I'm sure this has been blown up a million times but searching comes up with all kinda shit. I'm mostly interested in a cross reference to a purolator or motorcraft number if one exists unless there's strong evidence that I should stick to OEM or another specific filter. Also, if someone can educate me on making the search here better that'd be bitchen. I typed oil filter and got a million things that have nothing to do with oil filters. I'm guessing it's searching anything with either word, is there a way to make it search for both together?
Header wrap on stock headers; anyone tried it?
superhawk996 replied to superhawk996's topic in The Garage
Thanks. I did consider rust, but I rarely ride in the rain and there is a water proofing coating for them I read about some time back. I would also be painting them with extreme heat paint first for a little extra protection. Unless I hear some horror stories about using it I'll be putting that on my to-do list. I already have a roll of wrap. -
Question on choke use and normal warm-up on a '97 Bird.
I thought that, but following the electrical schematic it looks like the lower bulb is the low beam. I rode it last night and the light does appear to be the high beam after all (lower bulb). I'll get onto the bulb and see, looks somewhat time consuming so I wanted to eliminate other possibilities first. Thanks. -
Tho you found and cured a problem I'd still check it in case there's other electrical issues. There are ways to check for current flow in the plumbing and to the water directly. I don't know it well enough to instruct how to, but it's pretty simple and you should be able to look it up or maybe ask Carlos as he knows about nearly everything useful. And yes, even with an anode you can eat stuff up in a hurry with enough current flow. The anode helps, but can't fully compensate for a faulty system and I think it also depends on the direction of current flow as to how effective it'll be.
I read a little bit about wrapping stock headers somewhere here but there didn't seem to be decisive evidence whether it was a good or bad thing. My biggest concern is that they may crack. This was mentioned, but not confirmed. I'm not looking for the 500 extra HP it gives, just looking to have less heat around my legs. Less heat around the engine and rad. are a big bonus. There was also some mention about them catching fire but I assume that only happens if they accumulate oil (?). I'd especially like to hear from someone who's done it and can tell me their experience.
I've stripped many radiators and all have had the same style cooler in them, none have been just a simple tube. The trans fluid gets hot on it's own, considering it's under constant pressure even with the engine at idle. You start blanketing that already hot pipe with coolant that's at the same temperature or close to it, all you are doing is insulating that heat. Fluid pressure is not what creates the major heat in a trans. The coolant at the end of the radiator where the cooler is will never get close to the trans. fluid temp without cooking the engine. Everyone's entitled to their own opinions, but not their own facts. Decide for yourselves if you want/need a cooler, I only share the knowledge I've acquired after decades of auto & truck service and racing. I've worked on bikes to big-rigs. I've met and trained with engineers from companies specializing in stuff from u-joints to threadlocker (and yes transmissions). I would never condone adding any kind of unregulated cooler to a trans or anything else on a vehicle, engineers don't either. I think the OP's personal experience of a trans. lasting over 200K miles is pretty convincing evidence that they don't all need a cooler.
I was going to suggest the synchronization but you took care of that. Glad to hear your baby is purring like new again.Its always good to go over the entire bike when you get a used bike. Congrats on the amazing deal. I love my 97 she has 68, 000 miles on her now and runs like new. This winter I am hoping to pull all the plastics and repaint them and while they are off I want to try to lean out the main jets a tad. I have a factory pro jet kit so I should be able to just lower the neddles a clip or 2. It is jetted for 800 ft above sea level and I am only about 40'. She has just been running so damn good I hate to mess with it but it may be even better when I am done. Thanks. Mine has 50k. I was content when it was running shitty, now I'm jazzed. Still have to figure out the headlight. It only works on high beam, but actually illuminates the low. I'm guessing I'll find some kind of crackhead 'repair' on it. IF your bike was tuned for higher altitude you'd want to richen for lower, not lean. In any case, 760ft isn't enough to rejet for IMO. If it was absolutely spot on perfect (unlikely) and you wanted that same level of perfection then you'd richen a hair. The only perfectly tuned modified carbureted bike I've ever ridden was my superhawk. It was Jardine's test bike for building their exhaust and they spent lots of dyno and riding time making it perfect. After I sold it the buyer (a friend) took it to a performance shop because it had developed a little miss and I didn't have time to mess with it. They insisted it'd run better with a rejetting. I told the guy to NOT let them mess with it, but the shop kept insisting it'd run better and faster. They installed a stage 2 jet kit. I got to ride it afterward and from cold start to top end it sucked. It went from constantly trying to kill you power to not lifting the from without a clutch dump and the pipes were blackened with carbon within a few days. No kit is perfect unless it was designed for your exact set-up and even then won't be 100% out of the box. -
This is what the cooler salesmen tell you to scare you into buying their product. Tho your coolant temp may show 200, that's the temp leaving the motor. The cooler is always at the cold end of the radiator and way below that or the engine would overheat long before you could hurt the trans. Regardless, the trans and the fluid will not be damaged at all at 220. Externals can help if you NEED one, but hurt otherwise. You want the fluid to warm up as fast as possible and if the fluid always stays cold it'll accumulate water and other stuff and be a bigger problem. You want all your oils to regularly get hot enough to shed water or it will accumulate. At 207K miles you've proven you don't need a cooler. Would the solenoid have lasted longer with one, maybe. Would the fluid have accumulated water and possibly become acidic and attacked stuff with one, maybe. I have many cars & trucks, and tow regularly. I've never lost a trans and don't have any add on coolers.
