All Activity
- Yesterday
I should have said oil pan threads as that would have made a really bad day if they came out with the plug.
I should buy a new plug. The threads appeared unhappy. I agree, having the vehicle lift is a total game changer. Super grateful for the lift just wish I had one starting about 30 years ago.. The lift is certainly a “friend magnet”. 🤣
I am glad for you that the oil plug threads survived the massive over torque. As far as you pants, I just hate that. You are just going to do one little thing and bam, something happens. But at least you didn't have to crawl out from under the car 50 times as you tried different tools and drain the oil like the rest of us peons.
Looks like they want 45 degrees vs. injector in DI engines. Wife's CX5 is DI, I'll have some copper washers laying around. Car is due for service. See what happens.
The oil filter was also super tight, fortunately I have an end cap oil filter removal tool which I was able to bust it loose with. The nice thing about the Subaru is the filter is on top right next to the filler and the filter sits upside down.
This was a fairly common practice in the muscle car era, '60s thru the early '70s. The HP/combustion efficiency improvement was very subtle at best, but it was not that subtle on some high performance/built engines (i.e.; anything with a hemi-style combustion chamber). The trick was to mark the corresponding plug gap placement on the plug's ceramic insulator prior to installation; once torqued you could see the gap's relationship to the intake valve. Copper shim washers were available in various thickness to fine tune the plug gap/intake valve angle (using more than one shim/washer was ill advised, but was done by some). You wanted to point the gap past the intake valve seat and about midway toward the area of the chamber in which the incoming intake charge/spray of fuel would swirl the most (somewhat akin to aiming for center of mass).
Btw, I agree on latter part of OP. There absolutely no fucking way to know ahead position of side electrode of particular plug in particular engine.
Interesting, and not urban legend. Straight from NGK page. In DI engine, you index it toward injector?
I will pull the codes today. I don’t look at the check engine light anymore. I put an aftermarket manifold and cat on it last year and the rear O2 sensor does not play nice. I currently have 5 lights that stay on.
It used to be a hot rodder's trick to try to squeeze out a couple HP; usually pointless, but sometimes worth while. I recently learned that with some DI engines it's a big deal so if you have one and do your own work, make sure you check the info for yours. Some manufacturers get around it by using multi electrode plugs. Many say that if you buy plugs from a dealer they index properly, vs. the same number plugs from a parts supplier that won't index the same; I'm not sold on that.
The fill cap on some cars like to stick, but it seems likely that that one had been cranked down. No story about the filter so I guess he didn't go crazy on that.
Even if it didn't trigger a check engine light there's likely to be a "pending" code that will tell you which cylinder it was. From there I'd look at the plugs to see if it might be worn plugs or something else. If you replace the plugs I recommend OEM unless there's evidence of something that's better for it. They don't have to come from a stealership, just the same brand and number plugs. It's unlikely to be a coil, when they crap out it's usually permanent. I've seen some cases where they stop working cold but work as they heat up. The inverse could happen, but I don't recall ever experiencing it.
Good idea. I have thought of doing that, but it is such an intermittent event by the time I get home I have forgotten about it. Until the dead cylinder incident. And the stethoscope is in the barn so it is even easier to forget.
I just changed the oil on Molly's Subaru Outback, (SOB) I wish I could find the Subaru Tech who touched it last… FUCKING COCK SUCKING MOTHER FUCKER. 🤬 He must have applied the oil fill cap with a specialty tool torqued to about 60 pounds. The OIL FILL CAP!! Who does that?? . After I carefully removed it with a wrench my buddy said, “I bet the oil tech got fucked in the ass for forgetting to put the oil cap on previously.” Oddly, the Subaru cap appears to have slots for a speciality tool to be inserted for tightening…I’d never noticed that before. Next, when I tried to remove the oil drain plug with a 14mm socket and a 3/8’ ratchet wrench it wouldn’t budge. So, when I moved to a 1/2’ ratchet and it didn’t budge I began to become concerned. I pulled out the “Big Gun” the DeWalt 3/8’ cordless impact. The same tool I have pulled old, rusty bumper bolts with! Nada. Fucking reefed on. ‘’Out comes the DeWalt 1/2” cordless impact gun which I use for pulling wheel lug nuts. Well, the mother fucking oil drain plug busts loose, spins off, and I got hit with projectile oil vomit from the Subaru’s 45 degree exit drain plug. A fucking geyser which drenched my pants from the hip to the knee, and these were not my shop pants. I was pretty infuriated as I hadn’t bothered to put on my mechanics coveralls as it was a one bolt job. I decided to,change the oil on the SOB shortly after putting adjustable lower control arms on my buddy’s Jeep TJ. (The one we swapped Rubicon running gear into.) So, the point of this whole story…? I looked up the torque spec for a Subaru Outback oil drain plug and torqued that bitch to a perfect 25 foot pounds. 😀
Auto Stethoscope, listen on startup for general location and see if you can pinpoint it down. I have even used a short 2ft paint roller extension stick to pinpoint problems in the past. Press against your ear and listen. Naturally keep digits and loose clothing from belts and other spinning crap.
- Last week
Not DI. I will try new ignition stuff. Thanks.
Outmotoring has an ignition set they just started advertising. Includes coil pak. It has been probably 10 years since I last replaced one. Thanks, will try that next week.
Is it DI or port injection? I doubt the injectors could do anything to cause a tick. If the motor's really worn the imbalance caused by a misfire might cause ticking, but I don't think I've ever experienced it. If it's DI and the intake valves are gunked up and leaking they might be able to cause a tick/chirp type noise along with a misfire.
I don't think first and second part of your post are related. First looks like hydraulic lash adjuster/ lifter whatever you wanna call issue Second, it would be, obviously, fuel or ignition. I won't elaborate any further because I'm totally unfamiliar with your Mini. Maybe just throw on it fresh set of spark plugs and ignition coils. Not that expensive.
For the last year or so my MINI has a loud single tick on cold startup. EVERY ONCE IN A WHILE. It goes completely away in about a minute or two, by the time I get out of my neighborhood. I assume an injector is getting sticky. The car is my daily driver, but one week a month it sits at my office when I am driving a “call” car. Last week I got in after a week on call and started driving home. It was missing on one cylinder. It did not go into limp mode so I said fuck it and kept on driving. About a mile out it cleared. Is this an obvious bad injector? 278,000 miles on not top-tier ethanol free premium gas. I run Techron through it every few thousand miles. Should I try to clean it or replace it? Probably will DIY. Should I replace them all (fuckers are pricey)?
My test was sufficient for needs outside of air/spacecraft. I measured it a few months apart against the other torque wrench. I know exactly how that can be problematic but was simply looking for repeatability/change and really don't care about ultimate precision.
TOXXIC started following All about torque wrenches
+1 as in send it out for calibration. The Prime Air team that was building drones had theirs sent out every Friday for calibration....FAA and all....maybe Boeing should have been as methodical.
