NQ Rider Posted September 12, 2004 Share Posted September 12, 2004 Hi I have just purchased a 2nd hand CBR 1100XX (Dec 2003) model 8000 kms on clock - perfect appearance BUT it produces some terrible gear box (whine) noises!!!!! :-o Also gearbox seems very clunky? :-o Is this normal?? I have just given up a Suzuki GSX F 750 to get this and I am a bit concerned as Suzuki was as quite as a mouse and very smooth. :mad: Thanks NQ Rider Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted September 12, 2004 Share Posted September 12, 2004 No, this is not normal for the XX. Are you sure that it is the gearbox and not the chain? Inspect the chain for tight links. Lube and adjust. Then, I would change the oil and filter. Try Mobil 1 15w-50 (red cap). It makes for smooth shifting. Quote Link to comment Share on other sites More sharing options...
MileHi Posted September 12, 2004 Share Posted September 12, 2004 I don't know about the whine, but the "clunky" shifting is that you're used to the Suzuki tranny (buttah smooth). I too felt that the tranny was clunky when I first picked up the 'Bird after putting many miles on my Bandit. You'll get used to it and will finally not notice the "thunks". As was already mentioned... A good synthetic oil will smooth it out some, but riding it and getting used to a different bike will amke all the difference in the world. Quote Link to comment Share on other sites More sharing options...
2equis Posted September 14, 2004 Share Posted September 14, 2004 Geabox whines Give it a smack and tell it to get back in the kitchen!!!! Quote Link to comment Share on other sites More sharing options...
Violent J Posted September 16, 2004 Share Posted September 16, 2004 Mine whines in third gear when putting through town, don't know why, don't care, it's a Honda, good to go. Quote Link to comment Share on other sites More sharing options...
SBBXX Posted September 16, 2004 Share Posted September 16, 2004 Gees you can't compare it to that Suzuki gearbox, don't even try. Mine's always been clunky. I would change the oil/filter too, first thing. What does the whine sound like? "I wanna go on a cruise"? "We never talk anymore"? Leave the wife at home next time and see if that fixes it. marty Quote Link to comment Share on other sites More sharing options...
AXXKicker Posted September 16, 2004 Share Posted September 16, 2004 what they said. i thought for a day or so that my gearbox was noisy, but i just needed to adjust my chain and lube it up. after that, it was smooth as hell as always. Quote Link to comment Share on other sites More sharing options...
ar50racer Posted September 20, 2004 Share Posted September 20, 2004 Like the others said check the chain and change the oil to a sythetic( I like Amsoil), from there the noise your hearing could be the counter balancers. There is a backlash adjustment that could make it wine if it's too tight. Quote Link to comment Share on other sites More sharing options...
demon Posted September 20, 2004 Share Posted September 20, 2004 Just a thought here, but has the front sprocket been changed to a 16 tooth aftermarket sprocket? If it has, then it will whine a bit because it doesn't have the rubber damper on it any more. Wouldn't take a couple minutes to check. Pull your sprocket cover off and check to see if it has a rubber coating on it and then count the teeth. Quote Link to comment Share on other sites More sharing options...
Helvet Posted September 20, 2004 Share Posted September 20, 2004 It could also be a clutch problem. Maybe too many sprints? Does the noise go down when you use the clutch? Quote Link to comment Share on other sites More sharing options...
