TOXXIC Posted December 13, 2014 Share Posted December 13, 2014 We have a 2001 Yamaha XT225, which recently developed a fuel leak. Initially, I assumed it was at the petcock as the fuel was dripping down the left side of the motor (clutch lever side) and pooling on the floor. However, after pulling the side cover I saw a small drip of fuel above the petcock on the side of the fuel tank. This concerned me as I thought there might be a pin hole size leak someplace in the tank. This is where it gets wierd. The top of the gas cap is wet with fuel, and my son mentioned the key has gas on it when you pull it out of the locking cap. Sure enough, when I pulled the key out of the locking gas cap the bottom 1/4" of the key is wet with gas. I havent' dug into this yet nor pulled the tank to investigate. I considered it may have been overfilled and venting out, but the fuel level is considerably lower than the filler neck. These bikes have been fun for the kids as they are pretty bullet proof, electric start, and fun to ride. However, they sure are tempermental with cold starts after several weeks of inactivity. I am guessing the parts in the carbs are tiny and get ocluded rather easily. Quote Link to comment Share on other sites More sharing options...
John01XX Posted December 13, 2014 Share Posted December 13, 2014 (edited) If any carb'd bike sits for more than a week or two without being started up, you are going to get a buildup of deposits in the jets, clogging them up. After a ride just turn the fuel off and run the engine dry of fuel then store. A carb clean generally runs $150.00 here in So Florida! Edited December 13, 2014 by John01XX Quote Link to comment Share on other sites More sharing options...
OMG Posted December 13, 2014 Share Posted December 13, 2014 Thank goodness it doesn't do what the old Honda 350's did. I'm guessing I bored and installed new pistons in 150 of those. If the petcock was not shut off, often the carb floats would stick and drain the tank into the oil. Not many miles into the next ride the pistons would seize. Kept me very busy for a few years Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted December 13, 2014 Share Posted December 13, 2014 I am guessing the parts in the carbs are tiny and get ocluded rather easily. While that is true, it takes a while. I have a Honda generator that sits for months without being started. I should start it once a month but I forget. I have had it about ten years and this was the first year that I had to clean the carb and it is a tiny carb. I do keep some Sta Bil and a little Sea Foam in it. Also, my two bikes sit from November to April or May every year. Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted December 14, 2014 Share Posted December 14, 2014 I've found that some carbs will gum up easily and others won't without a lot of reason that I can think of, but running it dry or draining is a good idea. As for the gas everywhere I think you need a fresh start and see for yourself what's happening. Maybe they overfilled it before you got to it, just bouncing it hard, fell over and ain't tellin... The tank can be patched, most parts stores sell a gas tank repair kit; it's just epoxy and some matting to cover large holes. Quote Link to comment Share on other sites More sharing options...
EVLXX Posted December 14, 2014 Share Posted December 14, 2014 We have a 2001 Yamaha XT225, which recently developed a fuel leak. Initially, I assumed it was at the petcock as the fuel was dripping down the left side of the motor (clutch lever side) and pooling on the floor. However, after pulling the side cover I saw a small drip of fuel above the petcock on the side of the fuel tank. This concerned me as I thought there might be a pin hole size leak someplace in the tank. This is where it gets wierd. The top of the gas cap is wet with fuel, and my son mentioned the key has gas on it when you pull it out of the locking cap. Sure enough, when I pulled the key out of the locking gas cap the bottom 1/4" of the key is wet with gas. I havent' dug into this yet nor pulled the tank to investigate. I considered it may have been overfilled and venting out, but the fuel level is considerably lower than the filler neck. Ok, I'm not hands on familiar with this bike so.... question? Metal tank ?With locking gas cap I'm speculating the answer is, Yes. Also with Locking gas cap and metal tank, I am speculating 2 seals, and an inner metal vent tube, that is under the cap, and vents out the bottom of the tank. Yes/No? My guess is said tube is plugged, and since the fuel vapors can't get out through the tube, they are coming out through the key hole in the cap, and since the cap is metal an colder, it condensing inside the gas cap, hence fuel on the Key. 2 Quote Link to comment Share on other sites More sharing options...
