Zero Knievel Posted March 14, 2016 Share Posted March 14, 2016 (edited) My portable electric air pump broke. I'm looking for a replacement one that is a good quality but also inexpensive. I could go with a manual or 12 V electric, but I want one that won't break after a few uses either. I only use it for either a roadside repair or topping off tire pressure in the morning while on a trip and there are no gas stations nearby. Needless to say, it needs to be able to fit easily in a top or side case. The smaller, the better. Edited March 14, 2016 by Aunt Sylvia Quote Link to comment Share on other sites More sharing options...
OrganDonor Posted March 14, 2016 Share Posted March 14, 2016 i have the SLIME branded one. Got it at Autozone for under $10 because of a misprint. I cleaned them out, and gave them away to other board members. I believe it was Pete who broke the plastic housing off of his compressor,as naked it takes up a fraction of the space in your case. Quote Link to comment Share on other sites More sharing options...
OrganDonor Posted March 14, 2016 Share Posted March 14, 2016 Oh, and the SLIME on comes with clamps, and also connects directly your Battery Tender lead off the battery. Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted March 14, 2016 Author Share Posted March 14, 2016 Yeah, Slime had good reviews on Amazon. Is there a particular model you'd recommend? I'm sure the smallest one wouldn't hold up as well as the next model or two up. Quote Link to comment Share on other sites More sharing options...
poida Posted March 14, 2016 Share Posted March 14, 2016 slime powersport and a tubeless repair kit is what i keep on my bike.have had to use it a few times now and works great.made a shelf for it to sit on in the ducktail of my blackbird by tying a couple of bits of webbing in an x.i dont use the case it comes in,instead i have it wrapped in an old t towel so i have a rag as well to clean my hands with.the power cable and inflator hose fit under the tool strap and the tubeless repair kit sits under the seat where the owners manual is meant to be stored. pretty sure mine is a slime powersport 2000.have had it for years so could have been upgraded since. Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted March 14, 2016 Author Share Posted March 14, 2016 Thanks. It took a bit to find the best priced one on Amazon (cheaper than a kit with less in it ), but my replacement air compressor is on it's way. Quote Link to comment Share on other sites More sharing options...
DBLXX Posted March 14, 2016 Share Posted March 14, 2016 3 Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted March 14, 2016 Author Share Posted March 14, 2016 I almost thought of that. If it was small enough and sturdy, it'd work in a pinch. Most of the ones I saw looked pretty cheap in construction. Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted March 14, 2016 Share Posted March 14, 2016 You could get one of the fillers that use BB gun co2 cartridges, very compact. There are also small manual pumps, slow but compact. Quote Link to comment Share on other sites More sharing options...
XXBirdSlapper Posted March 15, 2016 Share Posted March 15, 2016 (edited) On trips I occasionally throw a small (frame mounted) bicyclist hand pump and repair kit in the gear. If you are practiced, a can of wd40 and a match will work if the bead is broken.. Edited March 15, 2016 by XXBirdSlapper Quote Link to comment Share on other sites More sharing options...
superhawk996 Posted March 15, 2016 Share Posted March 15, 2016 Starting fluid is much better for that. Quote Link to comment Share on other sites More sharing options...
TOXXIC Posted March 15, 2016 Share Posted March 15, 2016 I have the Slime one, took the plastic housing off and it fit under the seat near the tail lamp. Quote Link to comment Share on other sites More sharing options...
IcePrick Posted March 15, 2016 Share Posted March 15, 2016 I vote for a Slime pump. Cheap at Walmart or any auto store. The only failure I've seen them have is a hose blowout, and it's usually right at the pump outlet - easy repair with a Leatherman and a couple zip-ties. I've had three of them over the years, seated the bead on many a dirt bike tire out in the desert. I still have two of them, I only got rid of one because it was too large with a pressure gauge on it. Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted March 16, 2016 Share Posted March 16, 2016 Slime here also. Worked great when used and fits nicely under tail section Quote Link to comment Share on other sites More sharing options...
CBRXX Posted April 11, 2016 Share Posted April 11, 2016 Stop letting the air out of your blow up girlfriend every morning, just strap her to the passenger seat when travelling. It will save a lot of wear on the pump. Quote Link to comment Share on other sites More sharing options...
