Yup. Most of the high runout tires I've seen were generic, but I had a set of name brand, pretty sure it was BFG, that were bad. One was horrible, one kinda shitty, and the other two not great. The upside is that I got warrantee on them and I bought them used, probably why the guy put them on CL with lots of tread. The model was no longer made so they gave me MSRP credit toward a new set of MTs.
2023 Honda XR150 L (SOLD)
superhawk996 replied to DaveK's topic in The Sales Floor -- For Sale/Wanted
No difference between parked and driving. YUGE difference between you driving it and a cop driving it, he's very unlikely to be hassled after showing his credentials. -
And likely impoundment. -
I saw a great one. Couple criminals with expired registration took the license plate off another criminal's car that had current reg, that car was stolen so they got dinged by a plate reader. Being that it was a felony stop several cops converged, the first cop talking with another said that he would't have even bothered stopping them for the expired reg and they would have gotten away with all the illegal shit they had. It used to be semi-safe, the cop had to run your plate to know. Now that many have automated plate readers in their cars they might get alerted to a plate that they weren't even looking at. If the plate still has current registration then it's probably semi-safe, I don't think the reader can tell that it's on the wrong vehicle. -
A while back I did some reading/listening about the red and yellow dots, I found a lot of contradictory and some illogical information. Yellow is the lightest point of the tire, that was mostly undisputed. Red indicates the highest or lowest part of the tire, that was disputed a lot. If you have only a yellow dot, align it to the stem, mostly undisputed. If it has a red dot and your wheel has a dot, notch, or other marking that shows the high or low spot of the wheel (high vs. low was disputed here also) it should be aligned with the red dot on the tire and ignore the yellow. If the tire has red and yellow and your wheel has no marking, or you can't find it, align the red to the stem and ignore the yellow. That one seems illogical to me. If one wanted to perfect his mounting I think he should focus on the radial runnout of the tire/wheel assembly and ignore the balance since imbalance can be cured with weights. But, getting the runout dialed in would take more work so focussing on the balance point makes sense. I've encountered a few car/truck tires with massive runout. I've never seen it with bike tires, but have dealt with way fewer of them.
Then why go away from what has worked? I know you're not worried about it, but a fake plate is a crime, not registered is just an infraction. -
What's an easy way to turn a simple infraction into a criminal act? -
I know grinding wheels clog up, not sure what a disc will do. Guessing it'll clog and have to melt it's way through, but it might work ok. 3 points was my thought too. I've had some tires that needed no weight when aligning the dot to the stem, seems to often work. The tire shop I use ignores the positioning, the guy said it's pointless. I asked them to do it when they mounted my motorhome tires, apparently one of the guys working on them didn't get the memo. The ones that weren't aligned needed the most weight. I showed the owner, they still don't care.
There's some clown on CL asking $4k for one, I assume he'll have it forever unless someone just as dumb doesn't look at new prices. -
What's your cutting plan? I've had a few car/truck tires I rotated and re-seated to get a better balance, it was fairly easy since I had machines.
Home made tire balancer. It's a little fiddly, but it works fairly well, it's super compact, and was 'free'. It took time and stuff that I had lying around, but no money was spent on it. 4 small ball bearings, 10-32 screws and nuts, and some angle iron. It's fairly easy to detect 1/4oz., below that it gets dodgy. Being that 1/4 is as precise as balancing usually gets, and I don't plan to do any 200MPH rides on this sub-100 MPH bike, I decided that it's good enough. Interestingly, the rear had no weights and is only 1/4oz off with the new tire. The front had a 3/4 oz weight about 2" away from where it now needs between 1/2 and 3/4. I had marked the heavy spot of both wheels without the tires, but the shop cleaned off my marks.
That totally makes sense. The machine has a plastic spacer thing, but it rests on the bottom so it's probably not very helpful with such a heavy item. I'll try suspending tomorrow and see if it works better. Thanks, I'm surprised I'm still going at it. Today I briefly thought- the smart way would have been to commit and completely disassemble it, but I'm 99.999347% sure it would have become a pile of parts for eternity. Much of the motivation is being able to ride it and show it between stints of working on it.
