Everything posted by ptxyz
just for kix, i took a wire wheel on my drill to 'em for a few minutes. man, chrome's tough! easy enough to blast away the bubbly parts but, just putting a scuff on what's left takes some pressure! oh yea, brake fluid was another thing mentioned...
i got what at first glance was a good price on a front wheel to get my bird back on the road after my curb hopping incident. now that i'm faced with removal of the crappy chrome, i'm wondering if i shouldn't have spent the extra coin for a black one... i've read some on-line tips about using bleach, oven cleaner, 30% muratic acid and a few others that escape me at the moment. any advice on this? i'm not looking for a perfect finish. the bike was crashed and painted flat black by a previous owner. rattle can black is what i'll probably end up doing. i'd be happy with a 10 footer finish on this front wheel. don't care to spend any more coin to complete her rehab. here's the offender.
thanks for the sanity check, gents! while i love my big green pig (klr), i'm really missing my bird!
it's been almost a month since my bird's (fuel injected 2000) been out of commision after my curb hoppin'. the last piece i'm waiting for to make her whole again is that free front tire from pirelli. how concerned should i be about the inactivity? i know some of you here don't ride for long periods, any problems when it's time to wake 'em? should i start her up every few weeks? drain the fuel and run her until she sputters? just be patient? c'mon pirelli! it's bad form to complain about waiting for something that's free but, some communication would be appreciated...
never had to do so myself (current bird's a 2000, also has had a rough life) but, if the price is ballpark, i'd stay with oem.
if you're comfortable with your sexuality, how about a scrunchie? just don't let your pals see under your seat...
i've used a dremel in a pinch. kinda slow though... big box hardware stores sell a little kit that includes a drill attachment and balancing tool. also slow, depending on the drill. don't see why one couldn't take it to a curb at the proper angle if nothing else is available. bench grinder makes quick work of it. around 45 degree angle. make it too sharp like a butcher knife and it will knick and dull more quickly. grandpa was a landscaper / gardener. before i was old enough to have "real" jobs, i used to work for him.
probably best to get 'em off the ground with jack stands. if not that, at least inflate to the maximum pressure. i wouldn't expect flat spots unless the tires go flat or are under inflated to begin with.
some bike particulars will be helpful here but, let's assume an early (97-98) with stock pipes and not unreasonably high miles (under 30k?). i'd think you'd only get the full benefit of a jet kit with aftermarket pipes. while a properly installed & tuned kit will help with throttle response, there's not much new power to be had with a jet kit alone. if you're bike's otherwise stock and you don't want to break the bank, have the carbs synced (as a mater of course, this is done when installing a jet kit as well). with a couple of adjustments each (fuel / air, butterfly stop) on each of the 4 carbs, there's plenty to optimize here. my old '97 was happiest right after a carb sync. if i recal, i traded her at around somewhere over 40k and the valve clearances were still within spec.
i share this from another forum for kawi's klr. not sure if the link will work (or is cool with the admins...) but, i'll try; http://www.klr650.net/forums/showthread.php?t=110552 seems they don't like freezing temps despite no explicit warning from the manufacturer. disappointingly, bridgestone has not done right by the owner of these cracked tires.
i'd say, yes it does increase up to a point. the chain run will be the longest when the centers of the front spoket, swing arm pivot and rear sproket are all aligned. the honda manual states the chain tension should be checked with the bike on it's side stand. less convenient than the center stand but, some needed weight on the rear end. the attached pic might help you visualize how the chain run can change as the suspension moved up and down. a few dirt bikes (lots of rear suspension travel) have the rear sproket and swingarm pivot in the same axis to maitain chain tension.
Blackbird parts for sale....LAST CALL!
