blackhawkxx
  1. From what I have read, I'll take .40 over 9mm in the case of stopping bad things happening.
  2. Yep, what Tim said.
  3. Do you wash out your pan or just dump the oil out? If you don't clean it, maybe it is building up over time. The analysis was interesting.
  4. Hey I stopped by too.
  5. Check out the drag bike in the for sale section. I'm sure that he or a couple of others here would be able to help answer your question.
  6. Did you get really bad gas to plug up the injectors?
  7. Hose length would be very hard to measure on the bike. It is hard to believe that they are forgetting about us already.
  8. The color does make it.
  9. He races for wins and championships, so inconsistency makes you a loser.
  10. Well you won't have any trouble finding parts for that bike. I'll be interested to see if you can get the same consistency. The quicker you go, the harder it is to keep it.
  11. As long as the name doesn't start with a K or S. A real man would use a Motor Guzzi.
  12. If this would have been a some years ago, I would have been very interested.
  13. Well, you know when you push the start button, the headlight goes out. Checking out the button would be the first thing that I would do along with the starting circuit. I'm sure others will be along that has been through a similar thing before. I hope that you have a shop manual.
  14. Just to be clear, you can drift start it and it runs fine but the starter will not crank over? Does the taillight and dash lights work?
  15. Someone from here?
  16. I would say, living room.
  17. Why would you pull anything to change the oil in the Bird? You put in on the center stand, reach up under to remove oil filter. If it is too tight, use strap wrench to loosen.
  18. I have used the bolt trick to set a car intake manifold on perfect. It does work well.
  19. I posted about this before but can't find it. The filter is only on carbed Birds as far as I know but mine turned to dust and wanted people to know to check them. You can order the filter from Honda for only a couple bucks so get some oil filters or other OEM parts at the same time if you are ordering on-line. 17254-MAT-000 FILTER, SUB-AIR CLEANER $1.84 http://www.hondadirectline.com/OEMpartfinder.htm#/Honda/CBR1100XX_A_(98)_MOTORCYCLE,_JPN,_VIN%23_JH2SC350-WM100001_TO_JH2SC350-WM101089/AIR_CLEANER_97-98/CBR1100XX-98-JPN-A/14MATVE1AMAT3F2000CA
  20. That is one of the all time greats of how-to. A classic on here. Read that years ago but is very helpful to remind us that don't do it that often.
  21. Yep, square one.
  22. Did you check the valves to make see if anything is going on with that #3 from that end?
  23. Is this you?
  24. One or twice this past year, I bottomed the front which didn't happen in the past. Maybe I just found more dips and bumps but... I have stock weight Honda oil in it that doesn't have that many miles on it. Since I weigh about 175 lbs. without gear, from what I hear, the stock springs should work. I was thinking that it would be a cheap, not too hard of thing to try as long as it didn't make the full travel way firmer.
