SwampNut Posted September 24, 2019 Share Posted September 24, 2019 I found the issue that caused the 403. It was an over-active SQL UDF injection prevention script, which thought some of the SQL language used by the forum could also be used for a SQL injection. I simply removed that one rule. I don't know how/if this affects copy and paste. Let me know. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted September 24, 2019 Share Posted September 24, 2019 2 hours ago, SwampNut said: I found the issue that caused the 403. It was an over-active SQL UDF injection prevention script, which thought some of the SQL language used by the forum could also be used for a SQL injection. I thought that might have been the problem. 😀 Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted September 25, 2019 Author Share Posted September 25, 2019 In layman terms, what in the offending paragraph triggered the issue? I don’t see how anything I wrote looks like code or was it buried in something other than the text itself? Quote Link to comment Share on other sites More sharing options...
SwampNut Posted September 25, 2019 Share Posted September 25, 2019 Sorry, I don't have a specific answer. Something in the formatting code triggered the same response as an attack would, under that one rule. You can't plan for all attacks, so some rules are over-reaching. Like your immune system responding to something inside your body and attacking you. AIDS. You gave the board AIDS. Quote Link to comment Share on other sites More sharing options...
