OBELIXX Posted September 23, 2005 Share Posted September 23, 2005 Afam part: AS 11508-46 ....delicious little sprocky, gold anodised alloy and looks the "mutts nuts". This alloy is largely aluminium but with other "stuffs" added for superior strength. Would not last long if it was your common and garden variety window frame aluminium. I reckon it is about 9 on the bling scale and even if it was shagged in 15k it is worth it. Get a chubby every time I look at the back wheel Quote Link to comment Share on other sites More sharing options...
PlasticxxHead Posted September 29, 2005 Share Posted September 29, 2005 Trying to keep my head from spinning.. I am doing the new chain thing.. and the one down front sprocket seems like an intriguing idea.. can the vfr 16t front be put on with a stock rear sprocket? I understand that the wheel base will change.. Anything we can do to manually adjust the speedo.. without a $100 dollar box..? some kind of dial we can turn down? Quote Link to comment Share on other sites More sharing options...
Guest rockmeupto125 Posted September 29, 2005 Share Posted September 29, 2005 The VFR 16T can replace the stock front sprocket. Chain size (110) links remains the same with the stock rear sprocket. I doubt that you'll notice the wheelbase difference to be of any significance. There's nothing you can do to manually adjust the speedo except put tape on the speedometer face and write in the numbers. I recommend the Ahlman unit like I have to correct the speedometer error. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted September 30, 2005 Share Posted September 30, 2005 Do you guys really look at the speedometer? I never do unless I am stringing it out. If I am trying not to speed because there may be a tax collector around, I just go with the flow of the traffic. Quote Link to comment Share on other sites More sharing options...
