poida
Everything posted by poida
no way.whoever owns that looks like they do some serious touring.it looks to me either russia or the stans.be good to find out if they have a blog somewhere. nick sanders rode an r1 around the world in 19 days back in 2005
nsw?are you in australia.a 2003 in aus would be digital dash and hiss system.i dont know what the 2001 has.
just saying it has worked well on my bikes.the vfr800 i bought from racer212 had a sargeant seat that was really comfortable.even though i brought my airhawk along with me i never needed it with that bike.a friend of mine has had success with layering different density foams when he has made seats for his trikes.
i use an actual air hawk and have had no issues with damage.it has a non slip base with thin adjustable straps.
how about with varying densities of foam layers.i read somewhere a while back that gel inserts can heat up in the sun and become somewhat uncomfortable.i just use an airhawk cushion when i start getting sore on long trips.works well for me so far.
from memory the seat of my 99 fits my 06 and vice versa.just checked for you.both seats will go on either bikes although it looks like the padding at the front differs.it seems to go higher and a bit more forward on the 06 seat.when i fit the 99 seat on the 06 there is a slight gap between seat and tank.the bases appear the same but i didnt measure them with a tape measure.
check it's not leaking from the seal at the gear shift shaft/easy job to replace it if it's leaking from there
Some fucking Randys from Australia?
have you checked the starter relay plug.on my 99 the plug had corroded .it would let through enough power to turn the lights on and prime the fuel pump but but not enough to start it.
email mario at thunderbikes.i hear that he can sometimes source hard to find parts. https://www.thunderbikes.com.au/shop/
check the small brake light switch on the handlebar lever
more than likely just the small seal on the gearshift shaft.easy to fix
.plus, it's so damn purdy They have aged exceptionally well.
WTB chain and sprocket set
poida replied to Zz want’s an XX's topic in The Sales Floor -- For Sale/Wanted
when the exchange rate was better between U.S and AUS i used to get my kits from sprocket centre.D.I.D zvmx chain and pretty sure i would get the JT sprockets .i always run the standard gearing although the gearing on the U.S bikes are i believe different to ours. -
i have had the oem shock rebuilt on my 99.it was revalved and resprung.i run it on the soft setting when riding solo and adjust it harder depending on luggage and pillion.ive been really happy with it and to be honest the lack of a shitload of adjustment is good for me as i understand the theory of suspension adjustment i just can't put it into practice.
try plugging the o2 sensor back in and see if the fuel gauge works properly,assuming there is fuel in the tank.
ive done 40,000klms on my 06 with the o2 sensor disconnected.fuel economy is still good and the big plus is no more surging while cruising. have a read of this. https://www.cbrxx.com/threads/solved-2005-blackbird-surging-2-3k-rough-running-fuel-plugs-help.5513/page-2
I disconnected the o2 sensor on my 06 with an o2 eliminator plug as it was causing the engine to surge.i want to fit earlier mufflers without catalytic converters on it next.
i got my set from this company. https://www.ebay.co.uk/itm/Steering-Head-Stem-Bearings-Seals-for-Honda-CBR1100-XX-Super-Blackbird-97-08/282804867406?epid=925966833&hash=item41d87bd14e:g:NOwAAOSwG-1WvVr6
been years since ive had to replace dash bulbs but pretty sure i just removed the screen and could access them easy enough
i use one from roadstercycles on one of my blackbirds. https://www.roadstercycle.com/
slime powersport compressor and tyre plug kit.pumping up the tyre on my vfr800 in georgia back in 2013.plugged 2 punctures from 3 inch nails
