mack82097 Posted June 12, 2003 Posted June 12, 2003 I just put a set of GenMar risers on the XX. Whenever it goes to full right lock, the choke cable gets pulled and engages the choke. I think that if I re-route the cable behind the left fork, maybe there'll be enough slack. Has anyone else had this same problem? Does the choke cable need to be replaced with a longer one? Thanks, Colin Quote
Pete in PA Posted June 13, 2003 Posted June 13, 2003 The choke cable is the one thing I didn't have probs with, nor have I heard it from anyone else. Where is it routed now? I've got Helibars, higher then genmars. Quote
mack82097 Posted June 13, 2003 Author Posted June 13, 2003 If you are sitting on the bike, the choke cable comes out from the left grip housing, past the front of the left fork tube, under the top clamp, into a hole in the frame right in front of the gas tank, and then straight back to the carbs. Maybe there's a channel on the bottom of the airbox for the cable? I recently took the tank and airbox off, so it's possible that I screwed up. Colin Quote
Pete in PA Posted June 13, 2003 Posted June 13, 2003 That's it! There is a channel between the bottom of the airbox and frame crossover tube. You might be able to wiggle it out, if not off the tank and airbox again. :cry: Quote
XXTi Posted June 14, 2003 Posted June 14, 2003 Choke Cable??? We don't need no Steenkin' Choke Cable!!! (FI XX's rule) Quote
Pete in PA Posted June 14, 2003 Posted June 14, 2003 That's OK, we can take our bikes apart without worrying about spraying 80 psi worth of gas all over. :twisted: Quote
Redbird Posted June 14, 2003 Posted June 14, 2003 That's OK, we can take our bikes apart without worrying about spraying 80 psi worth of gas all over. If that's your best argument for carbs over FI, I'll keep my '01, thank you very much :grin: . Besides, since when is spraying 80 psi of gas all over a bad thing? :twisted: Do chicks still dig scars even when they're 3rd degree burns on your face? :???: Quote
mack82097 Posted June 14, 2003 Author Posted June 14, 2003 It's fixed!!! Now I can choke my 'Bird!!! Quote
pace Posted June 16, 2003 Posted June 16, 2003 Colin, Is the GenMar revised bar position a major improvement (in terms of comfort) or is it barely perceptible? I'm considering going this route also (see my thread regarding my 'bird comfort issues). Thanks, -Pace Quote
mack82097 Posted June 16, 2003 Author Posted June 16, 2003 Pace, IMO the GenMar risers offer a decent increase in comfort. I noticed the difference right away, and I would recommend them to someone who wanted a super easy mod. -Colin Quote
bajjer9 Posted June 17, 2003 Posted June 17, 2003 I have the genmar risers and in reality all they are is aluminum thick walled pipe with a cap. Ill be moving to '02 vfr bars soon. I have seen side by side pics of stock 'bird bars and vfr ones and the vfr's are taller and a little longer as well as being a tad swept back. Good Luck! Quote
CBRRACER Posted September 5, 2003 Posted September 5, 2003 I just put a set of GenMar risers on the XX. Â Whenever it goes to full right lock, the choke cable gets pulled and engages the choke. Â I think that if I re-route the cable behind the left fork, maybe there'll be enough slack. Â Has anyone else had this same problem? Â Does the choke cable need to be replaced with a longer one?Thanks, Colin I am sure you are long enough for me! In fact I hope to find out during the NEXXT meet! :twisted: Quote
mikeG Posted September 6, 2003 Posted September 6, 2003 Do the VFR bars. I had both and ended up with the VFR bars. You can simulate the Genmars by just loosening up the bars an lifting them about a 1/2". Genmars only go up about 3/4". VFR bars go up about 3/4 or 1" and back about 1 ". Then you can lift those a little too! MikeG Quote
joeblackbird99 Posted September 6, 2003 Posted September 6, 2003 Did you guys by new VFR clip-ons from the dealer or a salvage yard? How much did you pay for them? Inquiring mind(s) want to know! Quote
bajjer9 Posted September 6, 2003 Posted September 6, 2003 I believe I paid about 186 bucks for mine from ron ayers http://www.ronayers.com/categories.cfm?yea...&make=1&color=1 Quote
mikeG Posted September 7, 2003 Posted September 7, 2003 Same here. Might be some in the salvage yards now but not last year. Also might want to try the VFR list. VFR guys may upgrade to helibars etc. MikeG Quote
