While this is pretty low in carbs, it's probably not suitable for the initial startup phase.
Crust:
1 1/4 cups finely ground almonds, cashews, or macadamias
Sweetener equal to 1 tablespoon sugar
6 tablespoons butter, melted
Topping:
2 cups sour cream (16 oz. container)
1 teaspoon vanilla
Filling:
3 packages (8 oz. each) cream cheese, softened
Sweetener equivalent to 1 cup sugar
4 eggs
1 teaspoon vanilla
In a bowl, combine the almonds (or cashews), 1 tablespoon sweetener and melted butter until combined. Press into bottom of a 9-inch springform pan. Chill in the refrigerator at least 15 minutes. In a bowl, mix the sour cream, 1 teaspoon vanilla and 1 tablespoon sweetener until well combined. Cover with plastic wrap and refrigerate. In a large bowl, beat the cream cheese and 1 cup sweetener until fluffy. Add the eggs, one at a time, blending well after each addition. Blend in the remaining 1 teaspoon vanilla.
Pour the cream cheese mixture into the springform pan, and bake at 350 degree for 50 minutes or until a knife inserted halfway between the edge and centre comes clean. With a spatula, spread the sour cream mixture over the top, making sure you reach to the edges of the pan. Return cake to oven and bake an additional 5 minutes. Remove cake from oven, allow to cool to room temperature (cake will settle in the pan). Slide a knife around the edge of the cake to loosen it, then remove the springform ring. Keep chilled in the refrigerator.
Makes 16 servings, about 5 grams of carbs per serving if made with almonds, and 7.2 grams per serving if made with cashews.
Even better if you substitute and actual vanilla bean scraping v.s. the liquid shit.....
Vanilla beans are like 7 bucks a bean here in my area..but worth it.
