BCBird
0 Neutral
  1. Why do you avoid "day time" running lights? No headlight on during the day? Wouldn't you be more visible to oncoming traffic? However, you just replaced the bulbs with those leds? No issues? Thanks
  2. I can't answer your question however I'm curious as to when and where, if you're talking about the Bird, when you would want such an application.
  3. www.langka.com An interesting and professional looking product line. imo
  4. I have a full set of Goodridge lines plus clutch from Jaws. It took five hours to install and needed a "special" bleeding tool. All in all it's a great improvement, but it was spendy. I didn't do the install. EBC HH pads, Motul 5.1 Hydraulic fluids. 143,500 kms. '02
  5. Why not an Acumen Voltage indicator plus gear indicator?
  6. Would the above affect the daily "rideability" of the Bird?
  7. I use Motul injector cleaners every few months and the engine cleaner with oil changes. Sometimes I use Techron. Others use SeaFoam.
  8. BCBird
    New tires
    I haven't run Dunlops but I just installed P2s and I'm very happy with them. RoadSmarts seem to be highly recommended in ?Europe. Avons in GB, Aus, and NZ. I think it depends on types of roads in you country. My next tire will be Dunlops. imo
  9. If you run slip ons with a pc iii on an '02, will it still improve as stated above. I've never changed mine out in 140,000 kms. I'm always looking for improvements but don't want to throw dosh away for nothing. I'm also a sucker for "snake oil".
  10. I've always liked those bikes, especially the 1000. With full farings and luggage, they make a decent touring bike. imo
  11. I've replaced my wheel bearing and head bearings once in 7 years and 137,500 kms. I will be replacing the cush drives when I install new tires in a couple of weeks. I bought the bearings and cush drives from Jaws. I do feel a little play when I break at slow speeds in the front and my tech will check it out. I can't image replacing those items so frequently. All my 2 cents of course.
  12. Very sweeet looking Bird. Perhaps some gold Pazzo levers, gold Heli Bars, gold bar ends, and a golden bank account. Very trick looking Bird, for sure.
  13. I replace my stator on my '02 at approx 60,000 kms. I replaced the r&r at approx 125,000 kms just to be on the safe side. I used oem on both occasions. I have 137,500 kms at the moment. I don't like after market for electricals personally. To each his own. Don't get stuck out there b/c of an aftermarket part. imo
  14. I have used Motul coolant for many years. I recommend anything Motul. imo
  15. BCBird
    Hard Luggage
    The top box also can be fitted with a brake lite which is an excellent safety feature. There are liners for the bags which make it easy to load and just take them into the motel/hotel/camp site. If you install the brake lite you won't be able to use the smaller side bag on the top box position. Givi is stable at all hyper speeds. I took off the back rest to install a Corbin backrest with the Corbin seat. Do not, I repeat, do not bother with Beatle Bags.
