silverbird1100 Posted April 13, 2004 Share Posted April 13, 2004 I've decided to switch over to synthetic at 15,000 miles. I will be doing a huge 4000 mile trip on the new oil. Is there anything I need to worry about? What are the chances of any problems or should I do a test run before leaving for the trip? Quote Link to comment Share on other sites More sharing options...
velocity Posted April 13, 2004 Share Posted April 13, 2004 Mobil 1 has changed their oil and added friction modifiers (ie. tungsten). This is bad news for clutches. :cry: In my old bike I started using castrol syntec and have had no problems over the past two oil changes. Quote Link to comment Share on other sites More sharing options...
blackbd1 Posted April 13, 2004 Share Posted April 13, 2004 silverbird there is a correction to the statement above, Mobil 1 has a motorcycle synthetic named MX-4T or M4-XT something like that, and it contains NO friction modifiers (i.e. moly disufide). this oil is designed for wet clutch motorcycles. i have had it in my '00 XX for 8k miles and it is doing great. hth Quote Link to comment Share on other sites More sharing options...
silverbird1100 Posted April 13, 2004 Author Share Posted April 13, 2004 That sucks! When Sport Rider did their excellent oil test Mobil 1 showed use of Moly but no more than HP4. But that was back then, if they added even more junk, what's the alternative now? Castrol Syntec is $4/quart and you might as well be buying real bike oil. Quote Link to comment Share on other sites More sharing options...
silverbird1100 Posted April 13, 2004 Author Share Posted April 13, 2004 I'd be happy to get their bike specific oil if it wasn't $10 a quart. I wonder what Walmart could get it for? Quote Link to comment Share on other sites More sharing options...
Redbird Posted April 13, 2004 Share Posted April 13, 2004 Velocity, are you talking about Mobil1 15-50 specifically? I know the lighter weight automotive oils have the additives you need to stay away from, but the 15-50 has been known as motorcycle friendly for a long time. Hopefully that hasn't changed. Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted April 13, 2004 Share Posted April 13, 2004 When did this change to the oil occur? I changed my oil about a month ago or so. Only ridden about 100 miles on it so far.. (been working every weekend/or shitty weather) Quote Link to comment Share on other sites More sharing options...
Steve Posted April 13, 2004 Share Posted April 13, 2004 I switch all my vehicles over to Mobil 1 about a year ago after hearing such a great buzz about it. Since using it I've noticed Zero diference but will continue to use it. I had also heard of the histeria about the new "Super Syn" causing clutch plate problems but NO ONE has documented such problems. This was a hype that traveled along without merit. In my bikes I've switched to 15w-50 and change it out every 5K miles (makes it easy to remember to change it with the odometer reads 5 or 10K - no need to write it down and record anymore). As I have said to those I know - I have yet to hear of a single oil-related breakdown regardless of oil with the except of an in-law who never changed her oil for many years. In my Acura I ran Castrol 20-50 dino oil and have 275K on the original engine and it's still going strong! I change that one every 5K. Bottom line - I have read many tests that have shown Mobil one to be at elast as good as the others and better than most. I change it every 5K more so for piece of mind than anything else. You will be fine running Super-Syn (which is the new formula as of one year ago) in spite of the facctless rumors flating around, this is verified by many Goldwings, ST1100's and other bikes who run Mobil1 15w-50. Hope this helps some Steve Quote Link to comment Share on other sites More sharing options...
blackbd1 Posted April 14, 2004 Share Posted April 14, 2004 i like the Mobil 1 M4-XT 10w-30 as i understand it, moly disufide is a molecule that clings to the walls of surfaced to make them more slick. it basically fills in the low spots. in a wet clutch, filling in the low spots would destroy the clutch by making it slicker that greased owl shit. other synthetics that contain friction modifiers such as moly are used by some cyclist, but they are probably dry clutch harleys and the such. this synthetic (Mobil 1 M4-XT) is designed for use in wet clutch bikes. (contains no moly) actually, my bike seems to shift easier with the Mobil 1 in it my 2 cents Quote Link to comment Share on other sites More sharing options...
velocity Posted April 14, 2004 Share Posted April 14, 2004 Velocity, are you talking about Mobil1 15-50 specifically? I know the lighter weight automotive oils have the additives you need to stay away from, but the 15-50 has been known as motorcycle friendly for a long time. Hopefully that hasn't changed. I know...I used to use Mobil1 15W-50 in my bike too. But they started adding their "SuperSyn" Anti-Friction Technology to the 15W-50 as well. That's when I stopped using it. And so did everyone I know who used to use it too. :cry: Quote Link to comment Share on other sites More sharing options...
Redbird Posted April 14, 2004 Share Posted April 14, 2004 I've been using the Supersyn version for almost two years (up around 20,000 miles). My clutch is fine. It's like Steve said up above, there was much concern and knashing of teeth when it came out, but it's fine, really. Sportrider tested the 15-50 along with a bunch of other oils last year (post Supersyn) and it scored high marks, even compared to much more expensive motorcycle specific oils. Quote Link to comment Share on other sites More sharing options...
velocity Posted April 14, 2004 Share Posted April 14, 2004 Well if you're using it and haven't had any problems I can't argue with that. I just didn't want to chance it on my own bike. Quote Link to comment Share on other sites More sharing options...