It's probably leaking somewhere hidden and evaporating. Pull the tank and look at the hoses and stuff behind the motor. Some leaks will only flow cold then seal up as things expand and soften, some only with a hot engine when there's pressure.
Woohoo! I had a gut feeling (and hoped) the crappy idle might be carb synch and not plugged jets and it was. It was so far off I'm guessing someone did it, there's no way it could wear/shift on it's own this badly. At idle two throttle plates were fully shut, one open about normal, and one way open. I don't have a synch set so I used the force and some engine whispering. I can now back the idle under 400RPM before it chugs and dies out, at 1100 I can barely feel it running and the clutch clatter is entirely gone. I can now feel the normal off-idle lean spot, but I'm going to enjoy riding 'till it gets shitty cold then re-jet and do a major service at the same time. -
Finally getting to "that point" I think
superhawk996 replied to SR71BLACKBIRDXX's topic in Diet & health exchange
I peaked out at 255 at about 23 years age and did a fast. I was loosing weight fast enough to step on a scale 2-3 times a day and see it dropping. I went down to 165 and crept back to 175-180 where I've hovered for about 20 years. I can't say I'd recommend my lifestyle of coffee, rum, and cigarettes, but at least the weight stayed off. The only thing I can attribute to keeping lean is activity. I don't do any gym type exercise, but I'm relatively active in day to day life. I eat all wrong; no breakfast and large dinners. I eat mostly meats but carbs as well, so keeping active is my only salvation in not being fat again. If you have a desk job you need a gym or preferably a hot chick(s), that's great exercise and a morale booster! -
Yes it does but there is no point in revving it past red line. Cool. I know there's no point, just wanted to know I have back-up for when..I mean in case I screw up. Thanks. -
Squeeze the clutch and the noise goes away, so yup, clutch rattle. -
I'm excited to get to work on it, but don't have the time right now. I put some Techron in the tank; it works wonders on injectors, carbs not so sure. The idle is rough and the clutch rattles. The guy selling it said it's cuz it has 'some kind of wet clutch set up', I rolled my eyes and said "yea, like every other Japanese bike, if it had a dry clutch this would be ok". It rattles more than I'd expect for just having a light misfire, sounds similar to the Ducati 999 I had, so there may be something going on with the clutch too. The guy let the registration laps so I only get to stare at it 'till I get that taken care of. Ok, I had to take another test ride after unloading, but then back to just thinking about riding. Question, these do have a rev limiter right? I've only ridden mellow, no more than about 10K RPM so far. -
Thanks guys. That is about what I expected. I took another short spin today and confirmed she probably needs some carb love. I'll wait 'till I've checked a few things out before stripping them, but it seems to be a carb issue. -
I just bought it and I'm wondering what's considered normal or proper use of the choke and how long it takes the motor to run normal without the choke on. It has stock exhaust and I'm assuming stock jetting. It seemed to take a fairly long time running to idle without some choke and it was about 80 degrees out. I know some engines take longer than others so if anyone can clue me in to an ambient temp. and time to perfect idle or a position of the temp gauge when I should expect it to be running right I'd greatly appreciate it. The seller is not the brightest bulb in the box and was pretty clueless. The bike also sat a for an unknown time so it may need a carb overhauling, but getting some kind of baseline of what's normal will help to figure out if it needs work. THANKS!