TOXXIC Posted December 14, 2014 Author Share Posted December 14, 2014 Some good thoughts so far in this thread. I hadn't thought of the fact one of my sons could have tipped the bike over as there was no visible damage. But my Jeep has a flat tire on the sudden and I haven't driven it in weeks. As to the make up of the tank it is metal with a metal gas cap. I took it off yesterday and shook it looking for pin hole leaks but could not find any. When placed nearly upside down gas began to rush out from under the gas cap. Inspection of the inside of the gas cap revealed a large amount of dirt and residue build up on the rubber gasket. I cleaned that thoroughly and reinstalled the tank. However, now that you mention it, I didn't see a vent hose or line. Just the tank and the fuel petcock assembly. However, your theory of a plugged vent tube and pressuring the fuel vapors out the key hole of the gas cap does make sense. Here is a link to a schematic of the fuel supply system. http://www.boats.net/parts/search/Yamaha/Motorcycle/2001/XT225%20-%20XT225N/FUEL%20TANK/parts.html http://cdn.boats.net/diagram/yamaha/MCY/2001/XT225N_NC/IMAGES/FUEL_TANK.png Quote Link to comment Share on other sites More sharing options...
TOXXIC Posted December 15, 2014 Author Share Posted December 15, 2014 After cleaning cap, taking the tank off and inspecting the tank for leaks I am more perplexed. The fuel appears to be leaking down the from the underside of the tank, and causing a tiny pool to form on the left side of the engine case. To test Eric's venting theory I am going to leave the gas cap off overnight with a rag stuffed in the top. Should still vent a bit, and not be a captured system. Now I am starting to suspect a pin hole leak..... Quote Link to comment Share on other sites More sharing options...
brianmacza Posted December 16, 2014 Share Posted December 16, 2014 Might be easiest to leave tgetank off the bike for a day or so resting on a clean sheet of cardboard. If thetank and card was clean to start off it should give a clear indication of where the leak lives. On the bike it's gonnabe way harder to trace. Quote Link to comment Share on other sites More sharing options...
TuffguyF4i Posted December 17, 2014 Share Posted December 17, 2014 (edited) Those metal caps are the venting system. I have never had issue with one. Give it a good blast with some carb and choke cleaner. Turn the fuel off and see if it still happens. Maybe go so far as to disconnect the fuel line to the carb and drain the carb as well. Good time to clean it too. Many older carbs have the floats stick and drain the contents....but sounds like you may have eliminated that as an issue. For the cooler months and hard starts...have you dropped the clip in the main pilot needle to richen it up a bit? Edited December 18, 2014 by TuffguyF4i Quote Link to comment Share on other sites More sharing options...
TOXXIC Posted December 24, 2014 Author Share Posted December 24, 2014 Those metal caps are the venting system. I have never had issue with one. Give it a good blast with some carb and choke cleaner. Turn the fuel off and see if it still happens. Maybe go so far as to disconnect the fuel line to the carb and drain the carb as well. Good time to clean it too. Many older carbs have the floats stick and drain the contents....but sounds like you may have eliminated that as an issue. For the cooler months and hard starts...have you dropped the clip in the main pilot needle to richen it up a bit? I did not drop the clip in the main pilot needle, but can see how that would be a great idea! I solved the problem with the leaking tank, I sold the bike last night! I have a second 2001 XT225 at my cabin, which is cold blooded and would benefit from the main pilot needle adjustment. Quote Link to comment Share on other sites More sharing options...
haWHYnXX Posted December 26, 2014 Share Posted December 26, 2014 I solved the problem with the leaking tank, I sold the bike last night! Haha - that's some phenomenal problem solving skills right there!!! Quote Link to comment Share on other sites More sharing options...
