jimakazi Posted November 11, 2003 Posted November 11, 2003 [Edited from original topic] When I start my bike and it's running in neutral it has a lot of mechanical noise, but when I pull in the cluch it runs smooth and quiet [even idles OK]. It's like neutral is semi engaging a gear or something. I recall seeing a post a while back about lots of noise when the bike is started on the side stand - but starting it in the upright postion is better. Same for my bike. New oil [shell SX4] and filter, hydraulic clutch fluid, made no difference. I've cleaned all the gunk away from behind the front sproket / clutch actuator [suggestion from someone here] and again no difference I hardly ever use neutral anyway so it's no biggy - just curious. Quote
mickcbr1100 Posted November 11, 2003 Posted November 11, 2003 Try cleaning the clutch pushrod up first, get to it from behind the clutch slave cylinder, it gets all the crap off the front sprocket there, taking the rod out cleaning it and that area up does help. Clutch itself should be OK you'd be getting slip if it was on its way out. Doesn't seem to be an in between, its either quiet or rattles like a bag of spanners but has no ill effects. Quote
jimakazi Posted November 11, 2003 Author Posted November 11, 2003 I tried it, very satisfying to get all that gunk cleaned away, but no difference. Also I've realised it's when the bikes in neutral is when there is an issue, activating the clutch makes things better, so clutch likely all OK. Thanks anyway. Quote
joeblackbird99 Posted November 14, 2003 Posted November 14, 2003 When idling in nuetral the tranny gears are spinning past each other. Probably what you are hearing. Quote
MiDNiTXX Posted November 14, 2003 Posted November 14, 2003 Does the sound stop when you turn the engine off? Quote
cbrxxman1 Posted November 16, 2003 Posted November 16, 2003 it's just normal clutch noise my 00 the same way . Quote
Warchild Posted November 17, 2003 Posted November 17, 2003 You pull the clutch in, and all is silent, yes? It's just the clutch basket rattling around.... nothing to be concerned about. Many Blackbirds do that, particularly when cold. I personally have found that there is very little clutch basket noise once the bike is hot. But whenever it's cold, you can hear it fairly well upon startup unless you pull the clutch in. Nothing to be concerned about, you're good... Quote
