on.how.many.volts.or.omh.dose.it.throws,so.I.can.check.if.is.the.sensor.or.the.hardness. thans.for.any.help,I'm.desperado Quote Link to comment Share on other sites More sharing options...
superblkbrdxx Posted June 8, 2005 Share Posted June 8, 2005 how does it run? Quote Link to comment Share on other sites More sharing options...
silvertippr2001 Posted June 10, 2005 Author Share Posted June 10, 2005 well.I.could.tell.you.that.runs.pretty.normal.exept.for.the.fact.that.it.feels.like.the.revs.ar.slow.and.when.the.f1.ligth.turns.on,it.tops.out.at.10k revs.and.dosen't.go.all.the.way.to.11.5k.like.she.normaly.do. it.feels.like.she.is.going.lean I.realy.don't.now.what.to.think.because.I.would.like.to.be.shoure.before.I.bye.the.(tps) thanks.for.what.ever.help.you.or.anyone.could.give.me Quote Link to comment Share on other sites More sharing options...
demon Posted June 10, 2005 Share Posted June 10, 2005 Look above, oh new one. The XX gods are smiling upon you. Not automatic. 8) Quote Link to comment Share on other sites More sharing options...
silvertippr2001 Posted June 14, 2005 Author Share Posted June 14, 2005 PLEASE!.HELP I'm.having.big.problems.with.my.bird it's.stil.with.the.F1.light.on.and.the.tps.code I.have.not.found.the.problem.yet I.spoke.with.the.honda.dealer.here.and.they.told.me.that.the.tps.on.the. bird.its.very.hard.to.fail.and.that.if.it.is.the.tps.,the.thing.dosent.get.sold by.it.self,that.I.have.to.get.the.complete.throttle.body. They.told.me.to.verify.the.hardess.(did,that)and.test.the.TPS(don't.now.how) If.some.of.you.could.give.me.any.light.on.this.I.realy.be.thankfull P.S I'm.going.nuts Quote Link to comment Share on other sites More sharing options...
XXTi Posted June 15, 2005 Share Posted June 15, 2005 You should verify that your main grounds are clean and tight. They are the green wires on the left upper frame rail near the battery. Then reset your fault codes on the ECU and see what happens. Quote Link to comment Share on other sites More sharing options...
Redbird Posted June 15, 2005 Share Posted June 15, 2005 I think someone has the space bar and the period key confused. Go here- http://www.cbr1100xxforums.org/forum/viewt...?t=1246&start=0 Download what's there, it is what you need for troubleshooting this thing. If you're on dialup, say so and someone will probably help you out with the relevant info. If your TPS is bad, start checking with wreckers for what you need. Dealer is always last resort. Quote Link to comment Share on other sites More sharing options...
silvertippr2001 Posted June 15, 2005 Author Share Posted June 15, 2005 Thanks.for.the.tip.XXTI.I.finish.cheking.the.grounds.of.all.the.bike now.I;m.taking.her.for.a.spin.and.see.what.happens. REDBIRD,thanks.for.the.file,but.I'm.going.to.take.it.to.a.friend.he.has.dsl. oh!.and.I.don't.haved.the.keys.twisted. the.thing.is.that.the.spacebar.is.broken.and.i'm.fixing.my.bird.fist. she.has.her.place.before.the.pc Quote Link to comment Share on other sites More sharing options...
N1K Posted June 15, 2005 Share Posted June 15, 2005 Did you put a new coversheet on your TPS report? Quote Link to comment Share on other sites More sharing options...
willxx23 Posted June 15, 2005 Share Posted June 15, 2005 Did you put a new coversheet on your TPS report? :wink: Quote Link to comment Share on other sites More sharing options...
XXTi Posted June 15, 2005 Share Posted June 15, 2005 Did you reset your ECU? The manual tells you how to do it. Quote Link to comment Share on other sites More sharing options...
silvertippr2001 Posted June 16, 2005 Author Share Posted June 16, 2005 I.think.I.did,XXti.but.I.took.her.for.a.spin.yesterday.but.for.short.time.she.was.runing.good,but.then.it.came.again.the.F......,lite.came.back.on. and.the.problems.again.,the.thing.is.that.this.time.she.started.shooting. throu,the.exoust.cans.and.the.revs.went.down.to.500.or.less.an.she.shot. down.but.did.not.gave.any.problems.to.start.back.on. I.yust.hold.open.the.throutle.all.the.way.to.11.5.and.wen.a.let.her.lose.she.almost.blow.the.cans.of.(caboooooom)and.all.came.back.to.the.normal. 1100.revs. I'm.wating.for.a.friend.to.download.the.file.so.I.can.read.how.to.erase.the.code.of.the.ecu.because.I.think.I.did.but.I'm.not.that.shoore.and.I.have. dialup, XNIKX: what.thats.supose.to.be.,erase.the.ecu.memori? If.is..that.I.shust.wroted.if.not.explain.your.self Quote Link to comment Share on other sites More sharing options...
silvertippr2001 Posted June 19, 2005 Author Share Posted June 19, 2005 hey.guys.right.now.I've.just.about.anything.I.could.think.of.nothing.has. work.so.far,I.just.reseved.the.haynes.service.manual.and.did.step.by.step all.that.has.but.nothing.and.anyway.It.says.that.to.verify.the.TPS.it.has.to.be.on.the.dealer.with.honda.special.electronic.diagnostic.test.pin.box.(don't.now.what.the.f....is.that.thing)It.looks.like.I'm.going.to.die.on.the.dealer.anyway. If.someone.has.any.oder.Idea.please.let.me.now Quote Link to comment Share on other sites More sharing options...
Skull Posted June 19, 2005 Share Posted June 19, 2005 For God's sake spend the $5 and buy a damn keyboard! Quote Link to comment Share on other sites More sharing options...
FloridaSilverBird Posted June 19, 2005 Share Posted June 19, 2005 For God's sake spend the $5 and buy a damn keyboard! Quote Link to comment Share on other sites More sharing options...
silvertippr2001 Posted June 20, 2005 Author Share Posted June 20, 2005 it's.a.laptop :roll: Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted June 20, 2005 Share Posted June 20, 2005 it's.a.laptop :roll: PS2 or USB keyboard would work. External keyboard is the only way to type on a laptop. Quote Link to comment Share on other sites More sharing options...
silvertippr2001 Posted June 20, 2005 Author Share Posted June 20, 2005 thanks Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted June 20, 2005 Share Posted June 20, 2005 I'm reading this thinking it's a translator program from Spanish to English. Sorry, no help for your XX, I'm carbed. I was stationed in PR in 85 and ran all over the island on a 1983 Honda 650 Nighthawk. El Yunque is beautiful. Quote Link to comment Share on other sites More sharing options...
silvertippr2001 Posted June 21, 2005 Author Share Posted June 21, 2005 thanks.Pete! beleve.you,me.is.more.beautiful.,when.youre.on.a.bird when.it.dosen't.have.any.problems.do.jajajajaj Quote Link to comment Share on other sites More sharing options...
