REXX Posted January 11, 2004 Posted January 11, 2004 I have a 1999 with the original battery. It still starts fine but I don't want to stress out the R/R if the battery is towards the end of it's life. How many years are you guys getting out of your battery and what do you think of Wal-mart batteries? Thanks in advance for any info. Oh yeah, going to take off an old adhesive tank pad...any suggestions for easiest way? Quote
blackhawkxx Posted January 12, 2004 Posted January 12, 2004 I still have the factory battery from 1996. :shock: I am going to get a new one this spring. Don't know about Wal-Mart. Quote
XX Posted January 12, 2004 Posted January 12, 2004 2002 and 1.5 years old, and 36,000 miles, battery is fine. for the adhesive tank pad, blowdryer and patience. :grin: Quote
r3ckl3ss Posted January 12, 2004 Posted January 12, 2004 just in case anyone was curious.. it appears as though the Walmart brand Everstart is made by Exide... http://www.everstartbatteries.com/contactUs/index.asp note that the contact email address is @exide.com -r3ckl3ss Quote
Pete in PA Posted January 12, 2004 Posted January 12, 2004 98 with 40500 miles still factory battery. The key is a Battery Tender. I'd stick with Yuasa myself, although all made in same factory still diff. quality inside. To get goo off use carb cleaner. Quote
blackhawkxx Posted January 12, 2004 Posted January 12, 2004 just in case anyone was curious.. it appears as though the Walmart brand Everstart is made by Exide... Unless I am missing it, I don't see a listing for motorcycles. Quote
Northman Posted January 13, 2004 Posted January 13, 2004 To get goo off use carb cleaner. Yeah, especially if you don't like your paint! :shock: Carb cleaner will soften up your paint, and start removing it while you're using it. It can also seep right into the paint, and cause long term issues in the area you used it in. Use "Goo Gone", but use it gently, as it can soften paint as well. Best advice here was "Hair dryer and patience" BTW, I'd never use an Exide battery again, in anything. Stick with Yuasa. There's a reason Honda uses them exclusively, and we don't need to change them for 5-6 years. Quote
REXX Posted January 13, 2004 Author Posted January 13, 2004 Thanks for the advice everyone. I think I'll go with Yuasa when the time comes and use the "hairdryer and patience" technique with the tank pad. Quote
SwampNut Posted January 13, 2004 Posted January 13, 2004 Whoa, I missed that before, but yeah, I have direct personal experience that Goo Gone and carb cleaner will soften paint. Quote
Pete in PA Posted January 16, 2004 Posted January 16, 2004 I never had carb cleaner eat paint, sorry :oops: I use it all the time. I just wax the area afterwards. Never a problem. I had a buddy run his car through fresh tar without the chip. Turned the sides black. I used gas to remove it, then waxed. No problem. BUT it you guys had paint problems then try WD-40. Quote