ptxyz replied to HANKSXXX's topic in The Sales Floor -- For Sale/Wanted
pm sent on the vfr bars (#36). -
Exhaust options/suggestions for 97 (slip ons vs full system)
ptxyz replied to 2fast4love's topic in The Garage
i had a full yohsi system w/ carbon can on my old '97. i believe that's the way to the biggest bolt on exhaust gains. the stock headers appear pretty restrictive in comparison. had a shop do the install along w/ a jet kit (dynojet i think - paid around $1200 all told). i'd suspect you'd need the jet kit w/ a full system. might be able to get away w/o if you get only slip ons depending on the back pressure. big difference in power and throttle response for me. afterwards it would easily lift the front in 1st and 2nd and there was more on top as well. while i loved the sound, it was loud. i got pulled over once by a cop who only heard me opening her up on the freeway (no tix, he saw nothing...). still, i loved it. i haven't done the same on my current 2000. i'd spend the dough elsewhere unless you really need the sound. perhaps some mild slip ons and having somebody good syncing your carbs will satisfy. mine seemed especially happy after the carbs got dialed in. on my current bike, i like being quiet. the top end feels stronger than my '97 but, i still miss the old bike's low end response. i'll spend on comfort or suspension before exhaust. please let us know what you end up with and how you like it. -
have you noticed if the rear axle is moving? perhaps make a mark with a sharpie to see if the axle's really moving or the chain's loosening. should only be 1 washer outside the swingarm on each side. a too tight chain will quickly get longer.
assuming you don't feel any wobble on your front end, probably no need to re-balance. with the dunlops i used to buy regularly, there would often be no weights needed, just mount 'em with the mark (little yellow circle marking the tire's light spot) at the valve stem. fewer weights on a properly mounted and balanced tire / wheel assembly is indicative of a precisely manufactured tire.
2000 Honda CBR1100XX Blackbird For Sale
ptxyz replied to Moto-Charlie's topic in The Sales Floor -- For Sale/Wanted
while i'm not in the market, could you comment on the fork brace? i had one on my old '87 vfr and really liked it but, my own 2000 blackbird's still stock up front. very nice ride. hopefully you'll find a buyer who appreciates your setup. -
i have one of these at home and it works pretty well. i might improve on things with a stiffer walled vaccum tube. the hot oil tends to collapse the tube under vaccum. oil still gets pulled through, just a bit slowly. gives time to change the filter, i suppose... http://www.amazon.com/LiquiVac-Liquivac-To...der+oil+changer holds about 2 gallons. combined with the cartridge type filter on the top of the motor in the wife's car (benz), i no longer have to crawl underneath!
+1 on corbin's "helpfullness"... you'd think with what we pay for these things and the fact they have a factory full of craftspeople, they'd be more willing to let them work.
everyday, you're in the ballpark. if the bike's running well (fuel pressure regulator and leaky vaccum lines fixed, brakes not draggin', tire pressures up to spec.), your throttle hand will be the biggest single factor. in my experience ('97 carbed & jetted with yoshi full system, unknown tall screen & '00 all stock - both bikes had my givi 52 liter tail box); 25-42 mpg. i'm about 5'8", 145 lbs. 25 mpg is my daily commute, about 8 miles each way with sometimes heavy freeway traffic - i ride like i stole it! 42 mpg riding with a group of friends on highway 1 weekend traffic. i experienced the high and low on each bike. i don't think your size / weight has that much to do with your mpg on such a powerful heavy bike.
Anybody ever lose tools out of the tool bag under the seat?
ptxyz replied to XXitanium's topic in The Garage
nice model holding the cb125 tool kit! gotta wonder how's the face... i'd think the tool kits are relatively bike specific. although you're looking at the right brand, i'd try to get model specific or just replace any tools missing from yours with something from flaps (friendly local auto parts store) unless you're determined to stay original. of course, you could look at the aftermarket kits as well. as for the bird's oem strap, a heavy duty rubber band or small bungee should do. i keep a cargo net, some bungees, a tire plug kit and co2 inflation kit wrapped in a plastic bag under the seat near the tail light. being wrapped up in something kind of compressible helps to keep things in place. i'm now gonna spend some quality "me time" with that model pic... ha ha! -
mine got fried in it's hot oil bath last year. it was replaced with a rick's electics and so far, so good. still using a used honda r/r though...
i've piggybacked on that thread... thanks for that, i'm learning along with you. your description of the sucking sound reminded me of the time my '97 coughed off a vaccum line to the carb on the right side. does the sound kind of pulse? although yours is f.i., are you confident you didn't miss any vaccum lines?
if you can get a multi meter, good idea to check the stator. there should be between .1 & 1.0 ohms resistance between any of the 3 yellow wires coming from the stator and ground. if out of range, you probably need a new stator. mine went bad, the poor things are bathed in hot oil. mechanic showed me where a couple of the coils overheated and fused. it was replaced with a rick's electics and been good for about a year now. i now have an extra r/r.
