Tom Posted September 20, 2021 Posted September 20, 2021 I'm looking at some CB1300 wheels from 2003, thinking if they could be fitted to the Bird. It's a simple 5 spoke design, but anything's nicer than the 3-spoke wheel looking at some brake disc manufacturer specs and pics, the discs are very different, the PCD, inner diameter, so correct my basic level of knowledge but a CB1300 wheel with the discs and appropriate spacers for the axle would be enough to fit it? I have no intent on de-linking the brakes or changing anything about it, but both bikes have 310mm so I figure the CB rotor would fit on the Bird caliper? Also, from what I've been able to read, the rear should be a direct fit, even the rear discs are the same on those two bikes. Any advice or pro tips welcome Quote
rockmeupto125 Posted October 6, 2021 Posted October 6, 2021 Th concern is hub spacing combined with the offset of the disc. If the discs are the same width apart as an XX, then you can spacer the hub to fit the fork legs. If not, you're going to have to spacer the calipers to match them. 1 Quote
jon haney Posted October 7, 2021 Posted October 7, 2021 23 hours ago, FTM said: Anyone? We didn't get the CB1300 over here, so responses will mostly be limited to members who live in the eastern hemisphere. Quote
Tom Posted October 9, 2021 Author Posted October 9, 2021 On 10/7/2021 at 1:52 AM, rockmeupto125 said: Th concern is hub spacing combined with the offset of the disc. If the discs are the same width apart as an XX, then you can spacer the hub to fit the fork legs. If not, you're going to have to spacer the calipers to match them. I drew up this comedy of a front view of a wheel...now, if I ever find a CB1300 parked up somewhere, how would I precisely measure the gap from "middle of the caliper" to the hub, in order to figure out if Bird's disc and CB's disc have the same offset? Quote
rockmeupto125 Posted October 9, 2021 Posted October 9, 2021 The only thing you would need to know is how far apart the discs are and how that compares to an XX. From there you will know how much the calipers will need to be moved. Choose ID, OD, or measure from the middle of the disc, just do it the same way for both. I'd measure at a couple different points just on the possibility that one of your data discs is warped. Quote
Tom Posted October 9, 2021 Author Posted October 9, 2021 Thanks. I'm looking at some bearings catalog, if I'm looking at the right columns, front wheel bearing are as follows; Bird - ID 20 / OD 47 / WID 14 CB - ID 20 / OD 45 / WID 12 If ID are the same on both...this means axles are the same on both, right? Quote
XXitanium Posted October 9, 2021 Posted October 9, 2021 I bet you could Google the actual part numbers for both bikes. Design For Manufacture principles drive fewer Stock Keeping Units. They are likely the same axle. Quote
Tom Posted October 17, 2021 Author Posted October 17, 2021 Did some research today at the garage, measured distance left to right inside of the rotors. '07 CBR600RR - 125.5mm Bird - 134.3mm Now since disc part numbers (and catalog specs) of 600RR and CB1300 rotors are the same, if we presume CB's rotors are 125.5mm apart as well - it would mean a CB wheel with its discs would need approx. 5mm spacer on each side to fit in Birds calipers, correct? Or am I forgetting something? Quote
rockmeupto125 Posted October 18, 2021 Posted October 18, 2021 So you have a 600RR to compare with, correct? And you measured the disc separation on the 600 and the 1100 as a comparison? By searching the parts books, you surmised that the 600 and the 1300 rotors will interchange, having the same specifications. The gap in the data is that although the 600 and 1300 discs may be effectively the same, you still don't know if the hub width on the 1300 is the same as the 600, and you can't assume the spacing without that information. Quote
XXitanium Posted October 18, 2021 Posted October 18, 2021 Do you actually have set of these sources already? Quote
rockmeupto125 Posted October 18, 2021 Posted October 18, 2021 Internet folklore has the inner to inner spacing of the CB1300 discs at 132mm, so it might work with a metal shim behind the disc. I'm silly, so I'd try it, but I'd certainly want the CB1300 axle and spacers to go by. The collar width, step off on the axle, and bearing width are what keeps the forks straight so they don't bind with movement. You'll need pretty accurate measurement to choose the correct bearing width to keep that width 1 Quote
Tom Posted October 18, 2021 Author Posted October 18, 2021 (edited) Thanks for finding that number, I didn't manage to find it, bad google-fu skills how'd you find it? This would mean calipers on the Bird are 1mm "out" to fit the CB1300 discs, which seems like something not to hard to retrofit? Also, just as a thought exercise from an absolute layman (me), what if I'd want to keep the Bird's rotors. This is the only solution that comes to mind. The bolts on the outside of this adapter-spacer could be any "length" I presume, or whatever other factor matters for bolt strength. But the inner bolt pattern, where Bird's rotors would go - my question is would shorter rotor bolts even be allowed? Many OEM bikes seem to have 17mm long bolts here...what would happen if 8mm were used, to keep the spacer as "narrow" as possible? Second pic is some aftermarket wheel I found - it seems it uses this very specific type of adapter - spacer? I feel I'm overly complicating this as is, sorry Edited October 18, 2021 by FTM Quote
