Yakasuko Posted August 19, 2006 Share Posted August 19, 2006 Hey guys I have a 00 blackbird, and when I first got the bike about six months ago it purred like a kitten. But it was time to change the oil and I went with a honda grade oil. The slight knocking happens at start up and if I engage the clutch then it seems to quite down. But my question is do you think that there was a synthetic oil in there before I did the oil change to made this happen?? I have changed it twice but still the same problem, does the clutch needs to be changed or what? I have taken it to my local bike shop and they are telling me that it sounds okay, but I know that this is not normal. Anyone out there experience this, or have any solutions???? :icon_think: I forgot mention that I have already changed the CCT... Quote Link to comment Share on other sites More sharing options...
Aurora Posted August 19, 2006 Share Posted August 19, 2006 Check out previous posts on CCT Cam Chain Tensioners. Some people run differnt oils or weight oils which quites the noise. Quote Link to comment Share on other sites More sharing options...
Yakasuko Posted August 19, 2006 Author Share Posted August 19, 2006 Check out previous posts on CCT Cam Chain Tensioners. Some people run differnt oils or weight oils which quites the noise. I changed the CCT still the same problem... Quote Link to comment Share on other sites More sharing options...
Guest rockmeupto125 Posted August 19, 2006 Share Posted August 19, 2006 The slight knocking happens at start up and if I engage the clutch then it seems to quite down. Read what you already wrote. That should tell you what is causing the noise. Its quite normal in the XX engine. Don't worry about it. Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted August 20, 2006 Share Posted August 20, 2006 Its normal on everybike running a wetclutch. The oil in the bike is dampening the clutch plate rattle, when you pull the clutch in this prevents then from rattleing around like rocks in a coffee can. Go listen to a ducati running a dry clutch.. You think your clutch is loud Quote Link to comment Share on other sites More sharing options...
Yakasuko Posted August 20, 2006 Author Share Posted August 20, 2006 Its normal on everybike running a wetclutch. The oil in the bike is dampening the clutch plate rattle, when you pull the clutch in this prevents then from rattleing around like rocks in a coffee can. Go listen to a ducati running a dry clutch.. You think your clutch is loud You think if I go with a synthetic it would make a difference??? And let me ask you this it probably would not make a difference if I changed the clutch huh? :icon_think: Quote Link to comment Share on other sites More sharing options...
MrBadExxample Posted August 20, 2006 Share Posted August 20, 2006 And let me ask you this it probably would not make a difference if I changed the clutch huh? :icon_think: The sound is perfectly normal. I doubt changing the clutch would make a difference - except to suck away your time & money. Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted August 20, 2006 Share Posted August 20, 2006 You think if I go with a synthetic it would make a difference??? When I switched to Mobil 1 15W 50 it seemed to have helped some what. Still a bit of noise though. Quote Link to comment Share on other sites More sharing options...
SBBXX Posted August 20, 2006 Share Posted August 20, 2006 Sounds normal to me as well. Don't waste any more of your money. On a side note: when you pull the lever in, you're dis-engaging the clutch. marty Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted August 20, 2006 Share Posted August 20, 2006 you will have the same noise with a new clutch. Running a thicker oil might help dampen the noise some, but why? its perfectly normal clutch plate rattle from sitting at idle. I am running 5W- 40 oil and don't even notice mine unless I actually listen for it. Just ride the bike and enjoy it. Quote Link to comment Share on other sites More sharing options...
Graham Posted August 20, 2006 Share Posted August 20, 2006 I took out the Honda oil and put in Mobil 1 and my 2003 xx was also more rattly but that's OK it's quite normal Matey. Always better wid a new CCT, less top end chuckle, spring is $30 CCT whole is $95 AU Quote Link to comment Share on other sites More sharing options...
mrak26 Posted August 20, 2006 Share Posted August 20, 2006 I experienced the same problem soon after I first bought my '00. The noise dissapeared once the clutch lever was depressed. I bought a CCT thinking that this was the problem and it made little if any difference. I've since come to recognize through reading these posts that the noise is common and acceptable but I still found it annoying. It was suggested on one of the posts dealing with the issue that the idle speed be increased to just under 1400. Once I had done this the chattering was gone. Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted August 20, 2006 Share Posted August 20, 2006 It was suggested on one of the posts dealing with the issue that the idle speed be increased to just under 1400. Once I had done this the chattering was gone. WOW you have your bike idle at 1400RPM damn that's up there. Should make a good cruse control...lol My idle is only that high on cold start up. Quote Link to comment Share on other sites More sharing options...
mrak26 Posted August 20, 2006 Share Posted August 20, 2006 I suppose that I was misinformed. I am certain that 1400 was the number I read in the post that I read but I'm unsure of the source. I'm new tho the forum and haven't distiguished who's advice is good advice. I tried to find the post in which I read it but to no avail. I imagine that my next post will be whether or not I should learn to live with the "bag of marbles" sound that is present when the engine is idleing normally. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Yakasuko Posted August 21, 2006 Author Share Posted August 21, 2006 Thanks guys, I guess it is pretty normal. I mean it runs pretty good just that little noise that bothers me at time. I had a KN filter in there before, and that seemed to slow the bike down. I think it was getting to much air in the intake. So I went back to the factory filter, the KN was off a little and causing air to seep through the sides... And yes I removed the oring, it just didn't seem to fit flush all the way around, so now I just need to get a nice exhaust maybe to drown out the noise I hear....... Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted September 8, 2006 Share Posted September 8, 2006 I have it too. It goes away almost right away....definitely once the motor warms up a tad. It's really just a lack of lube in all places. Once the fluids get going good, I never hear it again. I'm running AMSOIL, which is as good as oil tends to get. Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted September 8, 2006 Share Posted September 8, 2006 I suppose that I was misinformed. I am certain that 1400 was the number I read in the post that I read but I'm unsure of the source. I'm new tho the forum and haven't distiguished who's advice is good advice. I tried to find the post in which I read it but to no avail. I imagine that my next post will be whether or not I should learn to live with the "bag of marbles" sound that is present when the engine is idleing normally. Any suggestions? If I'm not mistaken it's 1100RPM +-50. It will be in the service manual and owners manual. Service manual can be downloaded if you don't have it. Quote Link to comment Share on other sites More sharing options...
tapsport Posted September 8, 2006 Share Posted September 8, 2006 owners manual says 1100-+ 50, just happen to have it beside computer Quote Link to comment Share on other sites More sharing options...
county Posted September 11, 2006 Share Posted September 11, 2006 I had that problem but then I started putting in my Shure e2's and starting my CD player before cranking the bike. Now that noise is gone. Quote Link to comment Share on other sites More sharing options...
Yakasuko Posted September 11, 2006 Author Share Posted September 11, 2006 I had that problem but then I started putting in my Shure e2's and starting my CD player before cranking the bike. Now that noise is gone. HuH??? :icon_think: Quote Link to comment Share on other sites More sharing options...
