jon haney
  1. I think I need his scale for my bathroom. Not buying the 451. If it had CF wheels, fairings (including tank), and sub-frame, it might be close. Pretty sure thats a TI pipe.
  2. Very nice way of saying I'm old. LOL.
  3. Just picture yourself doing 100+ MPH, tight corner coming up quick, grab a handful of brake lever, and the discs are ripped from the wheel. You know the rest. My advise? If possible, I would use the discs that were meant for the wheel you are going to use.
  4. Not sure you can get those in stainless. Maybe after-market covers come with s.s. screws?
  5. That was my second guess. The kid that bought my other Bird did the same thing, only he went with white fairings. It looked pretty good, too. Don't remember what brand he bought, but he said they fit very well for China stuff. Haven't seen him since before covid.
  6. Please tell me you haven't put additional scuffs on my baby, already. I miss her.
  7. LMAO. That's brilliant.
  8. Try this one. I have this one in the back of my truck. Very small rolled up, but of course, more tools equals bigger roll. https://www.amazon.com/ROADGEAR-Sport-Touring-Pouch-Yellow/dp/B00N372SM0
  9. We didn't get the CB1300 over here, so responses will mostly be limited to members who live in the eastern hemisphere.
  10. Yes, that's how I measured my sag, and looks like I have some of the "good" forks. The air-gap size vs. sag thing could be measured, if stiction was completely eliminated. Of course, that is not practical. Even then, it would probably be less than a millimeter, but physics dictates that there would be a difference (everything else being equal). A practical difference? No.
  11. Large air gap vs. small air gap (reasonable), there would be slight difference in static sag. However, I would bet that the "stiction" range would be more than the sag difference.
  12. jon haney
    Honda cbx1050
    I have to admit I prefer sounds that are made with an engine, but being able to fully hear the tires squalling around a corner would also be cool.
  13. jon haney
    Honda cbx1050
    LMAO!!! Sorry, Tomek.
  14. I always feel great when my gas-powered equipment starts and runs well. For things that get used on a very regular basis (car, truck, Triumph), I will use the 10% ethanol. Everything else gets non-ethanol fuel, and a splash of fuel preservative over the winter, or if it goes unused for more than 6 months. Some might call it a ton of prevention for an ounce of cure, but I have some fairly old equipment that still runs great.
  15. Tires are cupped.
  16. So, I wonder how long it will take the owner of that last bike (extended swing-arm) to realize you can't bolt the exhaust can to the swing-arm, if you are still running a shock? 🙄
  17. Now that's a Pimped-Out Bird.
  18. jon haney
    Valves
    IIRC, shims for the early CRF-250 (or was it the 450) will also work, and they have a larger range of thicknesses.
  19. Check all the grounds when you install that new R/R.
  20. Show bike. Not intended to be ridden in traffic on a hot mildly warm day.
  21. I kind of like #5.
  22. jon haney
    Brake problem
    In Zero's defense, if one is OCD enough to thoroughly swab out the reservoir, they would make sure there is no lint left behind. Don't ask me how I know.😉
  23. jon haney
    Brake problem
    All good stuff above, but I'll add another personal experience, in case it might apply. On my 2010 Triumph, I installed an aftermarket brake lever, and had the same thing happen, but I only had to crack one bleed screw. The new lever wasn't quite allowing the master piston to fully return. The "dry end" of the master piston goes into a hole in the lever, and it needed to be just a few thousandth's deeper. A drill bit fixed the problem.
  24. Yep. The clutch and brake reservoirs (height) are the only thing I would change.
  25. Shiny black with the gold wheels. Wood.