With free shipping you say? SOLD! -
Rabbit hole? What's that? Since the rear wheel was off I might as well tidy things up a little, a few hours later there's probably a couple more to go. The chain spent the day in the ultrasonic being moved around every 8-10 minutes. It only effectively cleans right around the transducer, I think because it's so heavy, and so grungy. While it was being cleaned I pulled and cleaned the chainguard, sprocket, etc. Got the inboard sides of the mufflers, the swingarm, and other stuff that'll be a bitch with the wheel on. The sprocket carrier is being stubborn, it might need to be sanded and then polished to be nice, but I'll probably not go that far for now. The brake carrier will probably be about the same. The aluminum is spotty and darkened; I tried steel wool, a fine wire wheel, aggressive compound, and the discoloration is still there. But they're cleaner and smooth. The left case cover will have to come off to install the chain so I'll probably give it a squirt of black paint to de-ugly it some. The new tires are a fair bit taller and fatter despite being labeled the same size. It's a little easier to get onto the center stand now, I don't know why Yamaha made it so damn high.
I know you don't like to rely on other people's toys, but you/she are welcome to ride mine, someone's gotta do it. I plan to bring it, but don't plan to ride it much. On the off chance that I fall in love with it you guys get a Talon to drive, plus there's likely to be a spare RZR. And there's spare beds.
That somewhat makes sense, but I was stuck thinking more of how it would go for me. I've not put enough time on dirt to get over being scared of it so for me it would be the difference between falling over a lot at under 20MPH vs. taking flight. It'll be interesting to see if the 400 is less scary. Speaking of which, Ocotillo this weekend as long as the weather isn't shitty.
Your XR identifies as electric. It saw the direction your life was going and it's trying to turn you back before it's too late.
Imagine how pissed you'd be if you spent 90% of the money for a bolt-on solution to the problem that merely became a new set of problems. Researching your carb problem lead me to solving mine. The carbs on the R5 intermittently dribbled, polishing the seats mostly cured it. I hope to not go into them again 'till I decide to pull the cylinders for restoration, at that time the carbs will get new seats and needles.
I'm guessing it's because these rims have very little relief in the center. I don't know how common it is, not something I've ever paid attention to. And the tires are stiffer than I expected. There are several parts I've restored that are still available. A couple negatives on new stuff, cost and they'll stand out. I've mostly gotten over the "stand out" issue as everything becomes nicer. Cost: If I were to only replace everything that's available I'd probably be thousands of dollars in, and many more hours or dollars for labor. The rims and spokes can be replaced, not a whole lotta money, but a fair bit of work that I've never done before. I spent less time cleaning the brake lever than I'd spend trying to find a new one. There's also the satisfaction of restoring stuff and keeping the bike original.
Here's my guess: the bike is tall and heavy so it needs a lot of gyroscopic force to stabilize it. Fill the tires with water instead of air and it might become docile.
But heres the catch of this bike and the xr650L, faster you go, better and more planted the bike gets. I mean it gets very drastically impressive once you absolutely commit to it. That's what I was guessing. Just gotta get over the fear and send it, something I'd be unlikely to ever do, but the reward is very tempting.
...or become a helicopter ride. No biggie, a Life Flight ride is usually under $40k.
The beads were super easy to break, they damn near broke on their own. Probably because they're tube type wheels so they don't 'need' the bead retaining bump that most tubeless wheels have. Zipties were a fail. The recess in these wheels barely accommodates one bead, both together is an absolute no go so I cut the ties off and went traditional. Holy fuck that was a battle. Even when there was only about a foot of tire bead under the wheel I still had to use tools to keep prying to get it the rest of the way off, insane. I got the front tire off and pondered how much worse the rear would probably be, at that point I said fuck it and took them to a shop, but the guy was out. After waiting for over 1/2 hour I went back home and figured I'd just work on de-rusting the rear wheel. It would be easiest to work on it mounted to the forks, but it would't fit with the tire on so I decided to have a go at removing it, way worse than the front. I was finally able to get one spoonful of bead pried over the wheel, no way to get another in. I held it and used a die grinder to cut through the tire bead, then it was only a 'normal' battle of stretching it over the wheel. The rear rim was super rusty, some of the chrome is gone, but it cleaned up reasonably well. I didn't take photos of the wheel, but here's the rear brake lever. I had already done the ends when I thought to take the before photo. If I decide to make it better I'll dab some chrome paint on the bare spots to hide them better, but it's vastly improved. It took about 5 minutes, most of the work was done with a fine wire wheel on the bench grinder. I wish I'd tried wire wheels sooner, it does a great job and does't scratch up the chrome as long as it's fine wire. I used two different ones on the rear rim being driven by a cordless drill and die grinder. I had a small one that was able to fit between the spokes fairly well. I took a quick stab at mounting the front tire, fuck that, they're both going to a shop with a machine.
