http://secure.mycart.net/catalogs/catalog....;showprevnext=1
Connecting the map selection switch allows the rider to switch between two different maps within the Power Commander. For Touring Bikes this could be used to switch between a "fuel economy map" for long rides and a "full performance map."
For sport bikes it could be used for applications such as "dry nitrous oxide" kits to permit the user to make the fuel mixture richer when activating the system. Additionally, if the Power Commander has an ignition module connected it can switch to a less aggressive timing map at the same time.
Gear Position/Speed Input
Fuel and ignition timing (when using the Dynojet Ignition Module) adjustments can be made based on gear position or speed. If the user wants to advance the timing in lower gears while retarding it in higher gears this input makes that possible. (+/- 50% Fuel and +/- 10 Degrees of timing per gear)
Pressure Input
When using a Power Commander on turbocharged applications, the Boost input option (0-5v input) makes it possible to have the fuel automatically increase with boost level. In situations where the user has an adjustable boost controller, this makes remapping each time the boost level is changed unnecessary. (+/- 50% Fuel and +/- 10 Degrees of timing)
Relay Outputs (2)
Based on the data from the Power Commander and the inputs from the Multi-Function Hub, a solenoid, relay, warning light, etc. can be triggered. This can be used to activate items such as a shift light, nitrous oxide system, or air shifter. (Activated based on Throttle % and/or RPM, 3 amp max output)
Now you can get many of the functions more expensive aftermarket ECU's offer! Automatically shift your bike (w/air shifter), activate your nitrous system (with dry nitrous kit), and automatically add more fuel!
Includes:
Full Installation Instructions
Wiring Diagrams
Voltage Charts for WBC and GM 2/3 bar Sensors
CD with Updated Software
Dynojet Tech Support - tech@powercommander.com