superhawk996 Posted October 19, 2021 Posted October 19, 2021 I don't entirely understand what you're trying to say/ask. The length of a bolt when using a nut doesn't matter other than being long enough to fully engage the nut. The length of the factory screws going into the wheel are overkill, but I don't know how to calculate a minimum safe length. I also don't see how the length of them would matter for using an adapter like the one you showed. Quote
Tom Posted October 19, 2021 Author Posted October 19, 2021 If going for OEM Bird discs on these wheels, the mentioned adapter would be needed, so that the Bird's rotor bolts have to go somewhere - those bolts are 17mm long, so if the adapter isnt 17mm thick, they won't thread all the way in. What if the adapter needs to be, for example, 5mm - I can only see 2 solutions, one would be shorter bolts, another would be making threads in the hub itself, if that's even allowed, to intervene on a alloy wheel like that? I don't know the basics, for example you mentioned that the factory rotor bolts are overkill - but aren't they crucial, they hold the rotor in place and that rotor needs to be rock solid so the brakes can stop your bike down, or am I thinking wrong? Quote
rockmeupto125 Posted October 19, 2021 Posted October 19, 2021 I think the rotor bolts are 8mm, and ISO standards are pretty vague specifying somewhere from 4 to 12 mm of thread depending on how tight the threads are. I would not feel exceptionally comfortable with a grip at the lower end of that scale. Neither am I a certified mechanical engineer so while it may be safe, I don't like it. The lands for the rotor mount are machined from the cast surface of the hub to be parallel with the wheel centerline and by definition, the opposing machined surfaces. The area you are suggesting to thread the hub is a cast, imprecise surface and the rotor will not be true unless lady luck plays a part in the game. Quote
XXitanium Posted October 19, 2021 Posted October 19, 2021 We need a section cut drawing. I believe we are not picking up the direction he intends the bolts to thread in possibly? Quote
jon haney Posted October 19, 2021 Posted October 19, 2021 2 hours ago, FTM said: If going for OEM Bird discs on these wheels, the mentioned adapter would be needed, so that the Bird's rotor bolts have to go somewhere - those bolts are 17mm long, so if the adapter isnt 17mm thick, they won't thread all the way in. What if the adapter needs to be, for example, 5mm - I can only see 2 solutions, one would be shorter bolts, another would be making threads in the hub itself, if that's even allowed, to intervene on a alloy wheel like that? I don't know the basics, for example you mentioned that the factory rotor bolts are overkill - but aren't they crucial, they hold the rotor in place and that rotor needs to be rock solid so the brakes can stop your bike down, or am I thinking wrong? Just picture yourself doing 100+ MPH, tight corner coming up quick, grab a handful of brake lever, and the discs are ripped from the wheel. You know the rest. My advise? If possible, I would use the discs that were meant for the wheel you are going to use. 1 Quote
XXitanium Posted October 20, 2021 Posted October 20, 2021 FWIW - John Haney has a long history of drag racing in his past. 1 Quote
superhawk996 Posted October 20, 2021 Posted October 20, 2021 10 hours ago, FTM said: If going for OEM Bird discs on these wheels, the mentioned adapter would be needed, so that the Bird's rotor bolts have to go somewhere - those bolts are 17mm long, so if the adapter isnt 17mm thick, they won't thread all the way in. What if the adapter needs to be, for example, 5mm - I can only see 2 solutions, one would be shorter bolts, another would be making threads in the hub itself, if that's even allowed, to intervene on a alloy wheel like that? I don't know the basics, for example you mentioned that the factory rotor bolts are overkill - but aren't they crucial, they hold the rotor in place and that rotor needs to be rock solid so the brakes can stop your bike down, or am I thinking wrong? If the Bird rotor holes are on a smaller circle than the holes in the wheel, like where the green dots are in that photo, I see no way for the adapter to work. If the wheel had a smaller circle than the rotors then maybe, but unlikely. I think the rotors center on the wheel and not on the screws, kinda like car wheels that are hub-centric vs. lug-centric. If the holes in the rotors and the screws are tapered then the rotors are centering by the screws, if they're flat like I think they are they're relying on the machined 'pads' in the wheel for centering. Quote
jon haney Posted October 20, 2021 Posted October 20, 2021 21 hours ago, XXitanium said: FWIW - John Haney has a long history of drag racing in his past. Very nice way of saying I'm old. LOL. 1 Quote
