blackhawkxx
  1. New plastics come with new paint.
  2. Or, if you had a factory stock replacement part, it would also be a hunk of cake.
  3. Honda F-3 did the same thing but the tubes were not inside the ram air tubes. I don't think that it would be as easy as it sounds to get perfect.
  4. You must also pressurize the fuel bowls also or it will not work.
  5. While not being Joe either, I can't remember the brand of my stands but they have four wheels instead of two (per stand) and seems alot more steady than the two wheel units.
  6. Man, you sure have all the toys and bling. Yea, I have a front and rear stands but I had to buy mine used off of e-bay. Does your wife know about this?
  7. I bet a new front tire will fix that even if it is a Dunlop.
  8. Only Joe would know how to spell Mr. Honda's name.
  9. A fine hacksaw blade will cut the foam pretty good also.
  10. :bluebarf: Sorry, to me that is like watching your daughter give lap dances at the corner bar.
  11. If I were you, I would look for a cheap stock seat. That way, you could try different things to find out what works for you and you don't mess up the factory one.
  12. I am pretty sure that you will need a longer chain. Unless you drag race, I think it will be over geared. The chain at some point will drag on your center stand but I'm not sure if it is with the 48 or not.
  13. It would work great though I didn't think it was a big deal getting it off. A lot easier than some lug nuts on car wheels.
  14. I wish I could get that Stealth sprocket in 47 tooth.
  15. Why would you want FI? Those guys are always complaining about this FI light coming on, that FI light coming on. I like my carbs, they work great.
  16. Anybody who has worked at a manufacturing plant knows that it wouldn't be to hard to get something that just isn't perfect. Most plants are happy with a 97-98 % of good product. Well someone has to get the other 3%. :cry:
  17. devilisht2003, what format is your link in? My computer asks me what I want to open it with.
  18. You can easily get it up by by chopping the throttle at 6,000 and then wide open but I remember the first time that I rode my 97. It didn't have much gas in it but I just rolled on the throttle to wide open and the front end just started coming up. I never had a bike that would do that before. Great feeling.
  19. So, are you going to sell that full Yosh system???
  20. Oh, you will get anti-freeze on the floor. Have something to wipe it up.
  21. Thin oil and a light rear tire will give you more horsepower but.......
  22. Now, go put it on the dyno, then switch back to the old header and dyno it again.
  23. Yep, you are right. I think that is why Honda changed it, to give the bike more torque at a lower rpm while trading off the higher rpm charge of the older model. So, would you say that you like it better?
  24. What does changing the fork oil height do? Yes, I know that you are changing the air gap but will adding more oil act like a stiffer spring or what?
  25. So the integrated for the 97-98 is only $89.99 but the 99 on is $149.99? I'm glad I have a 97.
