Phalanx7.62 Posted May 22, 2004 Share Posted May 22, 2004 Is there a heat shield that goes between the header and the right lower fairing? What about foil sheeting on the plastic? Before I painted my bike I noticed that the right lower fairing got hot enough to affect the paint. I do not want this to happen again. Thanks.. Quote Link to comment Share on other sites More sharing options...
Furbird Posted May 22, 2004 Share Posted May 22, 2004 That's a good question. I don't know what you could do to the panel itself to dissipate heat considering the proximity to the header. Usually, materials that will adhere to the plastic will either burn up because they can't handle the heat, or end up transferring the heat to the outer panel anyway. Your best bet would be to wrap the header like they do on drag cars. If you're really swimming in money, you could have the header coated with Jet Hot which will keep it cooler. My vote is for the wrap. Most auto parts stores have it, but if not you can pick it up at summitracing.com. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted May 22, 2004 Share Posted May 22, 2004 One thought on wrapping, it is hard on the pipe. Most car header manufactures will not warranty their product if the header is wrapped. Quote Link to comment Share on other sites More sharing options...
nickc2s Posted May 22, 2004 Share Posted May 22, 2004 You could line the plastic with Plumbers heat shield used to prevent burns to anything close to the torch. It has the same look and feel as fiberglass mat and is about 12- 15 dollars for a 10x12 sheet. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted May 22, 2004 Share Posted May 22, 2004 Asbestos would work great. Years ago (before all the crap) when sweating water pipes together, I would put a piece of asbestos on my leg and use the torch on the pipes right on my legs. The stuff works. Quote Link to comment Share on other sites More sharing options...
Phalanx7.62 Posted May 22, 2004 Author Share Posted May 22, 2004 Thanks for the feedback. I found some high heat Dynomat (sound absorption material) that is foil-faced. That should do the trick. Thanks again Quote Link to comment Share on other sites More sharing options...
