XXitanium Posted May 30, 2018 Share Posted May 30, 2018 I snapped off one of the internals on my son's new-to-him 1997 Blackbird. I'd like to get it right for him. I've cruised around the web for hours. I can't find much information on the Manic Salamander brand. Some of the reading I did suggested that they use the OEM internal bar-weight hardware Honda provided. I assume need to pull the old weight/core out. Am I going to have to take off the grip? They're really nice. I don't want to mess them up.I took some pictures that I'll post. I've only ever re-attached purchased ends into the existing hardware TIA Bill Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted May 30, 2018 Share Posted May 30, 2018 Been a million years, and never done it on the Bird, but as I recall they kinda wiggle out. Put the screw in without the bar end and wiggle/pull. Grip stays. Not sure if this is how they come out, but shouldn't hurt to try if someone doesn't come in with a better way. 1 Quote Link to comment Share on other sites More sharing options...
XXitanium Posted May 30, 2018 Author Share Posted May 30, 2018 Quote Link to comment Share on other sites More sharing options...
XXitanium Posted May 30, 2018 Author Share Posted May 30, 2018 There's some kind oof steel retainer ring with a rim on it at the end, support for the weaker aluminum bar tube? Quote Link to comment Share on other sites More sharing options...
OrganDonor Posted May 30, 2018 Share Posted May 30, 2018 When I installed them I noticed nothing different about the internals. You shouldn't have to remove the grip, but may want to if you want to prevent damage on the end. I installed them with standard grip glue, so heat them up, and slide a long thin screwdriver under them all the way around. And if you destroy them, you can always upgrade to BMW grips. The ones you have on there now were cheapos. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted May 30, 2018 Author Share Posted May 30, 2018 6 hours ago, OrganDonor said: ....you can always upgrade to BMW grips. I'm pretty sure that's whats on my Ti. Quote Link to comment Share on other sites More sharing options...
DBLXX Posted May 30, 2018 Share Posted May 30, 2018 7 hours ago, XXitanium said: There's some kind oof steel retainer ring with a rim on it at the end, support for the weaker aluminum bar tube? I just did it on the NC700 and Goldwing and I believe Honda still uses the same method. There is a clip that holds it in as well as some expanding rubber. You need to pinch both of those clip ends you see which releases it. I took a long screw with a heavy socked head. Put in the screw and used the socket to bang it out. You see the 2 little shark fins sticking up (one on top and one on the bottom)...those clip into the inside of the handle bar itself. You have to pinch the 2 end clips to push those down to release the entire end. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted May 30, 2018 Author Share Posted May 30, 2018 Thanks Dave Quote Link to comment Share on other sites More sharing options...
Tom Posted May 30, 2018 Share Posted May 30, 2018 Just a sec, does this mean I can't buy those generic bar end weights that are sold on eBay, Bird requires special kind? Or not? Quote Link to comment Share on other sites More sharing options...
XXitanium Posted May 30, 2018 Author Share Posted May 30, 2018 If you're spending money on wheels, consider good bar ends an investment. It sucks when you get to your next stop and your hands are tingling or an end has fallen off. Quote Link to comment Share on other sites More sharing options...
DBLXX Posted May 31, 2018 Share Posted May 31, 2018 3 hours ago, FTM said: Just a sec, does this mean I can't buy those generic bar end weights that are sold on eBay, Bird requires special kind? Or not? Nope, the cheapies work too. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted May 31, 2018 Author Share Posted May 31, 2018 21 hours ago, OrganDonor said: When I installed them I noticed nothing different about the internals. Can you tell me if those are stock XX bars please? Mine came with two sets of aftermarkets... Quote Link to comment Share on other sites More sharing options...
XXitanium Posted June 1, 2018 Author Share Posted June 1, 2018 I'm going to look for a longer screw. There is abbout 5/8" left in the long rod. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted June 1, 2018 Author Share Posted June 1, 2018 I checked inventory for M6x80mm at Fastenal and Fleet Farm on line. They showed none in stock. I ordered from eBay, they should arrive before next Friday. $15.00 for a package of 10. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted June 1, 2018 Author Share Posted June 1, 2018 I used the two screw driver method as in the video Dave posted. I did not have to remove the grip. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted June 1, 2018 Author Share Posted June 1, 2018 19 hours ago, XXitanium said: $15.00 for a package of 10. ...Fastenal had convenience psvks of 3 for $3.00. She'll be totslly road ready by Sunday afternoon. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted June 1, 2018 Author Share Posted June 1, 2018 ...small keyboards suck. Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted June 2, 2018 Share Posted June 2, 2018 On 5/30/2018 at 10:09 PM, XXitanium said: Can you tell me if those are stock XX bars please? Mine came with two sets of aftermarkets... Bill.....if you're asking about the '97, those are VFR bars........exactly the same fittings as a stock XX bar, just a little higher. 1 Quote Link to comment Share on other sites More sharing options...
XXitanium Posted June 2, 2018 Author Share Posted June 2, 2018 Tx Joe. Quote Link to comment Share on other sites More sharing options...
XXitanium Posted September 20, 2018 Author Share Posted September 20, 2018 1 Quote Link to comment Share on other sites More sharing options...
