Phalanx7.62
0 Neutral
  • Website URL
    http://
  • ICQ
    Grand Rapids, MI
  1. Last time I changed my oil, I trued the washer on a flat 220 grit stone. This removed any irregularities in the washer and flattened it out. I had the time and forgot to buy more washers. Bottom line, no leakie.
  2. I also have a 98 and went with Scorpion Carbon slipons, K&N filter, and K&N jet kit (Dyno Jet). I put the larger set of mains in, they call them 140's. Then you dril the slides with the supplied drill bit and I put the clip in the 3rd position on the new needles. Runs much better, but there is more room for improvement. I have some dyno time coming this spring. I think the exhaust made the biggest change of course.
  3. For those of you who kept guessing after I answered, I guess you're wrong....
  4. Sort of like a Big-Bang motor, right? MotoGP uses this too, or I could be wrong.
  5. CR250. Or a 1972 Yamaha GS340 snowmobile. They fit either.
  6. So I am in my local Honda dealer, kicking tires and picking up a few items from the parts counter. I overhear part of a conversation between a service guy and a customer. The customer was saying he bought a CBR in the fall but he had problems with it and hardly rode it. Everytime he turned on the high beams, the bike would immediately die. He would have to pull over, turn the high's back off then restart the bike. The service guy was understandibly curious and was asking more questions. The guy then gestures himself turning on the high beams with his right hand on the right clip-on. I was stunned. I was next in line, but I could not speak to the parts guy. I was like, "Uhh.... Just give me 3 NGK BR8ES sparkplugs." I hoped to all that is holy that guy was joking/trolling/shitting the service guy. I feel like a genius now.
  7. Phalanx7.62
    Paint Q
    Mmmmmmm Termo pipes.....mmmmmmmmm
  8. On Jo-Jos site there was a Bluebird with this front end as well.
  9. 1 bulb kit please. $135 sounds groovy.
  10. +1 +2 +5 8) +another +another, Also is this a plug and go setup or will we have to modify the wiring and headlamp socket. Do you have any install instructions or photos? Thank for putting this together +12.5
  11. I just peed my pants. Thanks.
  12. I have a supercharged Cougar that I put an adjustable fan controller on. It had a rheostat on it to adjust it. I installed a temp sensor into the radiator near the hot side inlet, and set the fan to come on shortly after the tstat opens. I also put a cooler temp tstat in it.
  13. NO!! Its an Erion with a D&D decal!! ERION I SAYS!!! AUGH!!!
