Wolf1999 Posted October 20, 2015 Share Posted October 20, 2015 I have a 99 fi bird. Sunday I was cruising around 50mph and my head lamp looked like a h.I.d warming up then went out. Kick on my high beam to try to get it home and it did the same thing as soon as I turned it on. I don't have h.I.d's in my bike. Put a new set of bulbs in last night and on my way to work this morning it did it again. Any ideas on why it keeps blowing bulbs? Quote Link to comment Share on other sites More sharing options...
IcePrick Posted October 20, 2015 Share Posted October 20, 2015 Do you have a voltmeter? Sounds like high system voltage, likely caused by a failed rectifier/voltage regulator - probably the sole weakness of the XX. If left unattended, it will bake your battery. Properly diagnosed, it's around a $150-$200 DIY repair/upgrade to a R/R with longer-term reliability. Get a key off and a running voltage for us - at idle and at ~3500RPM - and we'll help diagnose. I don't want to jump to conclusions, but the R/R is a common fail item on the 'bird. Quote Link to comment Share on other sites More sharing options...
Wolf1999 Posted October 20, 2015 Author Share Posted October 20, 2015 I just put a Rick's R/R on it about a month go Quote Link to comment Share on other sites More sharing options...
SwampNut Posted October 20, 2015 Share Posted October 20, 2015 Then that's definitely suspect, do the voltage test as suggested. What does "HID warming up" look like to you? I don't know what that means. I have them, but not sure what you see that is related to this. Quote Link to comment Share on other sites More sharing options...
redxxrdr Posted October 20, 2015 Share Posted October 20, 2015 Although it gets argued here. The R/ R is a shunt device. It rectifies and regulates the stator output. I used to run drills and hedge clippers off of my trucks alternator. Just needed a switch and relay that dissconnected the diodes from the alternator. Easy to get 130 vac from a standard alternator. But 12 volt lights don't like it. Put your meter on the battery and measure both DC and AC . I bet you will see some high AC voltages. Quote Link to comment Share on other sites More sharing options...
IcePrick Posted October 21, 2015 Share Posted October 21, 2015 A voltmeter is a valuable diagnostic tool. 1 Quote Link to comment Share on other sites More sharing options...
John01XX Posted October 21, 2015 Share Posted October 21, 2015 Harbor Freight has them on sale for $4.99 - just saying! Quote Link to comment Share on other sites More sharing options...
partsman Posted October 21, 2015 Share Posted October 21, 2015 I just put a Rick's R/R on it about a month go Seen Rick's products fail right out of the box. Quote Link to comment Share on other sites More sharing options...
EVLXX Posted October 29, 2015 Share Posted October 29, 2015 http://www.roadstercycle.com/ Quote Link to comment Share on other sites More sharing options...