Edward Posted April 14, 2004 Share Posted April 14, 2004 If I may suggest an alternative. Try http://amsoil.com/lit/g391.pdf, One of the last "true" synthetics left. Quote Link to comment Share on other sites More sharing options...
jrdxx Posted April 14, 2004 Share Posted April 14, 2004 Use the Mobil 1 15W-50 and a fresh filter, don't overtorque your drain plug, and ride a few miles just to warm the engine and check for leaks. You'll be fine. Unless you decide to learn how to do giant, smoking burnouts in your driveway before you leave. Then, you might have clutch problems, but I wouldn't blame it on the oil.... Quote Link to comment Share on other sites More sharing options...
BIG BOY Posted April 14, 2004 Share Posted April 14, 2004 Fuck, i just bought a gallon jug or whatever it is at Walmart this past weekend of the 15-50 oil!!!!! It's not good for bike any more??????? Quote Link to comment Share on other sites More sharing options...
Redbird Posted April 14, 2004 Share Posted April 14, 2004 Read the whole thread, Don, it's fine :grin: Quote Link to comment Share on other sites More sharing options...
CoolRunnings Posted April 14, 2004 Share Posted April 14, 2004 Been using 15-50 for a year/18k miles & no problems. I'll get some more today. Quote Link to comment Share on other sites More sharing options...
bartonmd Posted April 14, 2004 Share Posted April 14, 2004 Edward, From what I Get, AMSOIL rocks! The ME and MET professors that ride at school (some of them I still talk to/ride with) use amsoil because: A. It's good shit B. They are about the only mfg. that puts out their performance data C. They are AT LEAST as good as the MX-4T that Mobil 1 has and charges $8/each for, and amsoil costs $5.85/qt. I have been using the MX4T for awhile because it's readily avaliable at AutoZone and I didn't put that many miles on (maybe 6k/year) but now that I'm lookin at double/tripple that, I'm probably going to change over this next oil change. My $.02 Mike Quote Link to comment Share on other sites More sharing options...
Edward Posted April 14, 2004 Share Posted April 14, 2004 Edward,From what I Get, AMSOIL rocks! The ME and MET professors that ride at school (some of them I still talk to/ride with) use amsoil because: A. It's good shit B. They are about the only mfg. that puts out their performance data C. They are AT LEAST as good as the MX-4T that Mobil 1 has and charges $8/each for, and amsoil costs $5.85/qt. Â I have been using the MX4T for awhile because it's readily avaliable at AutoZone and I didn't put that many miles on (maybe 6k/year) but now that I'm lookin at double/tripple that, I'm probably going to change over this next oil change. My $.02 Mike Don't forget that Exxon/Mobil, Chevron/Texaco, Pennziol/Quacker State, Castrol and more than a few other manufactures of so called synthetic oils are now mixing some petrolium oil in with there synthetics base stock making them a synthetic blend. It helps with the bottom line. Quote Link to comment Share on other sites More sharing options...
Tufelhunden Posted April 14, 2004 Share Posted April 14, 2004 Using plain old Shell Rotella T Synthetic 5-40. Buy it at WalMart for $10 a gallon. Works great comes out clean after 3 to 4 K Miles. :grin: Quote Link to comment Share on other sites More sharing options...
Ronnie Posted April 14, 2004 Share Posted April 14, 2004 same here using Shell Rotella T Synthetic 5-40 but its 13.00 here at walmart. They to had a problem a months back some of their oil made some nasty smells. They would send you a total refund if you had that problem. Wasn't suppose to harm anything according to "them" Other than that its been great for me.. Quote Link to comment Share on other sites More sharing options...
xxxbirdxxx Posted April 14, 2004 Share Posted April 14, 2004 Now you guys have me all FUCKed up???????? Is the Mobil 1 15/50 good for my bike now or is it not? Someone please enlighten me! I just bought some and want to know if it is going back or not! Damnit :pissedfingers: :twak: :banghead: Thanks Quote Link to comment Share on other sites More sharing options...
EVLXX Posted April 14, 2004 Share Posted April 14, 2004 I've been using the Supersyn version for almost two years (up around 20,000 miles). My clutch is fine.It's like Steve said up above, there was much concern and knashing of teeth when it came out, but it's fine, really. Sportrider tested the 15-50 along with a bunch of other oils last year (post Supersyn) and it scored high marks, even compared to much more expensive motorcycle specific oils. Tim is correct.... there is nothing to worry about yet! There has been extensive testing done, and countless threads about Moly and Mobil One on this site. Wish I had the time to get into this one with you guys... and prove that it's still safe, but I don't. Don.... you're OK., don't panic. Quote Link to comment Share on other sites More sharing options...
silverbird1100 Posted April 14, 2004 Author Share Posted April 14, 2004 I'm not worried about the Moly at all. Honda's own GN4 has more moly than MObil 1 according to the Sport Rider test. What I'm worried about is any other friction modifiers we don't know they slipped in there to screw us over for not paying triple for the bike oil. Quote Link to comment Share on other sites More sharing options...
Redbird Posted April 14, 2004 Share Posted April 14, 2004 Okay fellas, here the scoop on Mobil1 15-50 w/ SuperSyn. It's fine. Really. I'm not going to say it's better than this that or the other thing, I don't even want to get into that, but there is absolutely no problem running this oil in your bike. Promise Quote Link to comment Share on other sites More sharing options...
