Mikey Posted August 20, 2005 Share Posted August 20, 2005 This is what I've compiled so far for swappable bits. Bike info: Front tire: 120/70ZR17 Rear tire: 180/55ZR17 Chain size: 530x110 DID530ZVM Front Sprocket: 17 Rear Sprocket: 45 Battery: YTX12-BS Sparkplug: CR9EHVX-9 Same battery as: VF750C/C2 Magna 94-01 VF750C Magna/Deluxe 94-98 VF750F VFR 90-97 PC800 89-98 VF800FI Interceptor 98-01 CB1000 94-95 VTR1000F Superhawk 97-01 CBR1100XX 97-01 CN250 Helix 86-87, 93-01 YZF600R YZF750R FZ1 Suzuki LT-F250F Ozark atv Honda TRX250 Oil Filters . Yamaha 3FV-13440-00 - Perf-Form J-503 - Emgo 10-82232 - K&N KN-303 - Purolator ML16817 - Hastings LF113 - Walmart ST6607 - NapaGold 1365 • AC Delco PF2135 about $10. • AMSOil SMF103, about $9. • FRAM PH6017A about $7. • Honda 15410-MCJ-000, about $12. • K&N KN-204, about $13. Has a metric nut on the end for easy removal. • NAPA Gold 1358, Carquest 85358, WIX 51358 about $7 to $8. • Purolator Motorcycle ML16817 about $6. Imported, not made by Purolator. • STP SMO 07, about $7. Automobile Filters, about 2.5 inches long • Mobil M1-108, about $12. Ph6607 • Purolator Pure One PL14612 about $6. • Bosch 3300 about $6. About 64mm, doesn't quite fit oil filter wrenches. A real pain. • WalMart SuperTech ST6607 about $2. Made by Champion. • AC Delco PF1237 about $6. Ph6607 • NAPA Gold 1365 about $6. • Purolator L14622 about $4. • STP S-02876 about $3. • Baldwin B1400. • Hastings LF113. Automobile Filters, about 3.25 inches long • Bosch 3323 about $6 • Mobil 1 M1-110 about $10 • Purolator Pure One PL14610 about $6 • Purolator L14610 about $4 • NAPA Gold 1356, Carquest 85356, WIX 51356 about $6 • Deutsch D-370 about $4 • AC Delco PF-2057 about $6 • Motorcraft Long Life FL-821 about $4 • STP S-02867 about $3 • FRAM, Castrol, Penske 7317 about $3 • Baldwin B1402. • Hastings LF240. I've snagged this stuff throughout the net. I appologize for not being able to give credit where due. I did my own research for the battery reference though because at the Canadian Tire, they can't handle the actually battery number, but need a vehicle for reference. They didn't have a listing for the XX so I had to use other bits as references. As for the conflicts: - K&N KN-303 or 204? This conflict was created due to a posting earlier up. I don't know which is the best. Hope this helps Quote Link to comment Share on other sites More sharing options...
Northman Posted August 20, 2005 Share Posted August 20, 2005 FWIW, I used to be a big advocate of Fram filters, but haven't used one in at least 4-5 years due to a filter test I saw online. I prefer to use the Honda filter. Other than that, I use the Purolator, or ACDelco filters. NAPA Gold are also good, as are Wix. I won't use cheap filters on the bike. The car, however, is a different story... Quote Link to comment Share on other sites More sharing options...
Mikey Posted August 20, 2005 Share Posted August 20, 2005 Where do you get those Purolator, ACDelco filters, NAPA Gold or Wix in Canada? I've only found the Frams at CT or PartsSource. I'm assuming the NAPA gold is found at NAPA. Quote Link to comment Share on other sites More sharing options...
Northman Posted August 20, 2005 Share Posted August 20, 2005 I can buy them through suppliers, Mikey. Ideal Supply carries the NAPA, we buy Purolator through Uni-Select, and my dad bought me the ACDelco filters through General Auto Parts in Rexdale. Any AC Delco dealer should be able to get them for you. Wix can also be bought through Uni-Select. Check your local automotive jobbers. I'm sure there's something available in Hamilton. Quote Link to comment Share on other sites More sharing options...
MileHi Posted August 20, 2005 Share Posted August 20, 2005 I know many people who use Fram. I used Fram also for many years. Never heard of anyone that I know that had any trouble from using that filter. I do use the Honda now but I wouldn't lose sleep if the Fram was on now. Add me to the list... Fram filters on my old Buell S1 and a couple of friend's Harleys... I know... I know... (I got rid of the paint shaker!) Fired the H-Ds up and literally BLEW the oil lines off of the cases... Mine stayed on, but there was a high pressure spray from most of the oil line fittings. That cured me! Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted August 20, 2005 Share Posted August 20, 2005 Some years back, I watched a guy get a oil bath when his AC Delco oil filter blew up on his chevy when he had his head under the hood. Kind of cool, really. Quote Link to comment Share on other sites More sharing options...
SBBXX Posted August 22, 2005 Share Posted August 22, 2005 FWIW, I used to be a big advocate of Fram filters, but haven't used one in at least 4-5 years due to a filter test I saw online. +1 Can't remember where, but I read something that convinced me to stop using the FRAM filters. marty Quote Link to comment Share on other sites More sharing options...
arcticflipper Posted August 22, 2005 Share Posted August 22, 2005 Found that the Honda Goldwing GL1500 and GL1800 uses the exact same filter in South Africa, same part no. and all... only diffs is that they are for some reason cheaper than the Bird filter?? same part no??? ZAR 180 to ZAR 320 for Bird Honda Filter, while ZAR 90 to ZAR 150 for GoldWing Filter Quote Link to comment Share on other sites More sharing options...
RTGwalt Posted August 25, 2005 Share Posted August 25, 2005 When you guys say "the oil filter blows", do you mean the metal splits apart or the rubber gasket blows out causing the torturous oil bath? :?: Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted August 25, 2005 Share Posted August 25, 2005 The AC filter I saw, blew up! Side split. :shock: Quote Link to comment Share on other sites More sharing options...
EVLXX Posted August 25, 2005 Share Posted August 25, 2005 What a load of shit.People are so full of shit and misinformation its pathetic. So true! Quote Link to comment Share on other sites More sharing options...
EVLXX Posted August 25, 2005 Share Posted August 25, 2005 My last oil change...oh... nevermind... :oops: What.... somethin happen? :roll: It's OK you've got a good excuse, and I don't think anybody else here is going to crack there oil pan with a "HAND TIGHT" manuver. Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted August 25, 2005 Share Posted August 25, 2005 I'm using the Purolator Pure 1. PL14612 I believe I'm getting superior filtration from everything I've read, are only $6, and can buy them even on Sunday. SO Nik, what did you do with the old oil pan? Would make a fun target to blast holes in. Although I'm sure even a .22 could punch a hole clean through. Quote Link to comment Share on other sites More sharing options...
N1K Posted August 25, 2005 Share Posted August 25, 2005 SO Nik, what did you do with the old oil pan? As soon as I get it packaged I'm going to send it to Trurotor so he can fix it and do with it what he pleases. Quote Link to comment Share on other sites More sharing options...
