RXX
Everything posted by RXX
  1. Yeah, this is actually a pretty good question.
  2. It is mounted on a magnetic base for ease in removal. The unit is mounted high and is very visible. That lends itself to sticky fingers. I have used one for years and it would require less fiddling when I get off the bike. The telephone jack in particular is more difficult to remove since it has that tiny tab on it. I have a screamer unit on the bike and it requires being connected via the audio jack. As much as anything, I hate the lack of feng shui exhibited by the designer. Not gonna happen. That unit has saved me so much money it is stupid. The bird is just so awesomely overpowered these little 35-40 mph roads are almost impossible to ride on responsibly.
  3. My Beltronics RD has a serious design flaw. It uses a 4 wire phone jack for power and I guess other stuff, then it has a mono speaker jack. I have always thought this is retarded, there are 2 things to unplug when removing it. If I could put the two in a single jack, like maybe a CAT-5 thing a ma jig, and have it as sort of a pigtail, I could more easliy unhook it. A CAT 5 wire should easily be the right-ish amp/current/relgious preference to do this, right? Thinking about it critically makes my head hurt, but it seems loke it should work, right?
  4. RXX
    Gas Tank Question
    Small is a realtive term, of course, but I get your drift. This is a nekkid tank, so no hoses or fittings to get into. Once I put them in, I will use air pressure to knock them around, and a magnet and vacuum for removal.
  5. RXX
    Gas Tank Question
    Yes. Jackson would be cclose to 8 hour round trip. I have BBS. Plus, they are round.
  6. RXX
    Gas Tank Question
    Same here except for the Stabil
  7. RXX
    Gas Tank Question
    Thanks for the help guys. Well, by a month, I guess I mean up to 4 or 6. I get sidetracked easily and often. And yes, I thought about coating the inside, but jesus on a cracker, 85,000 miles, 20 years old, bike worth maybe $1200, why? I won’t be riding in 10 years. But tell me your experiences. I did it to a sportster about 30 years ago and do not remember anything about it. Yes, on my ‘99. It had an awful lot of what I assume is varnish. I have the fuel pump off, and can reach in there. I got a big speaker magnet in there and it did come out coated with rust, so I assume the shit left inside is the remains of all the negative karma that has flowed from me while riding to be bottled up there. Maybe I should leave it there, like Dorian Gray’s portrait. I vacuumed it out and am going to put a couple pounds of BBs in it to break up the rest.
  8. I am working on my tank right now. By right now I mean for the last few months. The interior had a bunch of shit in it that I have pretty much cleaned out. Thing is, it will prolly be at least a month before I get it installed and filled up. Is there something innocuous and cheap I can coat the inside with to keep it patent? WD-40? Mineral oil? Thin motor oil?
  9. Makes sense. There are no snakes in Ireland, so prolly no rodents either.
  10. Duh. It is a good process simply because dealing with temptations is just life. There are multiple ways of dealing with any specific temptation, and we are bombareded with temptations from the moment we wake until we take our dirt naps. We cannot ge5 away from temptations. Breathing, not a temptation. Pissing or not...... temptation. Temptation equals choices, and fuck I have problems with the whole “choice v. choices” deal.
  11. RXX
    I need a switch
    May be a hijack, but I installed a Stebel Nautilus http://www.stebel.it/stebel/products.asp?IDserie=14&uso=1&tipologia=moto on my bird and used existing horn switch. Installation requires a relay, but otherwise pretty straight forward. It is the primary horn, the OEM is now a paperweight somewhere.
  12. I’ve been wondering where you have been. I have seen your bike, that is a great price!
  13. $325.00 2 years old, stored in box. I have used it for a total of <2 miles. I had a panic attack using it. It will not go on me again. https://www.motosport.com/leatt-gpx-65-neck-brace
  14. RXX
    Gas filler pm
    Bummer. In dim light, the thread title looked like “gas filler porn”
  15. Ping Zero. I have. a PC3 on my 99. Got it from him, and it came with a computer. I am reasonably sure that is what is on it.
  16. Huh, the filter that came out was the straight one. I KNOW it is original since I bought the bike at 2700 miles. Already bought the crooked one. Prolly the last one I'll get for the this iteration. OK, KNOW may be a stretch, but pretty damned sure.
  17. Way ahead of you there, buddy. Have one in my cart right now. $55 and shipping. About to order the assembly gasket also. Like I said, it is not rust, and easy to clean out. Air gun and BB’s ought to do the trick. Might use Slappy’s warm milk recipe just in case.
  18. Well, never mind. After taking the fuel pump off, what I found was a crust of varnish or something that flew right off when hit with a high-pressure hose.
  19. I just drained a couple year-old tank of gas out of my bike and there is some rust patina inside. Both are too expensive to buy 6 gallons to fill the tank. Is one demonstrably better than the other?
  20. Craig, what model is it? I am about to get a new one.
